18 inch rear on the 8GS.....
Discussion in 'Parallel Universe' started by ebrabaek, Jan 24, 2012.
  1. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    Grand Valley, Colorado
    I searched for a while...and while there are post regarding the 18 inch rear.... I would like to ask you fine folks that did the conversion to 18 inch rears. In the next week or two...I will have my rear wheel send to Woody's....for a tubeless conversion..... I don't mean to start a tubeless....vs. tubed thread... But would really like to hear what you guys that has done this.....have to say... I am leaning that way....for my riding style. Bigger wheel roll over angle.... better off road traction...... But as with anything here on this forum..... your answers are a great help....... So after 18'ing it....wadayathink...:freaky:freaky
    :thumb:thumb
    Erling
  2. BMW_BIKER_KEITH
    BMW_BIKER_KEITH Been here awhile
    Mar 11, 2010
    395
    St Louis Missouri - USA !
    Good starter thread Earling... I am contemplating this too.
    To that, some folk I think have done a 19" front (tubless) from Woodys...
    Not to hijack this thread, but I would like to consider an F & R conversion to tubeless. In doing so, the bike has to end up a bit lower, and on the front, a little more fender clearance is gained.... right?
  3. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    Yeppers.... You would gain that....and if your off road riding is limited to dirt roads....washes....ie... no rock hopping etc.... you would be fine with the smaller front. for my riding style I will need to retain the 21 front....and would love the tubeless conversion....But nothing effectively beside Alpina (very costly) available. I spoke with Chris at Woddies yesterday.....and as usual..they are very knowledgeable....and offer tremendous help. This I know... I'm going tubeless on the rear..... Either retaining the stock wheel at 17 inch....( about 100-200 including boring out the hub+truing labor)...Or and excel 3.5 x18 incher all included for 650'ish. Tires cost about the same.......with a little more road rubber available in 17.....and a little more dirt rubber available in 18. Tire clearance is fine according to Chris...and a 1/2 inch higher tire lift of the bike is not an issue with me. Then there is the matter of ABS...? and how much taller the tall first gear now will feel..... Since I am using this for 50/50.....So you guys that have done the 18 rear..... How are you coping...????:thumb:thumb
    Erling
  4. nzcvlh
    nzcvlh Been here awhile
    Feb 2, 2008
    112
    Oracle AZ
    I did the 18 conversion. two things to consider. You need a 45 rear sprocket to get the equivalent of the stock 42 because of the increased rolling radius. If you are switching between a 16/42 stock and 15/45 off road you will be tight to the front of the swing arm and if you have a mudsling or similar device, the clearance can be tight unless you add links to chain.
    Dave
  5. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    That's what I was afraid of.... The first gear is too tall to start with.... and the extra 1/2 inch will obviously make that a little worse.... I will not re-gear it on the front or rear.... Was the gearing a big impact for you....???? On techno sections... that first can be a little tricky... How much did it impact you on the road???.:thumb:thumb
    Erling
  6. grndzr0
    grndzr0 its Ground Zero
    Feb 19, 2010
    661
    Montana
    Just curious, but why don't you want to re-gear it?
    Ryan
  7. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    Good question....:D.. I really don't have an acceptable answer. I was thinking of it...as a drawback.... Like a negative that if needed....it was a strike against the 18...... But in retrospect....and in this day and age of thousand dollar farkles..... a sprocket set is not a big deal.....if all other things are good. I think I said that out of stupidity...... Thanks for shaking some reality in me....... Not kidding here....:thumb:thumb
    Erling
  8. HighFive
    HighFive Never Tap-Out
    Nov 8, 2006
    3,484
    Okiehoma
    I've wanted to do the 18" rear. But, I'm running a 17/45 sprocket combo which allows me to swap to 15/45 when I hit the mountains. This option really gives the bike some superior versatility. The lower gearing (3.00 vs. 2.65 ratio) really makes it a much better trail runner in the rough stuff. However, this requires most of the room (forward to aft) with the axle adjustment slot. So, I'm not sure an 18" wheel will still allow me to do this. Its something I've pondered much...
    This gearing option is a bigger advantage for me than an 18" wheel would be, if I can't have both. But I'd really like both. A little more ground clearance would be helpful. Though, I've not really had any traction problems with the 17" wheel.
    HF [​IMG]
    #8
  9. Pantah
    Pantah Jiggy Dog Fan Supporter
    Oct 25, 2004
    13,114
    Scottsdale Arizona
    Why spend all that money? What advantages are you getting? Seems like all negatives to me.
