1968 Royal Enfield Interceptor barn find
Discussion in 'Some Assembly Required' started by Fast Idle, Sep 3, 2016.
  1. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    2,285
    The Great Land
    Well it looks like I've found this winters project! Can't believe I stumbled onto this during our annual fall bike trip around the state. Aired up the tires and rolled her onto the sag wagon. The front brake even worked! Last registered 24 years ago, came with tittle, tag and workshop manual. :happay
    Initial inspection looks good. The engine had fairly clean oil inside and it turns over with good compression This will be a fun build. I think she'll come back as a period custom because stock is boring. Would look cool to ride her as is too!
    :rayof
  2. usgser
    usgser Long timer
    Nov 6, 2005
    3,382
    Westside WA
    Sweet. Super simple old school tech bike to work on. Get'r running good and go ride the wheels off her.
    pennswoodsed and Kiba like this.
  3. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    Yes, never had one of these before but it does look really basic. Shares some parts with other British bikes of the era so I already have some spares for it. Maybe just a mild custom will be in order. I want to see if I can get it running before any major work. I have to clean out the gas tank first and see if it will hold gas.
    I like what this guy did with his 68.
    highnoonhunter, JagLite and oldfartrr like this.
  4. Foxed101
    Foxed101 Monkeywrench
    Aug 1, 2015
    444
    Holland
    Great find! Looks awesome as is!
    You can tell the bike has character.
    "So what if I was stowed away a quarter century ago? I'm about as ready as I ever was!":ricky
    JagLite, GR0NK and Fast Idle like this.
  5. huub
    huub Been here awhile
    May 11, 2012
    450
    wow , nice find!
    those are completely unobtainable over here!
    i am jealous, a interceptor and a kawa H2!
    Fast Idle likes this.
  6. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,013
    Reading,Pa
    I would keep it much the same as you found it , trials tires , solo seat and trail bars !
    Just wash lube and ride !
    shinyribs, victor441, JagLite and 2 others like this.
  7. kraven
    kraven Hegelian Scum
    Jul 7, 2005
    5,475
    Asheville NC
    You are reallllly lucky all the bits are there. I have a 56' Indian Trailblazer (RE Meteor rebadged) that was missing the engine and trans and bits here and there. It's been a gatdang slog to try and get those parts and figure out how they go together when I didn't disassemble it.
    Lucky lucky duck, you are.
  8. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    Seems that whenever I think all the barn finds have been found, something shows up. Definitely tempted to service everything and then ride her as is. One thing I've learned about finding old bikes like this is that they were all usually parked for a reason. I just need to find it and fix it. Hell, maybe I'll get lucky and it will be something simple! I'll need a stock taillight/license bracket for sure because I want it street legal. I plan to change all the fluids today and then start in on the carbs and electrical. I've heard these bikes sound really cool.:1drink
    #8
    JagLite likes this.
  9. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    I hear you for sure. I can't believe how complete this bike is, it's not missing much. Have you finally found all the parts for the Trailblazer? It does seem to be slim pickings for parts on these bikes. Everything I've been seeing is overseas.
    #9
  10. kraven
    Jul 7, 2005
    5,475
    Asheville NC
    They do sound really cool.
    You are right. They do get parked for a reason. They also were made with a lot of shit quality parts, so things break and shear off and strip on the regular. They're neat time capsules though.
    #10
  11. kraven
    Jul 7, 2005
    5,475
    Asheville NC
    Nah, I'm still looking for a complete engine and trans that's not astronomical. Everyone who has them seems to want to sell them one bolt or nut or component at a time, not as a unit. And the Indian parts (side covers with Indian logo, speedo, etc) are getting hard to find in good useable states. Lots of crap floating around out there. I'm not in a hurry. My impetus is to get it into rolling chassis state, and I might just use a new lean burn 500 RE mill or an XS650 engine in it. The Pre-Unit 700cc stuff is pricey.
    The RE club will ID your bike for you and give you production date and whatnot, if you contact them.
    #11
    oldfartrr likes this.
  12. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    Thanks, I'll contact them and see what they come up with.
    #12
  13. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    Inspected the cylinders as best as could through the plug holes. No sign of rust and the valve faces looked good. Dry compression test showed 130 psi on both cylinders so that's looking good.
    Test light hooked straight to the stator leads glowed bright when kicking over. I'll be dang, an old stator from " LUCAS, the Prince of Darkness" still works!
    Went through the carbs and they looked really good for almost 50 years old. The original brass cleaned up great !
    A quick round of soda blasting and detergent washing have them looking good.
    Should get them finished tomorrow and back on the bike.
    #13
  14. Lounge
    Lounge Been here awhile
    Jul 2, 2010
    910
    COS
    Dig the banjo bolts and hard lines for top end oiling.... I'm guessing that's what they're for??
    :lurk
    #14
  15. usgser
    usgser Long timer
    Nov 6, 2005
    3,382
    Westside WA
    That would be my plan. Beautiful "period piece". Enjoy it for what it is.
    #15
  16. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    They replied right away, cool.
    "Your Interceptor Mk.1A was dispatched from Bradford upon Avon on the 16th January 1968 destined for Cooper Motors of Los Angeles. Specification states “Scrambler, Chrome with Red Stripe”.
    #16
    JagLite, brucifer and kraven like this.
  17. Fast Idle
    Nov 9, 2012
    2,285
    The Great Land
    Finished the carbs today and reinstalled. I did a temporary patch on the already patched up wiring and hung a 2MC capacitor to see if she would make spark. Nice hot spark on both sides!
    Didn't have to touch the points, could not believe how clean it was in the distributor. The advance was free too. Will revisit after I get it running and check the timing.
    Cleaned the oil filter and oil pump screens. They all looked good with no signs of metal. Added fresh lube to engine and gearbox. Will button up the primary tomorrow.
    I need to pull the rocker covers and pre-lube the valve train as well as check the valve clearances. The first round of gas tank cleaning is done and there are no leaks!
    This bike is not that far from being ready for a start attempt.
    #17
  18. duckman
    duckman co conspirator
    Feb 1, 2005
    1,139
    Corova milk bar
    don't pimp that ride , its beautiful as is
    #18
  19. Solarmoose
    Solarmoose electric Supporter
    Sep 9, 2009
    1,060
    Fairbanks
    Actually I think it was in Paul's shed, calling it a barn would be generous.
    BTW, I looked at two CBX's for sale this week. Both rough but mostly complete,
    I think I'll make an offer and see what happens.
    So the Interceptor left as a scrambler? Wonder the diff between it and the Sports model?
    I met the owner of this one at Norton Rally in Lumby BC. Beautiful bike and wonderful sound.
    http://www.motorcycleclassics.com/classic-british-motorcycles/1968-royal-enfield-interceptor.aspx
    You didn't waste any time getting started...
    #19
  20. Golden955
    Golden955 Been here awhile
    Jul 28, 2016
    147
    Subscribed, can't wait to see this bike running.
    #20
