1974 Rickman
Discussion in 'Some Assembly Required' started by ZVossler, Aug 8, 2017.
  1. neil w
    neil w Been here awhile
    Jan 13, 2013
    248
    Northumberland
    Less than 2 minutes.................... JT list a 428 sprocket for the DT125 as a JTF416, searched for next size of bike capactity wise and the first one I looked at was a BW200.......... same sized output shaft but a 520 sprocket part ref JTF422 (Please double check yourself to confirm it is what you are after )
    #21
    JagLite likes this.
  2. ZVossler
    ZVossler Adventurer
    Oct 12, 2015
    15
    Western, NY
    I think the holes are spaced differently with the BW200 sprocket, that's my interpretation anyway. I did find JTF1554 to be the same measurement wise but it shows an offset, maybe that would work?
    JTF1263 would be factory 78-80 DT125F, G, H
    #22
    JagLite likes this.
  3. ZVossler
    ZVossler Adventurer
    Oct 12, 2015
    15
    Western, NY
    05C38F3D-859B-458E-8D93-9D6F1F16D33D.jpeg Local shop had a blaster sprocket and a chain on the shelf, went and scooped those up today, should work good.
    Just waiting on a new rear sprocket to arrive, then hopefully I’ll be able to line everything up to machine the spacers for the rear axle.
    Because the DT motor has taller cases than the Zundapp motor I was unable to use the original side covers. Started work on one side today. Making progress.... slowly.
    #23
    JagLite, Honda-50 and motu like this.
  4. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    618
    Carool, NSW
  5. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    3,241
    #25
    jays100 likes this.
  6. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    8,113
    Anchorage Alaska
    The stock fiberglass side panels are very easy to modify with a jig saw and grinder, or even just a file and a few minutes.
    I think they would look much better than aluminum flat panels.
    My 2c :hide
    #26
    Scoozi and Honda-50 like this.
  7. ZVossler
    ZVossler Adventurer
    Oct 12, 2015
    15
    Western, NY
    You are probably right, modifying would have been easier... but now they are on a shelf un-molested. I don't think the aluminum ones turned out too bad, though.
    #27
    Moose465, Honda-50, nickguzzi and 4 others like this.
  8. JagLite
    Jun 17, 2010
    8,113
    Anchorage Alaska
    Yes, you did a great job with the aluminum side panels. :thumb
    Fun bike! :ricky
    #28
    Honda-50, villageidiot and ZVossler like this.
  9. emti
    emti Been here awhile
    Aug 26, 2010
    364
    northern n.y.
    Nice job, Is it going to Ohio? emti
    #29
  10. ZVossler
    ZVossler Adventurer
    Oct 12, 2015
    15
    Western, NY
    That’s the plan, it will be for sale.
    I bought a pretty rough 64 BSA C-15 with a strong running motor. I would like to find another Rickman frame and body work to build another with the BSA motor.
    #30
    Moose465 likes this.
