16 T Sprocket the best $30 dollars you will ever spend
Discussion in 'Dakar champion (950/990)' started by Ricardo Kuhn, May 6, 2004.
  1. LC12JT
    LC12JT Adventurer
    Oct 27, 2003
    99
    Prescott, AZ
    On the trip to Baja this weekend, the GPS logged a top speed of 118 mph with a 16t. (Didn't have time to check what the speedo was reading.) The bike had a bit left, but the next corner was approaching much too quickly.
    #21
  2. barbasma
    barbasma 100% CAROTONE
    Aug 19, 2002
    1,821
    Sondrio (In the middle of the Alps) Italy
    17/45 work without new chain... you have to mount the rear chain settings... reversed...
    KTM don't make original 44 sprocket... but other company does... and cheaper.. http://www.pbr.it/
    pics of a friend with 44..
    #22
  3. barbasma
    Aug 19, 2002
    1,821
    question...
    the rear sprocket mount are same for 950, lc4 and EXC?
    #23
  4. Flanny
    Flanny Flanny-it-up!
    Feb 18, 2003
    2,739
    Ottawa, Ontario, Canada, the World, the Universe
    No the 525 chain on the 950 is wider than 510 on LC4, the sprockets are noticeably wider....They may mount the same, but they are not the same size sprockets...
    #24
  5. barbasma
    Aug 19, 2002
    1,821
    thanks... :thumb
    #25
  6. Ricardo Kuhn
    Ricardo Kuhn a.k.a. Mr Rico Suave
    Sep 20, 2001
    17,305
    Minneapolis (don't even ask how i end up here.
    Great explanation accurate and concise
    So anybody know if they make one of this half aluminum half steel deal,I think that will be lovelly
    #26
  7. Flanny
    Feb 18, 2003
    2,739
    As far as I know, only Stealth makes the alluminum/steel sprockets.
    http://stealth-america.com/
    ON this site:
    http://www.supersprox.com/listy.php?type=ktm
    They list one for the 950 in 525, part #: K5110010 from 38-52 teeth.
    I suspect that sprocket bolt paterns are standard, and that any 525 stealth for street bikes would work fine.
    BTW...I'm pretty sure the LC4 etc. use 520, not 510 as I indicated previously.
    #27
  8. barbasma
    Aug 19, 2002
    1,821
    the STEALTH sprocket are also in KTM POWER PARTS CATALOG... :wink:
    VERY VERY INTERESTING.... :thumb
    #28
  9. joe riddle
    joe riddle riddler
    Apr 14, 2004
    9
    My bike is dead stock except for the 16t sprocket and I got an indicated 128mph in 5th and 6th before it ran out of steam. The front end was pretty unstable feeling at that speed and I only ran at that speed for aprox. 10 miles this was in western Kansas, real flat good road, and the bike had about 2600 miles on it at the time.
    #29
  10. SoCalSar
    SoCalSar Wudup y'all!!
    Mar 13, 2004
    10
    San Diego, CA
    About the Stealth sprockets....
    I ordered one for the Husqvarna Supermoto and what came in was one of the "streetbike" style sprockets. That's probably what you'll get for the 950 also. I really liked the slimmer look of the dirtbike sprockets, but with several thousand miles on it and no appreciable wear I'm not complaining!
    #30
  11. katoom_950
    katoom_950 Life, 2 short 4 traffic
    Mar 9, 2004
    343
    Bali, Indonesia
    Go to this site and download a gearing chart. It allows you to enter the relevant details of your bike and see the differences in changes to your gearing.
    Gearing Chart
    For your information the ratios for the 950 are as follows;
    primary: 1.91
    1st: 2.92
    2nd: 2.13
    3rd: 1.72
    4th: 1.35
    5th: 1.13
    6th: 0.96
    Then the combination of the front and rear sprockets.
    Good luck
    #31
  12. KTMax
    KTMax Ninth of the Nazgul
    Oct 28, 2003
    1,099
    Amsterdam, The Netherlands
    Yep. It's excellent.
    I've put in the values for the 950 and - suprise suprise - it confirms the stock gearing being way too high. Given that 99% of the 950s deliver peak power at 8500 RPM (mine does too on the Dyno) 17T vs. 16T looks like this:
    On 17/42 in 6th at 8500 RPM: 236 KM/h or 147 MPH No way... :D The engine won't come near 8500 in 6th
    On 16/42 in 6th at 8500 RPM: 222 KM/h or 139 MPH Still high but a step closer to reality.
    #32
  13. Ricardo Kuhn
    Sep 20, 2001
    17,305
    WoW that is really cool can you do it with the 16T front anf the 45 T back
    maybe i try my self but i suck at it:deal
    #33
  14. Ricardo Kuhn
    Sep 20, 2001
    17,305
    Kirk Maybe you need to try this aproach
    I for sure don't know better since I install MAMF splash guard the minute i got the bike,but i don't see why not you can not take it out when is not wet,,take no time to do it anyway
    #34
  15. kirkmoon
    kirkmoon Making up for lost youth
    Feb 11, 2003
    8,912
    San Francisco, CA
    :rofl
    It took all of 2 minutes to install the thing. But I am too lazy to be putting it on and taking it off.
    On another note, I have been trying to figure out if the mudguard has any effect on wind buffeting since it more or less eliminates the flow of air up the forks and thus should be creating a larger vacuum behind the windscreen. I haven't been able to tell much difference, however.
    #35
  16. katoom_950
    Mar 9, 2004
    343
    Bali, Indonesia
    Reading back over this thread I have been reminded of an experience I had as a wide eyed 14 year old.
    I was out with my brothers God Father who just happened to be a Ferrari fanatic. We were on the way to a Ferrari Owners Club meeting and in his 275GTB 4 Cam Long Nose, a 1964 I think. Anyway, on the blast along the M4 he commented on how close the gearbox ratios were but also that when in top gear the needles of the tacho and speedo moved in unison. The fact being that at max power you are at max speed, in effect a 1:1 ratio.
    I have always remebered this and felt that as times have changed we now loose this ability to judge a vehicles gearing as most bikes now come with either all digital dashes or a combination of analogue and digital.
    Nevertheless, my point really is just that, should we try for max power at max speed? Or are we chasing a Holy Grail? Maybe it is a case of how and where you ride rather than what the perfect gearing is...
    Im thinking out loud you know. ots saturday, beer, football...... :freaky
    #36
  17. tools
    tools Adventurer
    Apr 30, 2004
    11
    Colorado Springs, Colorado
    How does one change the sprocket?
    #37
  18. Ricardo Kuhn
    Sep 20, 2001
    17,305
    I wrote this procedure for Motoreviewer
    I hope you find it useful
    #38
  19. Ricardo Kuhn
    Sep 20, 2001
    17,305
    What was beautyful,,,
    i like the way you think :freaky
    #39
  20. KTMax
    Oct 28, 2003
    1,099
    Sure, here you go.
    Based on my experience with 16/42 I think that 16/45 is uneffective i.e. too low if you use your bike on the street too. I'm sure it will feel 'spectacular' alright. Freaky short gears with the engine ripping through it like a maniac. But I doubt it will be an improvement. You'll be dancing the gearlever more than on 125 two-stroke. :D The very short bursts of power will be un- or at least less controlable too. With the proper mods the LC8 engine has quite a bite on a high(er) gearing already I'd say.
    You can remove 1st gear altogether and on every stretch of tarmac or highway (you do encounter these every now and then...) you'll be revving and buzzing along in a very unnerving way I think...
    #40
