2 into 1 left side exhaust
Discussion in 'Hacks' started by arbalest, Nov 28, 2020.
  1. arbalest
    arbalest Been here awhile
    Mar 19, 2009
    970
    Windham, Maine
    Does anyone know of any of the above exhausts are available new or used? I used to have a Lufmeister set on my previous BMW/Dnepr rig.
  2. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    If you're talking Ural
    Raceway $1,200.00
    GPR $1,200.00
  3. hack2004
    hack2004 Adventurer
    Oct 21, 2010
    95
    Northern California
    In 1994 I had the muffler portion from a R100R attached to my 1975 R90 Ural rig . Exhaust is on the left side away from the passenger. No issues in performance and the sound is very mellow. I have a spare R100R muffler if anyone is interested. Send PM
  4. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Knowing which bike you want it for just might help! :ear
    davebig and Bobmws like this.
  5. arbalest
    Mar 19, 2009
    970
    Windham, Maine
    Sorry. R90/6 tug.
    Strong Bad likes this.
  6. Fstwheels
    Fstwheels Been here awhile
    May 2, 2015
    130
    Idaho Heartland
    I used a system off of a '84 R80ST, which exits on the left (similar to the GS only chrome), on my '77 R100/7 dirt hack. I cut and re-welded the outlet as it came out of the collector to go straight back and fitted a super trap. You could probably fit any muffler that suited you. I expect any airhead GS exhaust could accomplish this.
  7. hack2004
    hack2004 Adventurer
    Oct 21, 2010
    95
    Northern California
    On my
    R90/6 Ural rig. I have the muffler from the r100r. Needed to attach a different muffler hanger, but it clears using the Krause bags. I will get some photos posted soon
  8. hack2004
    hack2004 Adventurer
    Oct 21, 2010
    95
    Northern California
    #8
    draperg1 and Strong Bad like this.
  9. arbalest
    Mar 19, 2009
    970
    Windham, Maine
    Did it look something like this? Do the stock head pipes line up with the collector? Is the R100GS exhaust 38mm?
    #9
  10. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Isn't that a catalytic converter being used as a collector?. Also don't forget you always want your head pipes to be of equal length before getting to the collector that joins the two head pipes in to one.
    #10
    JustKip likes this.
  11. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    3,594
    Scottsdale, AZ
    If you go on Hubert website
    http://www.thetimelessride.com/US/My-Rides/EU-Geneva-08.htm
    There is some explanation on the way he adapted a airhead G/S muffler on his sidecar.
    I bought last year a 2 in 1 left up mufflers for my 15 from France.... in SS well made; made the mistake of not trying it before having it ceracoated black. It was made for newer heads... sent it back and got my money back less shipping and costing, it was too bad as the exhaust was really well made!!
    Found these pics:
    https://www.emoto.com/actualites/2019/ural-et-ses-sidecars-2wd-a-l-aam-barcelonnette-9197.php
    BOUVIER MOTOS | 20 Rue des Mourettes | ZI Les Auréats | 26000 Valence |
    T. +33 4 75 42 06 83 | sebastien.ural@bouvier-motos.fr | www.bouvier-motos.fr
    #11
  12. Fstwheels
    May 2, 2015
    130
    Idaho Heartland
    Yes, similar but the collector is smaller, not containing a cat.
    #12
  13. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Old school Supertrapp! With that many discs in it it must be fairly loud?
    #13
  14. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    4,546
    Wellington, New Zealand
    None of the Airhead collector boxes were catalytic converters.
    Re the R100R muffler, a lot of the bulbous portion between the collector & muffler is just a screen. That can be cut off. There is a quite nice stainless canister behind all that excessive chrome
    #14
  15. claude stanley
    claude stanley Claude
    Aug 2, 2018
    643
    pa
    That is preferred but in a pinch
    a cross over tube will help.
    #15
  16. Fstwheels
    May 2, 2015
    130
    Idaho Heartland
    Yes, 18 discs, an airhead with attitude.
    #16
    Muscongus and brstar like this.
  17. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    Now that looks like a fun rig to take out on the fire roads! I love it!
    #17
  18. TurTal
    TurTal Long timer
    Jul 30, 2015
    4,616
    https://www.speedwaymotors.com/Univ...ikpYUUgx13EEUT1FYLKR2ibxXRZVk4AAaAvQPEALw_wcB
    For example only...you'll need to match your pipe size
    Sometimes it's just easier to mock up your own exhaust from a kit
    Aftermarket can't always accommodate your particular needs and depending on mods you've done they simply won't fit
    At $150 bucks its an inexpensive way to create what you really want
    If you can't weld get the basics laid out then get a buddy to tack it up...once you're happy with it weld it up....paint or coat it and save a lot of $$$$$
    Find a cheap or free used muffler and you're good to go
    Hardest part of the job will be flanging the ends or getting your buddy to cut and weld your existing ones
    Outside that a little patience and creativity on your part is all that's required
    #18
    Bobmws and brstar like this.
  19. Strong Bad
    Oct 29, 2007
    12,416
    Omicron Persei 8
    With those "slip to fits" swedgged U bends, you can put tabs on them and use springs to hold them together. Which sometimes makes them much easier to take on and off if you want to snake them through tight spots. Here's a set of SS headers my son built for an off road race car as an example:
    #19
  20. Fstwheels
    May 2, 2015
    130
    Idaho Heartland
    Exactly what I built it for in '84. A 3.56 fd makes it all usable power and with studded tires it gets around really well in the winter. Approaching 170,000 miles since the build.
    #20
    rg sw wa., Jimr80gs and Strong Bad like this.
