1967 Bridgestone 350 GTR
Discussion in 'Some Assembly Required' started by Fast Idle, Sep 17, 2018.
  1. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    2,695
    The Great Land
    Now that the Z1B is finished it's time to see about fixing up the old Bridgestone 350 GTR.
    A friend of mine had called earlier this year and said his neighbor had the bike and that it needed a new home. The guy wanted the bike to go to someone that would hopefully fix it. We went and picked it up a few days later.
    The story is that it was his Dad's bike since new. At some point the bike was wrecked and a second bike entered the picture. So the bike was now a mix of parts between the street model GTR and the scrambler version GTO. And there were also retrofit Honda turn signals and a period correct sissy bar. :photog
    The rest of the parts were in boxes. Almost a second bike's worth of parts but no scrambler exhaust.
    RCmoto, nuggets, JagLite and 5 others like this.
  2. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    I had just started the Z1 build back then and had parts scattered across the shop. I looked the Bridgestone over a bit but then put everything away to get it out of the way.
    Now the bike and all the other parts and pieces are back in the shop.
    I need to look over everything real good and see what's what. Only have the tittle to one bike, the GTR. So the plan is to sort though all the parts and pieces and use the best ones to bring back a running 1967 Bridgestone 350 GTR.
  3. Rick4003
    Rick4003 Adventurer
    Apr 17, 2012
    94
    Denmark
    Woo-hoo! It is started already! Definitely subscribing to this!
    Shame that the scrambler exhaust missing. I can't imagine it would be easy to get hold off. Is there enough parts to be able to fix the second bike too? Maybe you could fabricate a new scrambler exhaust. We know you do exhaust too you know
    Will it be a full on restoration or will you keep the original paint work and so on, full mechanical restoration with original paint and other salvageable parts?
    Looking forward to following along
    -Ulrik
    Sent from my SM-A520F using Tapatalk
  4. Rick4003
    Rick4003 Adventurer
    Apr 17, 2012
    94
    Denmark
    How difficult would it be to get a title for the GTR?
    rhino2481 likes this.
  5. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    Good questions Ulrik. I wish the scrambler pipes came with it too. I kind of like the look. I haven't decided exactly which way to go yet on this bike. On one hand it is a somewhat rare bike with less than 10,000 ever made. And the 350 GTR was the most desired of all the Bridgestone motorcycles.
    On the other hand I don't want to put more into the bike than it would be worth. I need to dig deeper into it and see just what it needs to get restored including price and availability of the parts. I will definitely try and use every decent part on hand. It may not be a complete, like new restoration but I think it will come back as a pretty nice survivor.
    The GTR may be a future possibility with or without a tittle but right now there just aren't enough good parts in the pile.
    edit, meant the GTO might be a future possibility.
    JagLite, DRZ RIDER, 3legs and 3 others like this.
  6. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    First up is sorting the GTO from the GTR parts starting with the frame. Bridgestone used 3 identification numbers on all their motorcycles. There are the usual engine and frame numbers, with an additional Vehicle Serial Number on a separate plate riveted to the frame (the actual VIN). This assembled bike has frame serial number NA1-07432. The NA1 prefix means it is a 350 part.
    The engine is serial number NA1-07629
    According to sources on the web the numbers were usually within 200 or 300 of each other so this looks to be the GTO frame with the original engine. There is no VIN tag for this bike but the numbers indicate it's a late 1969 or early 1970 bike. That would be towards the end of the production run.
    Now the cool thing is that the GTR tittle and tag are for VIN number 21Q00037. Yep, the 37th Bridgestone 350 GTR to roll off the assembly line!
    21 indicates it's a 350 and Q is the month code for May. This bike was made in May of 1967.
    And the frame is S/N NA1-00038. Now that's within 200 or 300.:photog
    JagLite and cyclonebergy like this.
  7. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    The GTR engine is a complete basket case. The case halves and a few boxes of parts.
    Amazingly it is S/N NA1-00023.
    First thought was to build up one engine from two using the early cases but there is a small problem.:becca
    There seems to be a chunk missing from the lower case half.
    So unless someone knows of a magical case repair outfit it looks like she'll come back with the late model engine.:(
    JagLite likes this.
