2 Batteries on one tender?
Discussion in 'The Garage' started by tomdubz, Nov 4, 2019.
  1. tomdubz
    tomdubz getting there Supporter
    Jun 29, 2010
    1,325
    Your Mom's in RI
    I've got a Battery Tender Plus single output charger.
    The two batteries in play:
    YTZ14S 12V 11.2Ah
    ES5LBS 12V 4.5Ah
    They're both AGM
    I'm thinking about using this thing but I have no idea if it's effectively series or parallel:
    Pretty sure I need parallel per the Battery Tender FAQ page here: http://www.batterytender.com/faq/products
    Someone tell me I'm an idiot.
  2. Jack90210
    Jack90210 quia ego nominor leo
    Oct 11, 2004
    16,527
    :jack
    That would almost have to be parallel.
    As best as I can tell, the larger battery is going to require a longer charge period for a given amount of discharge (lowered voltage), and what the charger will "see" as it cycles charge current on and off won't be ideal for either battery.
    SmittyBlackstone likes this.
  3. RetiredandRiding
    RetiredandRiding Retired to Ride Supporter
    May 22, 2015
    1,557
    Da Lat, Vietnam
    Bad idea. From the site you listed:
    "The nominal battery voltages (i.e. 12V, 8V, 6V, 4V, 2V) must be the same on each battery, and the batteries must be the same lead acid type (flooded, AGM, or Gel Cell). Also the batteries must be close to the same size in terms of amp hour capacity, and they must be close to the same level of discharge. It is also a good idea that the batteries be approximately the same age and that they be in relatively the same general condition."
    11.2 and 4.5 are NOT "close to the same size..." , so you CANNOT charge them together.
    The cable is, I believe, best used for accessories from the SAE plug on your bike.
    There's no need to keep a battery on the tender 24/7. If you switch it from one bike to the other every week of so, you should be fine.
    Or buy another tender.
  4. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    25,289
    Moneyapolis, MN
    I didn't want to start a new thread but...
    Neighbor's car dead this morning. Put my charger on it and it went haywire. Volt meter said 1 Volt? Really dead.
    Anyway after a while I though it was a goner but after a bit and jump start from another vehicle the 13V came back???
    It that even possible?
  5. RetiredandRiding
    May 22, 2015
    1,557
    Da Lat, Vietnam
    Better to spend an extra 30 seconds to start a new post than hijack one that's UNRELATED.
    CopyCat, sieg and Boatman like this.
  6. tomdubz
    Jun 29, 2010
    1,325
    Your Mom's in RI
    Derp. Dern reading comprehension fails me again. Was only seeing what I wanted it to do. Thanks!
  7. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,352
    New Mexico
    When I got injured and couldn't ride for quite a while I made a cable so I could put 5 bikes on one charger. The issue I encountered was making sure the batteries are at very nearly the same voltage BEFORE you rig them together. If you fail to do that, fuses will blow. I would not attempt to recharge or fast-charge batteries this way at all. But if they are already charged, just to hold them at 13v, personally would probably do it again.
    (Actually I have mostly switched to Lithium batteries now, they will hold a charge much longer and don't need to be put on a tender.)
  8. MacNoob
    MacNoob piney fresh
    Jun 2, 2010
    2,790
    The mosquito-y Center of Canada
    Tried this one time, ended up with 2 dry dead batteries. YMMV but I'm not doing it again.
    #8
  9. flei
    flei cycletherapist
    Apr 1, 2013
    10,438
    Western Mass.
    IMO you are not an idiot. For several years I've used this to charge 2 batteries from my Battery Minder brand maintainer. It has worked just fine. https://www.amazon.com/BatteryMINDer-SmarTECHnology-Multiple-Battery-Connector/dp/B00LHVUGXM
    I don't know if it makes a difference what maintainer you use, but I use this solar one as my bikes/atv/mower are stored in a remote shed (https://www.amazon.com/BatteryMINDe...ller-Desulfator/dp/B0000CEWWB?ref_=ast_sto_dp)
    #9
  10. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,131
    Indianapolis
    Yep, this. Don't parallel two batteries on one tender. And swapping every month would be plenty.
    And actually, all you really need is a few hours on the tender once a month or so. This is similar to what I do; I hate leaving tenders hooked up. Too many burned out garages from that. I normally only leave them hooked up when I'm around for a few hours doing something else. Once the light turns green, disconnect and ignore for four or five weeks.
    #10
    JGNC and MikeyT like this.
  11. tomdubz
    Jun 29, 2010
    1,325
    Your Mom's in RI
    #11
  12. RetiredandRiding
    May 22, 2015
    1,557
    Da Lat, Vietnam
    #12
  13. squish
    squish Out of the office.
    Dec 4, 2003
    9,160
    Where the Ghetto meets the sea.
    The only time I'll charge two batteries at one time, is if they are wired to work as one big battery and I'm only charging them as one big 12 volt battery. (My RV, or my Diesel truck)
    I wouldn't hook up two totally different batteries to one single output charger.
    They do make multi output chargers where you have individual leads for each battery and they work pretty well.
    I also do not like leaving bikes on a charger, even a "float" charger for long. I just worry about the battery boiling dry.
    If I do have to have it on a charger for an extended period of time (like over two weeks) I'll put the charger on one of those lamp timers, and have it set up to only charge the battery for like 5-10 mins a day, ideally if I could have it set up for say every other day or every third day I would do that.
    #13
  14. mike in idaho
    mike in idaho Been here awhile
    Aug 14, 2011
    500
    The only time I had two batteries on one float charger it ruined both of them in about a week. Turns out one of them had a shorted cell, boiled both of them dry.
    #14
  15. r60man
    r60man Long timer
    Mar 14, 2013
    2,062
    Centralish PA
    I have two motorcycles and a garden tractor. I have one tender that has two outlets. One single, no worries no hassles and everything stays nice and charged up. Total cost was less than $100.
    #15
