1. AVOID SCAMMERS!
      (1) Do not transact without protections in place! Different payment options may limit your payment protection
      (2) Use a payment service like PayPal WITH (!) purchase protection.
      (3) Terms like 'Friends and Family' are a warning that NO payment protection exists.
      (4) Avoid transactions with new members with no history and "family or friend of friend" offers.
      (5) If you do not understand the payment method you're being asked to use; stop and do not proceed until you do
      (6) If you receive a suspicious private message, click the "report" link and let us know!
    LISTINGS MUST INCLUDE: Price, Location, Product Description(s) and NO Links to CL or EBAY or your post will not be allowed. Read the rules!
Sold 1998 Suzuki DR650
Discussion in 'Bikes' started by NeilW, Apr 29, 2021.
Tags:
  1. NeilW
    NeilW 2-up Adventure Touring Supporter
    Sep 3, 2007
    192
    Las Vegas, NV
    Well-sorted 1998 Suzuki DR650 for sale $3,500
    Why am I selling? Just bought a Ténéré 700, which is bound to make the ol’ DR redundant, plus, the Missus says 4 bikes is at least 1 too many. I’m not in a hurry to sell because it’s cheap to keep, but I suppose the proceeds could go towards accessorizing/personalizing the new toy.
    Brief history – I purchased the bike from the owner of Warp 9 (hence all the Warp 9 parts on it) Nov. 2014 with 19,250 miles on it, currently has 36,200 trouble-free miles on the ODO. The only changes I’ve made are to completely redo the lighting and electrical accessories – done right. Otherwise just regular maintenance (oil & filter at 3,000-mile intervals, Valvoline 10w40 Synthetic). The bike has been thoroughly reliable.
    What it is
    1998 Suzuki DR650 (VIN: JS1SP46A5W2100677)
    The bike is located in Las Vegas, NV where you can see it, test ride it, take delivery.
    What it has/comes with
    Complete maintenance log (from my point of purchase)
    Purple frame painted black
    Eastern Beaver 3-circuit Solution, relayed grips, lights, outlet, SAE plug to battery
    Headlight - Petersen Great White LED 7" Round (DOT approved, sharp cutoff, excellent light)
    On/Off headlight switch
    DRZ 250 rear tail light with led bulb
    High intensity flashing brake light mounted below rear fender
    Instrumentation - Trail Tech Striker
    Trail Tech LED spot light bar mounted
    12v marine outlet on bars
    Heated grips
    Custom housing for grips / light switch
    Acerbis 6.6 tank with dual petcocks
    Warp 9 wheels, bronze rim color and spare wheels (spare wheelset, black rims, 21/17 laced to the OEM Hubs)
    Tires – Shinko 804/805 90/90x21 front, 130/80x17 rear (40-50% remaining)
    Warp 9 320mm big brake kit
    Braided brake lines front and rear
    Warp 9 clutch and brake levers (4 finger)
    Warp 9 handguards with led turn signals
    Aluminum Throttle tube
    RalleMoto steering stabilizer
    1" bar risers
    Cogent DDC valves
    . 55 front springs
    Cogent rear shock with rebound
    Superbrace Fork Brace
    Cush Rubbers (Sept 2016)
    Procycle jet kit with drilled slide (OE carb)
    FMF Megabomb headpipe
    Keintech midpipe
    GSXR aluminum rear can
    Warp 9 bearing starter cap
    Magnetic drain plug
    Warp 9 black timing plugs
    Warp 9 black skid plate with oil cover
    Warp 9 gear shifter with gold tip
    Warp 9 black aluminum pegs
    Procycle lowered peg mounts
    Procycle stainless engine side guards
    Warp 9 chain guide
    Warp 9 rear disk guard
    MSR Rear axle puller
    Zeta aluminum brake clevis
    Battery - Yuasa FTX9-BS (33610-33E20) (Aug 2018)
    Spark Plugs - NGK CR10E (Mar 2018)
    TCI luggage rack
    Quick disconnect Pelican cases
    Caribou limiters in pelicans
    12v outlet in pelican case
    Helmet lock on luggage rack with cable
    Tool tube
    Chain D.I.D. 525 Pro-Street VX Series X-Ring Motorcycle Chain (Mar 2016. 20620 mi)
    Sprockets – stock ratio (Jan 2016 23500 mi)
    Seat concepts seat
    Super custom mini faring made from a brown plastic trash can.
    Box ‘o parts included
    Tail bag not included
  2. bluemtnridr
    bluemtnridr Been here awhile Supporter
    Jun 6, 2009
    330
    Dayton Wa
    PM sent