    The 17 inch rear wheel/tire is totally servicable on any surface to can navigate with a 500lb motorcycle. Besides, the outside diameter of your rear tire is already bigger than an enduro bike. Going tubeless is a problem in the bush as well. Bent a rim and your walking out. Add in the chainset to get your gearing back...$$$
    Tubes and spokes are good things for adventuring. I vote save your money and spend it on a trip through the Yukon. :D
    Edit: The OD diameter of a 150/70/17 is almost exactly the same as a 130/80/18 found on most dirt bikes.
    #9
  10. SportFaller
    SportFaller Dirt dont hurt, MUCH
    Sep 29, 2008
    668
    Laramie, WY
    For me it all comes down to tire selection, an 18" rear gives you a multitude of choices, many at reasonable prices.
    Woody will be getting some business from me after tax season.
    #10
  11. nanotech9
    nanotech9 ** Slidewayz **
    Aug 10, 2009
    1,441
    Oklahoma City, OK
    I don't see how. Tubeless gives you an advantage... pull out a nail, add a shoe-string patch, and you're fixed. Just a few seconds and you're on your way.
    With a tube, you're breaking down the entire wheel/tire to patch it, and hope you didn't forget your patches. With the nail, well, heck, stick the nail back in and it'll patch the hole for a while if you're out of real patches.
    On tubeless, you can ALWAYS carry a tube with you and put it in if you get a puncture that a shoe-string plug won't fix. We experienced this in AZ on a front 19" on a 12GS... sidewall pinch flat on a tubeless - added a tube, and he was on his way.
    I see a tube as a backup plan to tubeless, but running tubes isn't essential to adventure riding.
    #11
  12. Pantah
    Oct 25, 2004
    13,114
    Scottsdale Arizona
    That is all true, but is it worth the money? Fixing a flat is no big deal. If you are willing to carry a spare tube, why bother with going tubeless in the first place? Tubeless tires are for cast wheels on the highway. :wink:
    #12
  13. señormoto
    señormoto Supermoto Abuser
    Jul 10, 2007
    1,110
    California + Costa Rica
    It's worth the money if you aren't a stickler about money. $1300 for a new Woody's rear wheel (KTM hub, rotor adapter, superlace, epoxy sealing) is not a lot of money for some people, and it's a ton of money to others. For me, it was worth the cost because I hate dealing with tubes when I'm riding solo in the middle of nowhere.
    YMMV
    #13
  14. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    I will use my stock hub..... Excel 3.5 rim ...... Superlaced.... Tubeless converted 18 ........
    $600'ish. Stock hub is ugly...... But good for saving $600 for a nice ano hub...:)
    Just need to be practical.
    #14
  15. Lounge
    Lounge Been here awhile
    Jul 2, 2010
    915
    COS
    I'm using a Woody's built 18" Excel rim - tubeless. Expensive but I haven't once regretted it.
    #15
  16. Dusty Kiwi
    Dusty Kiwi Kia Kaha
    Nov 29, 2010
    59
    Nth West WA
    I did the Woody's 18 x2.5 rear and 21 front so I could rim locks and run ultra heavy duty tubes and Michi Deserts for a 13000 km ride last year. This took in everything from desert tracks to hwy and went across Australia and back. The wheels are superb and I didn't get one flat using uhd tubes. I kept the gearing the same by going 45 on the rear and had no problem with the gearing option when paddling some horrible sand dunes or travelling at hwy speed.
    One thing to think about is when you bottom the rear this 18 can make contact with the rear guard. I broke one and ended up limiting the stroke a little to stop the potential contact. The bike was carrying a lot of extra weight when this happened and not riding conservatively.
    My vote keep the tubes and go 45 rear.
    800GS can do almost anything.
    #16
  17. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    Nice.... Did you re gear....... Since you have goooobs of good terrain around you.... Or did the taller first not bother you???
    Erling
    #17
  18. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,727
    Awesome...... Thanks
    Erling
    #18
  19. goodtimes
    goodtimes local bum
    Oct 26, 2006
    969
    chair in front of my computer
    Not just choices - but overall availability if you are in a small town. It's much easier to find 18" tires than 17" - especially if we're talking about tiny little towns where you always seem to be when a tire disintegrates . . .
    Another thing to consider is the resale value of the OEM wheels. It's been a while since I sold mine - but basically the cost of a set of complete wheels from Woody's, minus the sale price of the OEM wheels was pretty darn close to just having them re-use my OEM hubs and replace everything else. Obviously you'll want to look around at the current going rates for OEM wheels and do the math . . . but I was surprised at the result when I did it a year ago.
    #19
  20. grndzr0
    Feb 19, 2010
    661
    Montana
    This is a good point. I live in Billings, MT. Biggest city in the state. (still only 100k people) I needed a tube last summer, 1 out of our 4 bike shops had a tube for a 17"
    Ryan
    #20
