180mm clutch disk BMW vs VW
Discussion in 'GS Boxers' started by hasenwerk, Feb 15, 2010.
  1. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    31,387
    The Berkeley of Arkansas
    there are VW aircooled clutch discs available without the sprung for under $20.
    If I bought one and milled the hub down to fit, would this be a frugal 1100GS replacement clutch?
    #21
  2. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    Link? I'd like to buy one for the hub.
    <BR>
    #22
  3. Rabbitson
    Rabbitson Been here awhile
    Oct 3, 2004
    568
    Somewhere in Deepest Benelux
    I put a Lucas replacement clutch in mine with the other parts of the BMW clutch kit, much less expensive than BMW or Touratech and (I believe) better than the standard sachs BMW item.
    David
    #23
  4. Rabbitson
    Oct 3, 2004
    568
    Here's a link on flea-bay if you're interested.
    The material on the clutch is supposed to be superior to the standard BMW item which I've worn out several of.
    HTH,
    David
    #24
  5. Rabbitson
    Oct 3, 2004
    568
  6. mouthfulloflake
    Aug 21, 2008
    31,387
    #26
  7. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>Thanks Lake
    <BR>
    #27
  8. Grad
    Grad Wannabe
    Dec 7, 2004
    2,260
    Athens, GA and Blairsville, GA
    this is a very interesting thread. is the clutch for the 1100 and the 1200 basically the same?
    #28
  9. chiba
    chiba FYYFF
    Aug 27, 2007
    1,195
    Mechanicsville VA
    This might sound like a stupid question, but what good is having springs on a clutch disc?
    --chiba
    #29
  10. dancy
    dancy Undescended Testicle
    Aug 19, 2005
    14,344
    SATX
    I don't think the VW clutch could take the power :D
    #30
  11. hasenwerk
    hasenwerk Long timer
    Sep 11, 2008
    1,353
    Quesnel, BC
    I don't think so.. I will snap a photo tonight of the assembled VW clutch.
    Waiting to hear back from my VW clutch builder for a four puck... should be very interesting indeed.
    #31
  12. hasenwerk
    Sep 11, 2008
    1,353
    Quesnel, BC
    In theory, less initial shock on the gearbox and input shaft.
    #32
  13. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    Or the weight&#8194;:lol3
    <BR>
    #33
  14. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    Exactly, but as Anorak pointed out, the input shaft already has a spring loaded shock absorber built into the gearbox.
    <BR>
    #34
  15. hardybaker
    hardybaker Been here awhile
    Apr 15, 2003
    340
    Marquez, Texas
    Chiba, The springs on the disc (or clutch plate) absorbs or softens the torsional load as the plate is squeezed (or maybe a better description is, locked-up,) as the pressure plate locks the clutch plate to the flywheel.
    #35
  16. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>The clutch hub isn't directly connected to the friction disk mounting plate. When the clutch hub rotates, it pushes on the springs, then the springs push on the mounting plate. It works in both directions.
    Also there is a thin wafer 'wave' spring, the same size as the friction material, mounted under the friction material. The slight cushion reduces engagement grab and chatter.
    <BR>
    #36
  17. Gradall
    Gradall Army of one gets it done
    Sep 11, 2009
    75
    Baltimore
    I was told that the spring are in the clutch disk to smooth out the pulses of the individual cylinders firing.
    #37
  18. Kevreif
    Kevreif Been here awhile
    Nov 12, 2007
    449
    where the west and north branch susquehanna meet
    though it may help with the pulses i don't think that is the reason they are in there. every stock clutch i have changed has had them. as said above i think they are in there to lessen the shock on the input shaft and engine, between on/off throttle changes and clutch engagement.
    i replaced the clutch in my dodge cummins with an the aftermarket clutch, the one i put in didn't have springs, and does chatter or buck when trying to back a heavy trailer up a hill. but i think that it is due to the half ceramic friction material, not the lack of springs.
    jsut my .02
    #38
  19. ABuck99
    ABuck99 0.0
    Feb 21, 2009
    796
    Georgia
    GB- FYI- It appears from the photos in the TT website that the Ceramic clutch from (Cytech)Tours for Africa is subtly different from the TT ceramic clutch- I dont have a TT style in my hand to confirm it, but I do have one from Cytech I got a few days ago. And from the picture of the TT they are a little different. Either the Cytech( tours for africa)is a knock off, or more likely, Sachs is making it for Cytech, and are making it a little differently for proprietary reasons. Either way- you might not want to say its the same.
