180mm clutch disk BMW vs VW
Discussion in 'GS Boxers' started by hasenwerk, Feb 15, 2010.
  1. beantop
    beantop Remember, Safty Forced
    Sep 21, 2008
    5,825
    Enola, PA
    Beamer Bone Yard
    BBY
    Sent from my SM-N920V using Tapatalk
  2. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    31,387
    The Berkeley of Arkansas
    there is a spring in the input shaft already internal to the transmission, I think the consensus was that the external was not needed.
    but if so, yeah, 40 seconds with a grinder would reduce the hub OAL enough to use a stock VW disc, IF you can source the longer bolts needed ( the friction material is too thick as delivered)
  3. Eddieb
    Eddieb Long timer
    Nov 14, 2006
    1,492
    Hamilton, New Zealand
    Thread dredge and direction change.
    If there's so much similar between the R1100 clutch setup and the VW, does this mean it would be fairly easy to mate a R1100 engine and a VW Beetle/Bug gearbox and run a Beetle off teh R1100 powerplant?
    matkal likes this.
  4. kalaharipierre
    kalaharipierre n00b
    Jul 30, 2014
    2
    south Africa
    I am in process of doing vw 180 mm solid plate ,will report as soon as finished.
    ogklx400 and lewisjr1 like this.
  5. kalaharipierre
    kalaharipierre n00b
    Jul 30, 2014
    2
    south Africa
    Assembling for 5th time :baldy got shimming up to 1.5 mm now it does not bind:-)Now for re assembly of rest of bike tomorrow. The next step will be to see if it performs as planned with fully loaded /pillion and luggage to ascertain if it will slip , smoke or just fail.
