1967 Bridgestone 350 GTR
Discussion in 'Some Assembly Required' started by Fast Idle, Sep 17, 2018.
  1. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    2,013
    Adelaide,South Oz
    Now you're just showing off Steve (i'm just jealous) :lol3:lol3:lol3
    Fast Idle likes this.
  2. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    2,696
    The Great Land
    Time to unlace the wheels so the hubs can get cleaned up and polished.
    The rims are nice but the hubs definitely need some attention.
    Looks like the nipples were actually yellow. They appeared to be clear zinc on the outside.
    Only two rusted ones. Next to the valve stem where water must have gotten in. Other than that there's just some surface rust that should blast away.
    DRZ RIDER and JagLite like this.
  3. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Rear wheel is first up.
    And then the front.
    BillUA, DRZ RIDER, jays100 and 2 others like this.
  4. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Started cleaning the fenders to remove the layers of mud and dirt from underneath.
    Got through the mud and realized there was some sort of rubber undercoating. Never ran across that before. Is this factory? I'm thinking it is.
    Same on the rear fender. Well preserved. Just a little bit of surface rust. Cool!
    Most of the undercoating peeled up with soda blasting. I'll blast it some more and finish it up.
    JagLite and BillUA like this.
  5. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,084
    Long Beach, California
    Is your soda blaster a cabinet style or the non recoverable/outdoors ?
  6. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Outdoors!
    Just and old cheap siphon feed blaster. Works pretty good but I have to kick or shake the hopper now and then to keep the soda flowing.
    JagLite, Blakebird and Kai Ju like this.
  7. RickS
    RickS Long timer Supporter
    Dec 12, 2006
    1,619
    Altus, OK
    I bought me a soda blaster Last night to see what it will do on my 450. What pressure you running?
  8. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Around 70-80 seems to work good.
    Deadguyale and RickS like this.
  9. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Not all the NOS Bridgestone parts out there still look new. This rear sprocket was all I could find.
    She's not real pretty but she's got nice teeth! :photog
    It will need to be stripped to bare steel and re-plated.
    All of the cables are in pretty rough condition. The only NOS cables I could find were the tach and speedo, the rest will have to be rebuilt.
    BillUA and JagLite like this.
  10. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Been polishing the aluminum parts up one by one. Bead blasted the top tree and then started wet sanding.
    Shiny fresh metal starts showing up.
    And eventually it gets polished. A beautiful alloy and casting from 1967 lives on to look new again.
    zzzak, Pezz_gs, BillUA and 7 others like this.
  11. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,105
    Saranac,MI
    Have you considered vapor blasting for a step in the polishing?
  12. braindead0
    braindead0 Head Fisherman
    Oct 4, 2007
    1,697
    Reno, NV
    I'd be considering hiring day laborers ;-)
    Fast Idle and more koolaid like this.
  13. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    2,007
    Flaw'da
    More parts sent thru the will be was machine. How many gigajoules does it take to run that thing? You transported that top tree to seconds after it came off the buffer.
  14. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,385
    Anchorage, formerly Spenard (hub of the universe)
    I'm sure you know Flanders but here a link for other old schoolers
    http://www.flanderscables.com/
    I remember when I found out that cables were bike specific. walked into a certain motorcycle shop and asked for a clutch cable. "what bike".... hey, just a regular clutch cable. "I gotta know what bike"... ok.. Bultaco model 85, 1972-3. I might as well have asked for fresh weasel meat
  15. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,362
    Oakland, CA
    I know a guy who knows a guy...
    Kai Ju and Richarde1605 like this.
  16. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    I have not. Mostly because I have a bead blast cabinet and don't have a slurry blast cabinet. :photog
    In fact there are no vapor blasting outfits in the state that I am aware of.
    Sure would be nice to have wet blast cabinet but they are kind of spendy.
    JagLite and Bt10 like this.
  17. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Finished up on the rear shocks yesterday. I had originally soda blasted the best looking 2 out of the 4. Then I noticed a slight difference between the two sets. All the same dimentionally but I had picked a mismatched set.
    They needed to come apart anyway to finish cleaning and remove the baking soda from under the covers. That's one of the things about soda blasting. It will find it's way into any opening.
    I took them all apart to select the best pieces and have a matched set. A strip of inner tube and an oil filter wrench worked great for removing the upper eye and cover.
    The upper cover is threaded so it's a jam nut for the eye.
    DSC00064.JPG Now the shocks can also be checked for dampning.
  18. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Cleaned up all the best parts and bead blasted the top eyes too.
    Ready for reassembly.
    Good to go.
  19. Kaw4Life
    Kaw4Life Long timer
    Sep 27, 2008
    8,705
    Earth
    Is the goal here the same as the 900, to keep all factory?
  20. Fast Idle
    Nov 9, 2012
    2,696
    The Great Land
    Yes
    Unless by some miracle a set of expansion chambers from one of these old race bikes shows up! :evil
    Phoenix101, wmfleet2, Beezer and 7 others like this.