    Also the price no longer quite half compared to the TT. The current price is 2800 Rand, which is about $365( at todays exchange rate)+ shipping + exchange rate fees, plus transfer wire fees( all of which Cytech charges you for), which brings it closer to $475 to $500 depending on where you live. Still less than the TT, but higher than originally posted from April 2008 thread.
    Here is a photo of the Cytech Ceramic Clutch:
    <form name="guestpassword" action="http://s962.photobucket.com/home/FredZiffle/editalbum" onsubmit="document.fire(SharePanelController.EVENT.PRIVACYCHANGESUBMIT,{form:this,mode:'guestpw'});return false;">
    <input name="ts" value="1266361032" type="hidden"><input name="sig" value="819ebec5d51b56ee6f7509c58778684b" type="hidden"> <input name="pubpriv" value="private" type="hidden"> </form>
    <iframe id="shareMobileFrame" border="0" frameborder="0"> </iframe>
    <script type="text/javascript"> </script> <form name="sharePanelMySpace" id="sharePanel_MySpaceForm" method="post" action="http://www.myspace.com/index.cfm?fuseaction=postto" target="_blank"> <input id="sharePanel_MySpaceFormContent" name="c" value="" type="hidden"> </form>
    <script type="text/javascript"> //Instantiate the tabbedpanel on render var cfg = { defaultOpened : 1, key : 'sharePanelTabs', totalPanels : 4 }; var sharePanelTabs = new tabbedPanelHelper(cfg); var sharePanelController = SharePanelController.getInstance(); sharePanelController.mixIn({contentId: 'sharePanelContent',progressId: 'sharePanelProgressContent',wrapperId: 'sharePanelWrapper',tabController: sharePanelTabs,tabPanelMap: {'easy':1,'email':2,'linkcode':3,'mobile':4},isSearch: false,isAlbumPublic: true,hasGuestPassword: false,albumParentLink: 'http://s962.photobucket.com/albums/ae102/FredZiffle',isAlbumOwner: true,isLoggedIn: true}); </script>
    <!-- Bserver Implementation--> <script type="text/javascript"> jq(document).ready(function() { APIRequest.track("fullview_views", 1); APIRequest.track("page_view_logged_in"); APIRequest.track("page_view"); }); var preloader = new PBScriptPreloader(); preloader.add("http://static.pbsrc.com/include/js/pkgs/albumtheme_v23.4.12.js"); document.fire(PB.EVENT.PAGE_LOADED); </script> <!-- Google Analytics include --> <script src="http://www.google-analytics.com/ga.js" type="text/javascript"></script> <script type="text/javascript"> var pageTracker = _gat._getTracker("UA-245455-1"); pageTracker._setDomainName(".photobucket.com"); pageTracker._setAllowHash(false); pageTracker._trackPageview(); </script> <!-- dfdfc4836b63dd84312279af52791431 --> <!-- den3ws537 --> <!-- Begin comScore Tag --> <script> document.write(unescape("%3Cscript src='" + (document.location.protocol == "https:" ? "https://sb" : "http://b") + ".scorecardresearch.com/beacon.js' %3E%3C/script%3E")); </script><script src="http://b.scorecardresearch.com/beacon.js"></script> <script> var origURL = document.location.href; var truncatedURL = origURL.split("?", 1); COMSCORE.beacon({ c1:2, c2:6034695, c3:"", c4:truncatedURL[0], c5:"", c6:"", c15:"" }); </script> <noscript> http://b.scorecardresearch.com/p?c1=2&c2=6034695&c3=&c4=&c5=&c6=&c15=&cj=1 </noscript> <!-- End comScore Tag -->
    #39
  20. hasenwerk
    Sep 11, 2008
    1,353
    Quesnel, BC
    I think, at least just form everything just sitting on the desk, that it will work. There's just a tad more friction surface showing but I don't think it would be that great of a deal...
    BMW Disc
    VW Disc
    #40
