1972 CB350F... Cliche Cafe/Brat Build
Discussion in 'Some Assembly Required' started by TheGr8Pumpkin, Jul 25, 2017.
  1. everready
    everready Stuck in Ohio....Ugh!!!
    Jul 1, 2013
    3,127
    Macedonia, Ohio
    Well then it sounds to me that fuel isn't getting to #4 carb. The carb lets the starter fluid go by, right? Can you hook up a secondary fuel source to carb #4?
    #61
  2. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,164
    Arizona, Alaska
    If there is fuel in the bowl, and it is not getting into the airflow in the carb. The problem is between these points.
    Sounds like a blocked passage to me.
    Don
    #62
  3. TheGr8Pumpkin
    TheGr8Pumpkin Been here awhile
    Oct 8, 2014
    100
    Atlanta, GA
    Yup!
    It was a blocked slow jet. I thought I cleaned that passage and put in a new jet. Turns out I did the number one carb twice...
    Just a matter of buttoning everything back up and the bike is ready to go and firing on all cylinders!
    #63
  4. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    Took a test ride today and everything went pretty well. Seems that the power comes on pretty high in the rev right about 5,000 6,000 anybody ridden one of these before and know if thats fairly normal?
    #64
  5. Cogswell
    Cogswell Trying to live the new normal.
    Jan 3, 2005
    9,055
    Riding with my pal Richard Cranium
    Yes, that's about normal. They never did make a whole lot of power and you did need to wring the motor out pretty good to get it.
    What did you end up doing regarding airbox/air filter ?
    #65
    TheGr8Pumpkin likes this.
  6. TheGr8Pumpkin
    Oct 8, 2014
    100
    Atlanta, GA
    I used UNI foam pods. Seem to work fairly well. Went up to a #98 main jet.
    #66
    Cogswell likes this.
