180mm clutch disk BMW vs VW
Discussion in 'GS Boxers' started by hasenwerk, Feb 15, 2010.
  1. hasenwerk
    hasenwerk Long timer
    Sep 11, 2008
    1,353
    Quesnel, BC
    I have quantity six, 180mm diameter, 6.5mm thick (friction surface thickness) four puck ceramic clutches coming to me from my clutch builder. Correct splines / hub thickness for the BMW R1100 GS - direct drop in with out the shims needed for the TT / Sachs clutch. I had to get six because of the custom build so, one for me and five for ???? Pricing I have no idea... definitely more than a standard Beetle clutch but way less than the TT / Sachs clutch! :freaky
    #61
  2. KShow
    KShow Been here awhile
    Dec 16, 2007
    675
    Shenandoah Valley, VA
    very interested
    #62
  3. arboffroad
    arboffroad Been here awhile
    Sep 3, 2009
    133
    If it will fit an hp2 enduro I am interested
    #63
  4. Andrew
    Andrew Optimus Primer Administrator Super Moderator
    Sep 25, 2001
    24,857
    Eastbania
    Not to mention, it brought Ricky Patineto out of the woodwork... :thumb
    My mind has been cogitating on Poolside's comment about the unbalanced clutch disk wearing the splines... wild and scary hypothesis, and you have to wonder why the mother ship would let such a glaring flaw slip through.
    #64
  5. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,291
    The woods and mountains of Alabama
    Are they balanced?
    BTW, nice job on the winter Olympics so far.... :super
    #65
  6. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,715
    Sunshine Coast B.C.
    #66
  7. def
    Feb 28, 2004
    14,291
    Any further details such as brand or model? I don't want one of these!
    But, the splines look OK......
    #67
  8. jasonTDI
    jasonTDI TDI Guru
    Jun 7, 2008
    193
    Just south of Madistan, WI
    #68
  9. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,889
    Silicon Beach, CA
    <BR>
    The offset hub, combined with no pilot bearing, is what causes the spline wear. It'd require some imagination to get a pilot bearing there because of the clutch actuator rod.
    I agree though, a longer 'snout' on the clutch hub might help matters. Since the input shaft wear is from the snout side of the clutch hub. There is some extra spline that the clutch hub isn't engaged with, so another maybe 15mm of clutch hub would have spline.
    The VW clutch disk does have a longer snout, I think, from what the OP was saying. So maybe it doesn't even need to be faced to length and can be used as is.
    <BR>
    #69
  10. scooteraug02
    scooteraug02 Dog Rancher
    Feb 18, 2003
    4,588
    Atlanta, GA
    Dang I posted the link. Click it for more info.
    http://www.rbracing-rsr.com/bmw_clutches.html
    This site is pretty interesting. I think it is current they have R1200GS clutches for sale.
    #70
  11. hasenwerk
    Sep 11, 2008
    1,353
    Quesnel, BC
    Yes they are balanced! The place that is making them for me makes their living doing clutches! :wink:
    Yer welcome on the Olympics - I'll be paying for them for the rest of my and my kids life - enjoy them!
    #71
  12. hasenwerk
    Sep 11, 2008
    1,353
    Quesnel, BC
    I have no idea if they would work or not... well... I take that back... I think the 1200s have a different spline count so, no, I don't think the discs that are getting made up will work on a 1200 series bike.
    #72
  13. hasenwerk
    Sep 11, 2008
    1,353
    Quesnel, BC
    These guys lists clutches for sale, but don't have any to sell... else I and a few other people would have bought them. They look like a good idea!
    #73
  14. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    57,214
    San Rafael, Marin County
    RB Racing scares me. When I read the website, I expect a giant fist with big skull rings to punch me in the face.
    #74
  15. def
    Feb 28, 2004
    14,291
    Does anybody have any experience with this?
    http://www.sunshinecoast.ca/bmw/InputShaft.pdf
    :dunno
    #75
  16. Rode2Nowhere
    Rode2Nowhere Long timer
    Sep 1, 2007
    2,299
    Saratoga, NY
    Looks like "how could it be bad?" But DAMN! Holy expensive! :eek1 Although I guess if their claim for longevity is accurate, it's worth it. :dunno
    #76
  17. Andrew
    Sep 25, 2001
    24,857
    Eastbania
    This is why I eschew motorcycling, and motorcyclists. I have tender cheekbones.
    #77
  18. def
    Feb 28, 2004
    14,291
    Expensive...yes!
    The metallurgy, broaching accuracy, heat treating and lubrication all need to be right in order to eliminate clutch/input shaft spline failures.
    Also, I am a proponent of balancing the whole clutch assembly in order to eliminate the clutch disc "whipping" at the end of the transmission input shaft. Other than the rear wheel, the clutch assembly is the largest diameter, highest mass rotating part in the power train. Therefore, balance is a critical element in reducing unwanted forces and vibration...just as important (if not more so) as balancing the engine.
    #78
  19. GS Addict
    Sep 24, 2006
    7,715
    Sunshine Coast B.C.
    I have, it's my link. The prototype is in my machine now at 39,000km and I plant to look at it next winter. (I will post my findings)
    There was a lot of interest in it but I could not 10 orders to go ahead with a batch run. The price is high when compared to the OE part but what people did not factor in was the 12+ hours labour to change it out each time. I was having these made onshore and I am not willing to go elsewhere to have it done. The reason for the high cost is because the improved shaft has to be machined twice, once to create it, then out for case hardening and then machined once more to bring it to the exact size. Have a real hard look at the part....there are many processes required to make it - a complex piece with just about every dimension critical.
    #79
  20. def
    Feb 28, 2004
    14,291
    Addict,
    I have no doubt that there are high costs associated with this piece. After all, it is not a mass produced item. Do you know the Rockwell hardness of the spline area? I have yet to open up my clutch inasmuch as I have no issues with shifting or other signs that my splines are junk (only 40,000 miles, mostly just touring). But, one day, I'll go in and see what replacements, if any, are needed.
    I'll be interested to see your report next winter when you go in to have a peek. Keep us posted. Thank you.
    PS, Next time I'm in BC I might schedule a visit to talk metallurgy and machining with you. I do business with a Vancouver outfit.
    Dennis
    #80
