1986 CR500R--Woods Bike Material?
Discussion in '2 smokers' started by brucifer, Apr 29, 2016.
  1. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,316
    Eureka, Ca.
    LOL, thanks for the tips! :p3rry
    I remember the lean it over till gas flows out of the carb from the '70s. My uncle and his buddies used to do that. :D
    #21
  2. Dao1
    Dao1 Long timer
    Mar 17, 2014
    1,999
    Austin TX
    hahaha....mine spit me off real good one time when it got on the pipe in 3rd gear....and, even landing on dirt w/ atgatt, I walked funny for at least 2 months recovering. My subframe twisted like a pretzel.
    #22
    FJ Fun likes this.
  3. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    15,491
    the hills
    Fortunately I had an understanding girlfriend. At the end of every day she peeled the shirt off and applied lotion 'til it healed. Road rash the size of Arkansas on your back in a humid Maryland summer sucks.
    #23
  4. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,316
    Eureka, Ca.
    She runs! :clap
    Finished straightening up the garage a bit and was ready to close it up and looked at the CR and thought "I wonder if that thing will light off."
    Turned the fuel on, leaned it over until fuel spilled out of the carb, stood it up and snicked it into 4th gear, rocked it back and forth a bunch of times, clicked into neutral, a couple half hearted kicks then two like I meant business and braaaap....ding...ding....ding. The thing runs awesome!
    Rode it around the yard for a minute or two and that's all it took for the front caliper to start seizing up so I put her away.
    I like this bike. Lots of torque even off the pipe. Nice. :ricky
    #24
    spokester, Brewtus and Rot Box like this.
  5. Bhart89
    Bhart89 Long timer Supporter
    Nov 12, 2013
    1,422
    Indianapolis, IN
    Congrats! I'm jealous.
    #25
    brucifer likes this.
  6. anotherguy
    Jun 18, 2009
    15,491
    the hills
    My experience says rebuild both the M/C and caliper. And use a quality DOT 4 when done.
    #26
  7. AlpinaE24
    AlpinaE24 Long timer
    Nov 2, 2010
    1,233
    az
    Better yet, swap a more modern USD complete front end
    #27
  8. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,085
    Stuck in 80s
    They actually make a better trail bike than most would think. I have an FMF Gnarly on my 86. I never could find some flywheel weights for it though. Air down for traction and pack fuel. :D
    Congrats on getting one. :beer
    Sean :brow
    #28
    dynodave and brucifer like this.
  9. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,316
    Eureka, Ca.
    Well, a couple weeks ago I pulled the caliper apart and cleaned it. The seals and bores looked good so I reinstalled everything and it seems to work well now. One of the pistons had a scratch I was concerned about but it appears to be just fine.
    So today I decide to change the transmission oil, coolant and plug and give the bike a general going over. I knew it was down on coolant and was hoping I didn't have the dreaded rotted out water pump/clutch cover deal but as soon as I loosened the oil drain plug, out comes some green and then milkshake. Crap.
    I removed the water pump cover and.........crap.
    Pretty sure I know what I'm going to find once I remove the impeller and clean all the corrosion out.
    So right now I'm letting the transmission drain. I'll get back to it after awhile.
    #29
  10. snarlyjohn
    snarlyjohn Human money repellant
    Apr 1, 2016
    501
    Australia
    One of these is all it takes to make starting a big-bore two stroke a piece of cake:
    #30
  11. GR0NK
    Sep 24, 2006
    10,085
    Stuck in 80s
    Bummer. Hope it's not as bad as that looks. :eek7
    Sean :brow
    #31
  12. GR0NK
    Sep 24, 2006
    10,085
    Stuck in 80s
    Can you post a link for it? I'm not getting any younger... :lol3
    Sean :bmwrider
    #32
  13. snarlyjohn
    Apr 1, 2016
    501
    Australia
    Sure - http://www.thumpertalk.com/topic/843225-cr500-decompression-valve-pics/
    The valve itself is a decompression valve for a chainsaw, any Stihl or Husqvarna dealer can supply them. They have an M10 fine thread, and the Husky versions are available in a long and short thread version. Just be sure to buy genuine; I bought a cheap aftermarket one from ebay once and it barely worked. These things make starting a big-bore as easy as a 125, really.
    #33
    spokester likes this.
  14. spokester
    spokester Long timer
    Jul 9, 2013
    1,812
    SE USA
    I also wonder if you could somewhat tame the beast by lowering the compression Ratio via a thicker head gasket or shim?
    #34
  15. snarlyjohn
    Apr 1, 2016
    501
    Australia
    You could, but it'd reduce the peak power a bit.
    One of the easiest ways to soften the hit without reducing the peak is to use a CDI with a programmable advance curve. With a little tweaking you could reduce the initial steepness of the torque curve as well as extending the over-rev.
    These bikes really don't make an enormous amount of horsepower; it's just the sudden increase in torque when it comes on the pipe that makes them a bit of a handful at times.
    #35
  16. Mobil1
    Mobil1 Long timer
    Jan 12, 2016
    1,837
    Is that aluminum or magnesium ?
    #36
  17. Mobil1
    Mobil1 Long timer
    Jan 12, 2016
    1,837
    They use these on Harleys also.
    #37
  18. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,316
    Eureka, Ca.
    Magnesium.
    #38
  19. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,316
    Eureka, Ca.
    As was suspected, the case is bad. The corrosion was actually pushing the outer seal out towards the impeller.
    On the inside, someones previous "fix" using silicone. I guess it worked because it didn't fail; the case did.
    Time for the later model two-piece clutch cover mod.
    #39
  20. AlpinaE24
    Nov 2, 2010
    1,233
    az
    What a mess, par for the course though. If it wasn't 116 today I would fire up the KX... considering pulling the head and sending it out to Larry wiechman. For $150 and he mods the head and skims it.
    Something about kicking a 500 in gym shoes just feels wrong
    #40
