1972 CB350F... Cliche Cafe/Brat Build
Discussion in 'Some Assembly Required' started by TheGr8Pumpkin, Jul 25, 2017.
  1. Andyvh1959
    Andyvh1959 Cheesehead Klompen Supporter
    Feb 16, 2012
    3,258
    Da frozen tundra eh? 1.5 mile west of Lambeau
    Could be the o-rings Honda used to seal the oil galleys running up through the cylinder/block up to the head. Honda-4s rely on fairly high system pressure to deliver enough oil to the the cam carriers. Standard nitrile/Buna-n o-rings are only good for a bit over 200 degrees F. Those Hondas could run quite hot, and once the o-rings get over-heated to take a thermal "set" they would seal as effectively. Would be worthwhile to upgrade the o-rings to high temp silicon seals.
    #21
    TheGr8Pumpkin likes this.
  2. TheGr8Pumpkin
    TheGr8Pumpkin Been here awhile
    Oct 8, 2014
    100
    Atlanta, GA
    Well... now that the school year has begun, the build has slowed down a little bit. Once I paint the frame, I will be able to start rebuilding. I'm not exactly sure when the frame will be ready for paint though. There is still a good bit of sanding and prep work that needs to be done. Here are all the other parts that I have painted. The light cluster needs a wet sand and Im waiting to clear coat the front fender until I clear coat the tank so that I only have to mess with the spray max 2k once.
    #22
    shinyribs likes this.
  3. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    I'm not sure yet what I will do with the engine. The bike was put away with only 7K on the odometer. So, I'm hoping the engine isn't in too bad of shape. I'm thinking that replacing all the gaskets should be enough, but there is no telling until I tear into it.
    #23
  4. Pezz_gs
    Pezz_gs Cant ride for crap
    Nov 13, 2004
    5,017
    Sydney Skunkworks
    The best thing I did with my XR460/4 (CB400/4) was to fit a Dyna ignition system :thumb
    #24
  5. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Very cool build! I will have to keep the Dyna ignition in mind.
    #25
  6. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Finally got the frame cleaned up and painted after some help from the new garage assistant. IMG_9814.jpg
    Painted the forks, but forgot to take the after picture. In a couple weeks I should be putting stuff back together.
    #26
    ADVBedouin and Pezz_gs like this.
  7. Ghengis o reilly
    Ghengis o reilly Adventurer
    Aug 3, 2016
    12
    Looking forward to seeing finished result :1drink
    #27
  8. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Well, I got moved to the second forum page, so I figured it was time to do a little bit of work. I cleaned up some rusty parts: screws, swing arm bolt, etc... and now I have attached the center stand, swing arm, and bottom triple tree. I was planning on putting on the top triple tree, but the threads on the steering head nut were so rusty that they dissolved away in vinegar. A new nut has been ordered... I've been itching to get back to work on this thing so I actually brought it to my apartment at law school ha. bike apartment 1.jpg
    #28
  9. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    2,360
    Ventura, CA
    Looks good!
    I used coca-cola to remove the rust on my hardware when I was restoring my Triumph. Worked great. Didn't work really fast though.
    #29
  10. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Got the new steering stem nut in with some other parts. Pretty interesting to see just how much damage rust can do. IMG_0041.jpg IMG_0042.jpg IMG_0043.jpg IMG_0044.jpg
    #30
  11. Ghengis o reilly
    Aug 3, 2016
    12
    Looking good :1drink
    #31
  12. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Attached the front forks, rear shocks, seat and seat pan, and picked up some handle bars from cycle gear. I'll definitely be switching out the rear shocks at some point, but that will probably be after the bike is finished.
    Does anyone have any tips for taking that dent out? a little too big to use bondo I think.
    Also, started looking at the engine and the left cover is completed rusted onto the shifter rod. I've tried pb blaster, heat, and even muriatic acid to try and get it off, but none of it has worked.
    #32
  13. Todd157k
    Aug 14, 2012
    2,360
    Ventura, CA
    #33
  14. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Here's a bit of an update. I've finished the tank and have a fairly good rolling frame set up. Carb cleaning will be coming up next.
    IMG_0927.jpg IMG_0928.jpg IMG_0929.jpg IMG_0930.jpg Here's a bit of an update. I've finished the tank and have a fairly good rolling frame set up. Carb cleaning will be coming up next.
    #34
  15. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
  16. Ghengis o reilly
    Aug 3, 2016
    12
    Awesome work, keep us updated:clap
    #36
  17. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    So, one of the spark plugs got rust fused into the head and a couple other parts of the motor are toast including the head. At this point im considering an entire motor swap. Seeing as CB350Four motors aren't that easy to come by, now taking suggestions for an interesting motor to swap in. obviously any regular CB motor would be fairly easy, but im down to make things interesting.
    #37
  18. Pezz_gs
    Nov 13, 2004
    5,017
    Sydney Skunkworks
    #38
  19. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,602
    Beautiful Revelstoke BC
    Looking good, keep it up
    #39
  20. Pezz_gs
    Nov 13, 2004
    5,017
    Sydney Skunkworks
    Any updates . . . . . . :ear
    #40
