1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
188 mpg - F800GS
Discussion in 'Parallel Universe' started by grandpa_ken, Oct 30, 2008.
  1. RedHawk47
    RedHawk47 Adventurer Supporter
    Oct 5, 2006
    1,481
    Berthoud, CO
    A gallon is four quarts, regardless
    Imperial gallon (UK or Canadian) = 4 Imperial quarts = 160 fluid ounces
    Imperial quart = 40 fluid ounces
    Gallon (US) = 4 quarts(US) = 132 fluid ounces
    Quart(US) = 32 fluid ounces
    So it would be correct to say that Imperial gallon(UK) = 5 quarts(US), but that is mixing measurement systems.
    #21
  2. jagec
    jagec Been here awhile
    Aug 21, 2006
    417
    So basically you can coast in gear with the engine off, but don't you dare put it in neutral or pull in the clutch on a long downhill with the engine off.
    Of course, for a modern FI bike, coasting in gear with the engine off uses EXACTLY as much gas as coasting in gear with the engine on. So basically, don't turn your engine off when the bike is moving on a BMW.
    #22
  3. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,427
    Penticton, BC, Canada
    So, what are the numbers coming in at for average mileage? Just curious....
    #23
  4. WoodWorks
    WoodWorks House Ape
    Feb 11, 2003
    3,001
    Ashland, OR, USA
    Seven fill ups so far, all sorts of speeds, terrain, etc: 52 mpg. That's US gallons, BTW.
    David
    #24
  5. spoof
    spoof on backwards
    Oct 21, 2003
    315
    Santa Fe, NM
    You all are confusing me. Can someone clarify the dry sump transmission issue? I understand that the oil pump runs when the motor runs, but why would neutral be a problem? Are you saying that the oil pump is run off of the tranny rather than, say, the crank? But still---isn't the transmission entirely disengaged and not moving when neutral is selected? Why it need lubrication at that point?
    Does this really mean that say, you can't get a tow out of the woods behind your buddy or something? Makes no sense.
    #25
  6. jagec
    Aug 21, 2006
    417
    In a nutshell: if the transmission is moving and the engine ain't, bad things will happen eventually. Idling in neutral is fine, but the transmission is still moving even when no gear is selected...so if you gotta tow the bike out of the woods, put it in top gear and take it easy.
    #26
  7. spoof
    spoof on backwards
    Oct 21, 2003
    315
    Santa Fe, NM
    Thanks...
    And, not to continue hijacking this riveting thread about faux MPG, but I guess I'm trying to understand what drives the oil pump as a way of grokking the situation.
    #27
  8. grandpa_ken
    grandpa_ken Been here awhile Supporter
    Jan 13, 2008
    250
    Archer Lodge & Sneads Ferry, NC
    57 MPG for daily commutes over 50 miles city and country roads.
    #28
  9. Skippii
    Skippii Milkshakes, my lad.
    May 11, 2008
    6,686
    Richmond, Va
    But if the engine is running in neutral, the oil is pumping.
    Coasting down a slope in neutral means the oil is pumping.
    Coasting down a slope with the engine off means no oil.
    I don't understand why running in neutral could be a bad thing (as far as the engine is concerned--rider safety is another issue).
    #29
  10. Skippii
    May 11, 2008
    6,686
    Richmond, Va
    The pump runs of the crank, not the tranny. Otherwise, if we warmed up our bike for a minute or two before riding it like we're supposed to, we'd all have seized engines before we even got on the bike.
    #30
  11. spoof
    spoof on backwards
    Oct 21, 2003
    315
    Santa Fe, NM
    Right. So why would it make a difference whether the bike is in high gear or neutral?
    Oh, and I just picked min up...can't say the mileage. I think it must be around 1000
    #31
  12. eakins
    eakins Butler Maps
    May 29, 2002
    38,668
    Fort Collins, Colorado
    people realize that and are joking...only your the one who missed the joke.
    #32
  13. Skippii
    May 11, 2008
    6,686
    Richmond, Va
    I can't imagine why you'd want to do it in high gear. If the bike will run, why are you towing it?
    #33
  14. Professor Badass
    Professor Badass ROTC Special Forces
    Dec 25, 2006
    142
    Abilene, Texas
    1 US Gallon = 128 fluid oz
    #34
  15. priller
    priller -
    Dec 9, 2004
    2,988
    wetlands, PL
    we have different octans here (at least in my neck of the woods). high caloric 98 and 95 are standard - no 91, 87, not to mention 85. therefore gas here is more caloric. i didn't carefully checked my bike yet but i seem to get slightly better milage on my fj cruiser. that said, i bet manufacturers set efi specifically for every market.
    #35
  16. spoof
    spoof on backwards
    Oct 21, 2003
    315
    Santa Fe, NM
    Obviously I'm not going to tow a running bike anywhere. This thread is the first I heard of this and it made me curious about when it might present a problem. I figured if something happened to prevent the bike from running when I was in the middle of the sticks, I might want to hook up my towdowns to a friend and have him pull me out (that's why I carry the towdowns, right?).
    Here's what it says exactly in the manual:
    Transmission lubrication is only ensured when the engine is running. Insufficient lubrication can lead to transmission damage.
    Do not allow the motorcycle to roll for longer periods or push it over longer distances with the engine switched off.
    My dealer hadn't really considered this. The tech dept. had a little conference when I inquired and they responded that it was OK to push/tow the bike for a few hundred yards. More than that, don't do it.
    On topic: Haven't even been through a tank yet in the 28 hours I've had the bike (slacker, I know)...so I can only confirm that mileage appears--thus far--to be infinite.
    #36
  17. robhar54
    robhar54 Been here awhile
    Jan 14, 2006
    476
    Seattle, WA
    HUH. That's good information, thanks. Guess I'd better read the rest of my manual...! It does seems like a limitation on an adventure bike. I've never actually used my tow-downs...but I do carry 'em with me. I guess the design assumption here is that the F800GS won't break down...
    Rob in Seattle
    #37
