'15 F800GSA overheated, fan not cycling??
Discussion in 'Parallel Universe' started by KILR0Y, Aug 21, 2019.
  1. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    Coming home from work yesterday at around 100 deg F i was stopped at a traffic light for quite some time after highway speeds. When the light turned green i took off and noticed a huge loss of power, and a check engine light. Eventually the bike stalled and i pulled over to the sidewalk. After cooling a bit it started up and i drove 2 blocks home and parked it until today.
    Can't seem to find anything about testing the fan or location of the fan fuse. Can anybody more versed in this give me a little advice? After pondering over this i can't ever remember hearing the fan come on (that day, or ever) even on dessert ADV rides.
    Only issues ever are yesterday I'm having overheat issues, which i suspect is the result of inop fan...
    Bike is 2015 F800GSA stock except for AFIXED installed.
    Any help would be greatly appreciated.
  2. TRJeff
    TRJeff Adventurer
    Feb 10, 2013
    28
    Check first if you can spin fan by hand, mud and road grime/trash can block fan from turning, if fan turns easily then you will need to see dealer or if available someone with a GS-911WIFI, if fan had tried to start and overloaded the electrical the canbus would reset after a engine shutdown and restart .
    KILR0Y and JRWooden like this.
  3. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    Ok, Fan doesn't spin "freely" by hand. It seems a little gummed up.
    Replace it or is there a way to get it freed up?
    Are there good aftermarket options?
    Will the fan relay start on its own after I R&R?
    Thanks a bunch
  4. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    Got the fan out and it spins, but nor easily. Wondering if the dealer will test, or if i can apply power. Does anybody know if it takes 12v straight?
    Holy Shit, $322 from dealer... there's got to be another option.
  5. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,189
    Lanark County near Ottawa ON
    Used one from eBay.
    KILR0Y likes this.
  6. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    Just bought, thx!
    Hopefully install and it'll work with no other issues. Do i need to reset anything or replace a fuse?
  7. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    Anybody in the Reno-Tahoe area with a GS911 willing to help me diagnose/test my bike to assure the new fan is operable after replacement is installed? Thanks.
  8. TRJeff
    TRJeff Adventurer
    Feb 10, 2013
    28
    No fuse, canbus monitors amperage and shuts down fan if overloaded,
    #8
  9. bmwroadsterca
    Jan 3, 2007
    1,189
    Actually the ZFE does this. CANbus is a Controller Area Network.
    #9
  10. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    So the fan should start automatically once the replacement is installed into the bike and the temp sensor tells it to run (assuming the replacement works)?
    #10
  11. Scubalong
    Scubalong Long timer
    Apr 25, 2012
    1,124
    So Cal
    You can let the bike idle for about 15 minutes, the fan should turn on when the temperature reaching 4 to 5 bars on the gauge.
    #11
  12. ROMAD
    ROMAD Been here awhile
    Sep 23, 2008
    246
    N.TX
    The free version of Motoscan has a fan off/on test. I used it myself because I never heard the fan come on when riding in TX summer heat. After the test I did get it to come on normal after a couple long lights in stop and go cross town and 96F temps.
    #12
    KILR0Y likes this.
  13. KILR0Y
    KILR0Y Is here...
    Jul 8, 2016
    165
    PNW
    Got the new fan today and it spins nice and free with flick of the finger. Installed & tested via idle - cycled great after about 15 min idle as previously posted.
    All good now for $99 ebay and about 2hrs labor. I'm sure i saved myself about $500 over new/oem with shop install.
    Thanks for the information. Glad i discovered it 2 blocks from home and not 40 miles out in the desert on a 100deg day.
    #13
  14. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    786
    Denmark
    Connetc the fan directly to 12v then you know if you solved the problem. Can be the switch or wiring..
    #14
