~~~1983 Honda XL600R Total Engine Rebuild~~~
Discussion in 'Thumpers' started by BThresher183, Jan 12, 2015.
  1. BThresher183
    BThresher183 Adventurer
    Jan 12, 2015
    34
    Hi Everyone,
    I have owned this bike since 2004, and picked it up on the side of the road for $500. Ran great when I first bought it, gobs of power. Had the top end rebuilt a few years later (new piston, cylinder bored, etc). For the past couple years, I have been dealing with a fairly severe oil leak. Unfortunately, it looks like it is coming right out of the bottom of the motor where both sides of the crankcase come together. As of right now, I have the entire motor apart, and the crank case split. Looks like it had a (paper?)-like gasket which was very disintegrated. I cannot seem to find the center crankcase gasket anywhere, except for GasketKing. Does anyone have an experience with these gaskets? A whole gasket set for the entire engine is $21, and that's why I ask. I am planning on replacing all gaskets/seals, as well as a new piston and rings when I get it back together. Possibly any other parts that are out of spec as well. Thanks!
  2. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,418
    San Francisco,Ca.
    1987 XL600 crankcase center gasket.
    I'm sure this is what you need.
    From a 1986 XL600:
    GASKET, CRANKCASE
    11191-MK2-000 11191-MN1-701
    $13.49
  3. BThresher183
    Jan 12, 2015
    34
    Ah-Ha! I never thought of searching for a different year. So the 1986 crankcase gasket WILL fit the 1983?
  4. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,418
    San Francisco,Ca.
    I'll bet ya a dollar to a donut that it will.
  5. BThresher183
    Jan 12, 2015
    34
    Haha, Ok. Looking at the schematics of both years, the pictures are identical. I would assume this would hold true for other seals and gaskets I may need. I know I have read it before, but does anyone have a list of what parts/years are interchangeable? I appreciate your help. I am going to order this gasket now.
  6. Elkster88
    Elkster88 Adventurer
    Jan 10, 2011
    50
    MN
    I would not assume the crankcase gasket from a different year will fit. Why guess? Most of the parts lookup places online can tell you what year a particular part will fit, given the part number. I looked up the crankcase gasket for a 1983 XL600R on cmsnl.com, then double checked it against partzilla.com. The two part numbers previously given do not fit the '83.
    All that said, for joining case halves, a very common practice is to use Yamabond or Three Bond gray gasket sealant.
    http://www.partzilla.com/parts/detail/honda/HP-11191-MG3-306.html
    This Honda 11191-MG3-306 GASKET, CRANKCASE is used on these models and components:
    1983 XL600R A CRANKCASE
    1983 XL600R A GASKET KIT B
    1983 XR500R A CRANKCASE 83-84
    1983 XR500R A GASKET KIT B
    1984 XL600R A CRANKCASE
    1984 XL600R A GASKET KIT B
    1984 XL600R AC CRANKCASE
    1984 XL600R AC GASKET KIT B
    1984 XR500R A CRANKCASE 83-84
    1984 XR500R A GASKET KIT B
    Description
    11191-MN1-701 GASKET,CRANKCASE
    This Honda 11191-MN1-701 GASKET,CRANKCASE is used on these models and components:
    2009 XR650L A CRANKCASE
    2009 XR650L A GASKET KIT B
    2009 XR650L AC CRANKCASE
    2009 XR650L AC GASKET KIT B
    2012 XR650L A CRANKCASE
    2012 XR650L A GASKET KIT B
    2012 XR650L AC CRANKCASE
    2012 XR650L AC GASKET KIT B
    2014 XR650L A CRANKCASE
    11191-MK2-000 GASKET, CRANKCASE
    Description
    Purchase this Honda 11191-MK2-000 GASKET, CRANKCASE --- GASKET, CRANKCASE (Honda Motorcycle Code 2002756) , GASKET, CRANKCASE (Honda Code 2002756)
    This Honda 11191-MK2-000 GASKET, CRANKCASE is used on these models and components:
    1985 XL600R A CRANKCASE
    1985 XL600R A GASKET KIT B
    1985 XL600R AC CRANKCASE
    1985 XL600R AC GASKET KIT B
    1985 XR600R A CRANKCASE
    1985 XR600R A GASKET KIT B 85-92
    1986 XL600R A CRANKCASE
    1986 XL600R A GASKET KIT B
    1986 XL600R AC CRANKCASE
    1986 XL600R AC GASKET KIT B
    1986 XR600R A CRANKCASE
    1986 XR600R A GASKET KIT B 85-92
    1987 XL600R A CRANKCASE
