1981 C70
Discussion in 'The Garage' started by AJs General, Sep 13, 2019.
  1. AJs General
    AJs General n00b
    Sep 13, 2019
    5
    Texas
    Hello,
    I am working on a 1981 C70 6 volt. The problems I ma having the headlight will not come on while the engine is running. The problem is the flasher will work when I turn the right turn signal on but not the left side. I can tap the flasher and it blinks on and off. What could be both of my problems? please help!!!!!!!!!!!
  2. SmittyBlackstone
    SmittyBlackstone Been here awhile
    Mar 3, 2015
    722
    Westchster County, NY
    First, check and clean ALL of the grounds and ground paths.
    Make sure the battery is perfect.
    muddywater likes this.
  3. youkiddin
    youkiddin Adventurer
    May 17, 2009
    59
    bay city,mi
    i think your headlight is ac voltage straight from the stator and all other bulbs work off the battery and the batteries don't seem to last real long . make sure the battery is good.
    SmittyBlackstone likes this.
  4. superscott
    superscott Been here awhile
    Jan 5, 2012
    127
    Uhm, should be 12 volts, could be half of your problems
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,377
    Anchorage, formerly Spenard (hub of the universe)
    nope... think its 6V DC except the headlight which is AC. the flasher or it's wire and or socket need cleaning and inspection. flasher may be bad. something is wrong with the left side signal path. start as above, clean the grounds and all connectors. get a known good battery, test the bulbs. if there is no other way switch left to right. the headlight is a separate issue.
    get the engine running and see what voltages the system makes. I don't have a diagram but the generator makes AC and some of that will go to a rectifier and regulator system, then to battery and feed the DC systems. the headlight on these bikes usually have a separate lighting coil. the tail light should be DC off the battery
  6. muddywater
    muddywater Untermenschen
    Oct 1, 2007
    2,854
    East TN
    I have an 81 and an 82.
    The 81 is 6 volt and the 82 is twelve volt.
    The headlight on the 82 runs AC and basically uses the battery load to regulate voltage (via the rectifier). Anything goes wrong with the battery or related connections and the headlight goes off like a flash bulb. The original sealed beam units are pricey too. An aftermarket reflector with a replaceable bulb is a good idea, at least till you get it sorted out. I added an aftermarket shunt(?) on the headlight made for a battery less dirt bike that is adjustable from 12 to 16 volts. It sends to ground excess voltage to the headlight.....worked well for many years.
    Honda has used a bunch of different charging and lighting systems on the underbone bikes over the years...most are simple yet have compromises in design that cause issues. Plenty of info online if you dig around... as already stated, a perfect battery and sound connections throughout eliminate most problems.
    My 81 electrical system has actually always worked pretty well except for popping every bulb on the bike if I let the battery go bad.
  7. Beezer
    Oct 26, 2004
    9,377
    interesting... no regulator on the stock bike then. I thought they abandoned that type system in the 70s like everyone else. so only a rectifier for DC, and the load (kinda) self balances due to the AC side self limiting (2 pi FL). in that case, everything must be up to par or it will crap. "aftermarket shunt(?)" regulator... yes. dumps the excess to ground. I would add one in a heart beat is that system does not have one. that, and float the stator to get maximum power (then you could run a series regulator!)
  8. AviatorTroy
    AviatorTroy Long timer
    Oct 15, 2007
    2,413
    Castle Rock, CO
    I have an 82. Yours is the last year for the 6v system. The battery is critical in these bikes. Fortunately they are cheap. Get a new battery then see how it goes. Turn signal flasher relay is an easy fix but did you check all the bulbs? Headlight I have no idea but some simple troubleshooting with a multimeter should get you there..
    #8
    muddywater and SmittyBlackstone like this.
  9. AJs General
    AJs General n00b
    Sep 13, 2019
    5
    Texas
    Ok Everyone I have it running I do have a Hot battery. I think I have bad flasher. I still don't have a headlight either low are his beam. This is a 6 volt system so the headlight is going to be AC volts is that correct?
    #9
  10. muddywater
    Oct 1, 2007
    2,854
    East TN
    The yellow wire leaving the alternator (coil on right side in pic) goes to the dimmer switch, then the hi and low headlight filament...it is AC.
    With an ohmmeter,
    Check your filaments in your head light.
    Check for output from your lighting coil/yellow wire when running... use AC setting... probably will be 25 or 30 volts with no headlight load.
    Seems like you can bridge your flasher relay, and the turnsignal will come on and not blink, or it will come on and not blink as is.... depends on your flasher failure mode.
    #10
  11. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,083
    Kentucky-Eastern that is!
    And of course the model year, as titled, can vary according to date of sale.
    FWIW, I remade the HL on my 6v 70's Honda by silicone-ing a new 6v bulb into the back hole (I created by removal of a bad bulb) in the old HL unit which had the permanent bulb in the unit originally.
    #11
  12. AJs General
    AJs General n00b
    Sep 13, 2019
    5
    Texas
    Hello,
    I am still having problems with the left turn signal. The right one works great. What else could be the problem. I have another flasher and it does the same thing. Could someone please let me know. Could I bridge the flasher and what does that mean.
    I forgot that the lights come on the back one is dimmer then the front light. the lights just stay on.
    Thank you
    #12
  13. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,799
    Hiding off Hwy 6, B.C.
    Yes asking but in the meantime did you fix anything?Headlight?
    Turn signals? Clean and check all the grounds? Start with the dim bulb?
    Turn signal switch?Clean or corroded contacts?
    #13
  14. AJs General
    AJs General n00b
    Sep 13, 2019
    5
    Texas
    Yes I have done everything went back and double checked the grounds.
    #14
  15. muddywater
    Oct 1, 2007
    2,854
    East TN
    The dim light issue is most likely a ground... 6 volt is more sensitive to clean grounds than 12 volt.
    Bridge the flasher.... just a jumper wire across the terminals....the flasher just makes and breaks the ground in most cases (have fuses handy)...
    #15
  16. AJs General
    AJs General n00b
    Sep 13, 2019
    5
    Texas
    Well I bridge the flasher and when I do that it doesn't flash any more. I will double check the grounds again to make sure.
    #16
