1994 k Roo build thread
Discussion in 'Trials' started by Junglejeff1, Aug 20, 2019.
  1. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,626
    Upper Michigan
    In the 3rd pick you see moly 55 grease. This stuff slightly swells rubber. There is a small o-ring between the AJP caliper halves I coated with it.Most likly not needed but will make sure nothing seeps.I used moly 55 a lot on paint ball gun electronic trigger air control systems to help seal.
  2. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    20200411_001655.jpg 20200411_005242.jpg 20200411_004926.jpg I found a motor on Amazon to replace stock cooling fan motor. Going to try this instead of spam fan I purchased. Only 15 bucks and has ball bearings instead of bushings like original. Painted some parts I missed like fan housing mount and cleaned up exaust. I threw the header in a yard fire to burn out coke.Boring stuff but want to do it right.
    DyrWolf, Brewtus, Huzband and 2 others like this.
  3. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    Finished putting 2k clear on my parts and looks decent for a amateur painter.The decal places are closed here so I just painted the shroud graphics on which was a bitch. 20200423_123317.jpg 20200423_122621.jpg
  4. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    The 94 did not have the frame mount for the 91 shock res.A friend gave me a 2x3 sheet of 4mm aluminum so took a small piece off and came up with my own mount. 20200422_000106.jpg 20200422_000005.jpg
  5. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    15,404
    Dubuque, Iowa
    I gotta admit for an old HOS, that bike is going to look pretty nice. Too pretty to ride...
  6. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    Sometimes I think I should of held back and just made it mechanically sound for that reason. Not going to try some of the stupid shit I try to pull off on my gasser.If we do get to ride some trials this summer will try it out on one of the more forgiving ones (NOT Door county).We were looking at some new sections to make in Door last weekend.Hopefully will be toned down a bit from last year.
    Brewtus likes this.
  7. Hoss Cartright
    Hoss Cartright 219.474.6657
    Oct 23, 2016
    951
    Galapagos Islands
    "Too nice to ride" was exactly what I was thinking also. This bike is SWEET!
  8. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
  9. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    7,286
    Portales, New Mexico
    Nonsense. Ride it like ya stole it!!! :super
    Yeah, you really shouldn't listen to me..... :uhoh
    oldtrialer, Huzband, 10K and 2 others like this.
  10. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    15,404
    Dubuque, Iowa
    From the guy who's bike collection, umm, err, has a lot of patina. And I'm mean this in the most flattering way.:-)
  11. Brewtus
    Jul 30, 2008
    7,286
    :thumb
    Huzband and Norman Foley like this.
  12. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    I always tend to ride them.It's just pretty paint.working on powdercoating bash plate and high temp powder on header tonight.
    Huzband and Brewtus like this.
  13. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    20200423_234353.jpg 20200423_230642.jpg 20200423_224354.jpg Last project of night so I can start finishing this bike.Shot the skid plate with the same high temp powder as header.Have found this powder to be pretty tough in other use.Skid was to big for my little 2 pizza oven so used tinfoil to seal in heat.I tried cleaning up skid but some of the narfs were pretty deep.Powder fills in stuff better than paint and is tougher so worked out well.Almost shot skid with chrome powder but decided against it for this project.
    DyrWolf, Huzband and Brewtus like this.
  14. mrsdnf
    mrsdnf Been here awhile
    Feb 8, 2019
    807
    Lost between the Dandenongs and Yarra Valley
    Yes. Have to agree here. :raabia
  15. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    Not going to try to explain this but found out the reason this bike has the name Stanley steamer. My friend thought it was a broken impeller (all good there ).This pick is a thermostat that can be taken apart.The pressure return valve was missing and no pressure was building up beside relieving it when it was cooling. 20200525_220417.jpg
  16. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    Installed new dunlop on back.I used the 20"bicycle tube trick and it really sucks.Will buy the foam ring thing and try that next time.. 20200525_215718.jpg
  17. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    All you have to do is leave the tire blocked a few days. The DUnlop is usually the easiset one to mount.
    Norman Foley likes this.
  18. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    I put a tube in it over inflated for a couple days and it did help.
  19. Junglejeff1
    Oct 20, 2016
    4,626
    Upper Michigan
    20200603_210240.jpg Put a couple stickers on.Been to busy to do much and frustrated because my new bike is stuck in Chicago because of emergency measures. I kept my cool when fed ex called but really bummed because it was supposed to be here today.
    Brewtus, Huzband and lineaway like this.
  20. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    15,404
    Dubuque, Iowa
    That sucks. In the old days Ron would be delivering it to you in Door county this weekend.