    1987 XL600R A GASKET KIT B
    1987 XL600R AC CRANKCASE
    1987 XL600R AC GASKET KIT B
    1987 XR600R A CRANKCASE
    1987 XR600R A GASKET KIT B 85-92
    1988 NX650 A CRANKCASE
    1988 NX650 A GASKET KIT B
    1988 NX650 AC CRANKCASE
    1988 NX650 AC GASKET KIT B
    1988 XR600R A CRANKCASE
    1988 XR600R A GASKET KIT B 85-92
    1989 GB500 A CRANKCASE
    1989 GB500 A GASTET KIT B
    1989 GB500 AC CRANKCASE
    1989 GB500 AC GASTET KIT B
    1989 NX650 A CRANKCASE
    1989 NX650 A GASKET KIT B
    1989 NX650 AC CRANKCASE
    1989 NX650 AC GASKET KIT B
    1989 XR600R A CRANKCASE
    1989 XR600R A GASKET KIT B 85-92
    1990 GB500 A CRANKCASE
    1990 GB500 A GASTET KIT B
    1990 GB500 AC CRANKCASE
    1990 GB500 AC GASTET KIT B
    1990 XR600R A CRANKCASE
    1990 XR600R A GASKET KIT B 85-92
    1991 XR600R A CRANKCASE
    1991 XR600R A GASKET KIT B 85-92
  7. BThresher183
    Jan 12, 2015
    34
    Ah, ok. I was on HondaPartsHouse.com which they do not give that info. Partszilla does. I will look closer next time. Thank you!!
  8. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,418
    San Francisco,Ca.
    #8
  9. BThresher183
    Jan 12, 2015
    34
    Thanks, i will take a look at that thread. So, Neither the 1983 or 1984 (the years that are supposed to interchange for the gasket) are available. Partzilla people can't tell me if any other years will fit, even though the schematic pictures are 100% identical.
    #9
  10. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,418
    San Francisco,Ca.
    Go with the 11191-MK2-000. Honda may make a miniscule change to a part but it will still cross over to other applications.
    I meant 11191-MN1-701
    #10
  11. BThresher183
    Jan 12, 2015
    34
    I don't see those available either. You still think that the 1986 crankcase gasket will work?
    #11
  12. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,418
    San Francisco,Ca.
    Dammit I meant 11191-MN1-701
    This is the updated part number for the 1985 and up XL600 which is also the part # for the XR600's and XR650l's
    #12
  13. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,201
    Eureka, Ca.
    Use the gasket Steve (mcma111) said to use. It will work.
    Honda didn't change the architecture of these engines. I'm sure that gasket would work for an XR600R or an XR650L as well. I've used the clutch side case gasket for the XR650L on my XL600R.
    #13
  14. BThresher183
    Jan 12, 2015
    34
    Ok! Thanks for the verification. I will order that one.
    #14
  15. Ivanych
    Ivanych Ivanych
    Jan 24, 2011
    250
    St. Petersburg. Russia
    I used this gasket in my xr500r-84.
    she works:D
    #15
  16. BThresher183
    Jan 12, 2015
    34
    Stupid Question. 3 different part numbers for the same head cover gasket. Advice on which to get? Or does it not matter?
    #16
  17. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,418
    San Francisco,Ca.
    It's reusable. See my engine build thread.
    #17
  18. ewbarger
    ewbarger Hondarider69
    May 1, 2014
    235
    Williamsburg, Va
    Hi, Denniskirk dot com has the whole gasket kit for the 1983 xl600r. I use to own one. Vesrah Complete Gasket Set - VG1081M its a bit pricey, but you get what you pay for!
    #18
  19. Elkster88
    Jan 10, 2011
    50
    MN
    I'm normally a big fan of DK because of great service and quick shipping, but they're usually a bit pricier than other places. OP could save over $25 by buying that set on ebay, $95.29 including free shipping vs. $118.76+ shipping (and possibly sales tax if you live in MN) from DK.
    #19
  20. BThresher183
    Jan 12, 2015
    34
    Wow, thanks for that ebay link. I was going to order everything separately from partzilla, but it would probably equal out the same. Irritated I had to spend $50 on the left side crankcase today on ebay, I cracked and broke mine it hitting it with a deadblow to get the 2 halves loosened up. First time taking a motor apart, I learned my lesson.
    I hope that is a stock picture they have on there. None of those gaskets look correct ha.
    (I should have read down further, duh)
    #20