  8. jays100
    jays100 Been here awhile
    Aug 1, 2006
    363
    CT
    Ebay occasionally has reasonably offered bare 350 cases, so there could be some hope for a 2nd engine. You should be aware that the crank halves aren't splined or timed in any way so if you replace the center bearings (like for instance, if the crankshaft perchance needs a rebuild), a special tool is needed for reassembly to factory specs.
    #8
    Fast Idle likes this.
  9. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    2,007
    Flaw'da
    There are quite a few places that can rebuild the crank as long as rods are available that fit. It may be that they used a generic rod common to more than one make.
    #9
  10. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    2,012
    Adelaide,South Oz
    Looks like you may have the oldest surviving Bridgestone in the world. Would be nice to confirm that.
    #10
  11. r60man
    r60man Long timer
    Mar 14, 2013
    1,913
    Robesonia PA
    Yay a new bike to cheer on the restoration of! :clap:clap:clap:clap
    #11
    zzzak, more koolaid and Fast Idle like this.
  12. Scrivens
    Scrivens Long timer
    Jun 5, 2011
    1,251
    usually the garage
    Aagh. I put this in the wrong thread by accident first off. Dug around in my old bike mags for this from Two Wheels #3 late '67 - I've never forgotten the photo because of the size of the two men. Reminds me of the old joke about 50lb Japanese test riders.
    #12
  13. Blakebird
    Blakebird r-u-n-n-o-f-t
    Feb 7, 2004
    28,452
    Parker, CO
    I had a '67 X6 Hustler with the scrambler pipes - grew up on two strokes in the late 60's.
    This thread will be every bit as fun to watch as the Z1B build was :nod
    #13
    Phoenix101 and Fast Idle like this.
  14. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,723
    Beautiful Revelstoke BC
    Nice project! If you decide to get rid of the scrambler bars I’d be interested in them for my CL450 project.
    #14
  15. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    Looks like there are enough decent parts between the two bikes to bring one back. Some parts are pretty rough but should be repairable. Other parts are missing all together but should be available. This is going to be a different kind of build since the "parts bike" is going to be the one getting restored and the complete bike becomes the parts bike. The GTR frame has a bent exhaust hanger on the right side but looks real good other than that.
    The shift shaft is completely stripped on the complete engine.
    Fortunately the other one looks great.
    Bridgestone made these bikes to be either left or right shift depending on their destination. The shaft ran through the gearbox to both sides and the frame had brake peddle and brake switch fittings on both sides. You can see the right cover has been repaired where the brake pedal punched a hole in it. There are torch marks on the peddle where it was straightened.
    #15
  16. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    Cool photo. It goes to show that the 350 was not a small frame bike. It was real apparent when I first got the bike. With 19" wheels front and rear on a full size frame it feels like a much bigger bike. The frame is also heavily made. I swear it feels heavier than the Z1 frame.
    The shorter guy in that photo looks like he'd be on his tip toes to ride it.
    #16
    JagLite likes this.
  17. fast1075
    Dec 28, 2013
    2,007
    Flaw'da
    I'm glad you have a good shift shaft. I did a rebuild once that required that the stripped shift be repaired since the owner absolutely would not allow a new replacement, which ironically was available. I sent the shift shaft and shifter to my machinist, where they were welded up, re-splined, and sent to the plater to be re-plated. He got to keep his original parts for the paltry some of $400.00. NOS parts still in the Honda bag would have cost around $110.00.
    And I'll bet that after being Fast Idled, that damaged cover will look new. Is that welded or epoxied?
    From the looks of that shift shaft, it got the "vice grips will work fine in place of the shifter" job.
    #17
  18. Fast Idle
    Nov 9, 2012
    2,695
    The Great Land
    That's crazy.
    The cover is welded. Might clean up pretty decent. Sure hope so because this is what the second set of covers look like.
    And yes, the old vice grip trick! :photog
    #18
    nuggets, JagLite and jays100 like this.
  19. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    What you're not going to cast new cases?
    After buying the pre-painted bodywork you've gotten really lazy:jack
    #19
  20. anonny
    Mar 20, 2007
    6,723
    I had a set of aluminum Norton covers welded, after hours of polishing and buffing it blended in pretty nice.
    #20
