1974 CB550 KO Restoration Project
Discussion in 'Old's Cool' started by tom c, Aug 14, 2019.
  1. Cycle Goon
    Cycle Goon Been here awhile
    Sep 16, 2016
    826
    I think it looked better in monochromatic blue....
    #81
    KeithTurk likes this.
  2. OU812
    OU812 Legend in my own Mind! Supporter
    Sep 18, 2006
    21,718
    Sleepy Hollow IL
    Blasphemy!!!!;)
    #82
  3. tom c
    tom c Teflon Tommy Supporter
    May 21, 2012
    8,301
    Delaware
    :fpalm
    #83
    OU812 likes this.
  4. Cycle Goon
    Sep 16, 2016
    826
    Please tell me you knew I was kidding
    #84
    OU812 likes this.
  5. tom c
    May 21, 2012
    8,301
    Delaware
    @Cycle Goon , I knew you were joking :)
    The chrome tank trim arrived yesterday, it just makes the awesome tank look even more awesome:
    #85
    FLGSARider, Laconic, UstaKood and 4 others like this.
  6. Cycle Goon
    Sep 16, 2016
    826
    Glad your sarcasm detector is functioning properly. Tank looks FANTASTIC!! Whomever painted that laid down some great results
    #86
    OU812 likes this.
  7. OU812
    Sep 18, 2006
    21,718
    Sleepy Hollow IL
    I'm starting to want this.
    #87
    tom c likes this.
  8. Fearless
    Fearless Brutally Honest Supporter
    Oct 8, 2010
    1,312
    'round Atlanta
    And so, your addiction begins..... Tom is just an enabler.
    I remember my first "that'd be cool to have" moment. Now look at me
    #88
    Al Tuna, tom c, goosecreek and 2 others like this.
  9. CCitis
    CCitis Been here awhile
    Jan 13, 2013
    935
    Beautiful BC
    Fantastic, fueling my want for a project... although my mechanical skills lack to say the least. What is the process/product you use to get such a good polish on the metal? Looks great.
    #89
  10. goosecreek
    goosecreek Ashes ashes all fall down Supporter
    May 25, 2010
    7,690
    One foot out the door.
    It is incredible the wheels on my ct90 looked like junk when he got the bike.
    Oh and man it runs great, it started yesterday when my 1150 would not.
    #90
    knybanjo and OU812 like this.
  11. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    447
    Michigan
    I kind of like that color too ! :jkam
    Nice work ! :thumbup
    #91
  12. tom c
    May 21, 2012
    8,301
    Delaware
    The last step is to use this stuff:
    The chrome usually cleans up good with WD40 applied to a 0000 steel wool pad.
    The aluminum parts usually have some kind of a clear coat on them that must be removed with a good paint stripper before you start sanding with progressively finer grits of sandpaper from 400 - 2000 grit. Lots of elbow grease. Then the final polish is using a 6" cloth wheel with White Diamond.
    In the past I've used a fine crimped wire wheel as a first step after stripping any remaining clear coat. This can easily be overdone, resulting in gouge marks that have to be removed with coarser grit sandpaper.
    #92
    Fearless, Dynamick, knybanjo and 2 others like this.
  13. CCitis
    Jan 13, 2013
    935
    Beautiful BC
    Vanilla scented! Sold. Thanks for that.
    #93
  14. tom c
    May 21, 2012
    8,301
    Delaware
    With regards to engine work, the current plan is to send out the head, intake manifolds and cylinders for Hondaman, to work his magic on. Hondaman, AKA Mark Paris, is the author of this book:
    and somewhat of a celebrity in the SOHC/4 community. In my communications with Mark, he explained to me that intake restrictions are the most significant performance restriction in the SOHC 500/550 motors. The best way to improve the breathing to port the head and intake manifolds, slow down the spark curve rate and change out the OEM cam for one with longer duration. Mark recommended the Megacycle 126-00 or 126-01 because it is longer in duration with lift similar to stock which increases flow and performance without putting more stress on the valve train. The Megacycle cams are not cheap ($450) but in Mark's opinion they are worth it.
    I got extremely lucky last week - Just before getting in touch with MegaCycle to place my order, My daily search on ebay (CB550, used, Honda) popped up with a Megacycle 126-01 cam selling for $125 including shipping! I snapped it up immediately. It has arrived in perfect condition with the original box including installation instructions, timing card and a small container of Red Line Assembly Lube!
    Now that is a pretty good deal! Before I install this cam I'll have the top end work done by Mark.
    I also found a NOS Connecticut Luggage rack for the 550 upon which I can mount the Arthur Fulmer top box:
    While it mostly fits, it seems to be for an older model CB550 because the mounting holes to attach it to the grab bar are not in the proper location for my 74:
    I think that I can remedy this however, using a corner bracket of some sort.
    Here's the top box sitting on the rack - not yet hard mounted.
    Lots more left to do!
    #94
    Cogswell, weldingrod, thewbee and 5 others like this.
  15. OU812
    Sep 18, 2006
    21,718
    Sleepy Hollow IL
    I think its going above my income...:)
    #95
  16. KeithTurk
    KeithTurk Been here awhile
    Feb 4, 2008
    896
    South east corner of lower Alabama
    #96
    OU812 likes this.
  17. tom c
    May 21, 2012
    8,301
    Delaware
    #97
    KeithTurk and OU812 like this.
  18. Cycle Goon
    Sep 16, 2016
    826
    I'd start with removing that atrocity directly behind the seat and that hideous thing adorning it. It absolutely kills the lines of an otherwise beautiful bike
    #98
  19. Al Tuna
    Al Tuna NSFW
    Nov 24, 2006
    24,863
    Moran Nation
    Don't judge the ass until you've seen the boobs.
    #99
    Cogswell, Fearless and OU812 like this.
  20. OU812
    Sep 18, 2006
    21,718
    Sleepy Hollow IL
    :clap
    :y0!
    :photog
