2 stroke fouls plugs quickly
Discussion in '2 smokers' started by Stick_man, Jul 31, 2020.
  1. Stick_man
    Stick_man Adventurer
    Feb 26, 2012
    91
    NY
    75 Harley sx 175
    I rebuilt it recently and replaced 2 broken gears. Upon rebuild I noticed the clutch wobbled a little. Anyway the plug fouls quickly and bike smokes like a b*tch. I replaced the right seal so I don’t know how gear oil is going in. Unless the gasket between the cases is bad or wobbly clutch /bad bearing is causing the seal to not work ... how else is oil getting in there? The trans oil is low so I know it’s going in
  2. motu
    motu Loose Pre Unit
    Dec 28, 2001
    7,327
    New Zealand
    I'm not familiar with the engine, but on some 2 strokes the right hand main is lubed by the gearbox oil, and so the seal is inboard of the bearing, a leaking seal will suck gearoil into the crankcase. But you say you've replaced the seal ? Put gear oil in the gearbox, you'll smell it in the exhaust to confirm.
  3. Stick_man
    Feb 26, 2012
    91
    NY
    It’s a typical Japan two stroke set up. The main bearings are lubed by 2 stroke oil injected in the cyl head.
    And yes I did replace the seal - it still does it. Did you mean put2 stroke oil in the gearbox ??? The gearbox already has gearbox oil.
  4. Navin
    Navin Long timer
    Sep 22, 2009
    29,405
    Wear on the shaft? Bearings wobbling isnt going to help. Like my old 2t Derbi, fun old bikes but dont ride it farther than you can push it home just in case. :lol3
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,517
    Anchorage, formerly Spenard (hub of the universe)
    if its pulling gear oil in, it has to be either the gasket or a crack in the case
  6. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,993
    Golden CO
    On a typical Japanese two stroke as you mentioned there only way for oil to get in there is the right side crank seal or leaking center case gasket.
  7. Stick_man
    Feb 26, 2012
    91
    NY
    The gasket is new unless something happened to it upon assembly. Which is highly possible since I didn’t use gasket goop (I always considered it amateur thing to do). But man ripping that whole thing apart again shoot.
    Can you just run the injector Pump dry and put 2 stroke oil in the gear box or just use like castor oil or something for the gears?
  8. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,084
    Omicron Persei 8
    Let us know how that works out!
    #8
    sieg likes this.
  9. Spikester300
    Spikester300 Roll Tide!
    Feb 19, 2009
    163
    Killen, Alabama
    gear oil lubes the gears unless the crank seal is bad, it's not a 4-stroke.
    #9
  10. Stick_man
    Feb 26, 2012
    91
    NY
    hmm the right side oil seal. OK when I put it together - I never replaced it. It started doing the oil thing in the exhaust/smoking thing. So I figured "well it has to be the seal. you should have replaced while you were in there... oh well, better late than never. " So i opened up the right side again, and replaced it with a new seal. It still does it.
    Maybe that clutch that wobbles, is causing so much vibration on the main crank it is shaking the seal that all gets past there >>> :dunno
    #10
  11. TNWillie
    TNWillie Long timer
    Sep 18, 2012
    1,369
    NE TN
    Back in HS, MANY decades ago, I had a Suzuki X6 Hustler that I'd bought used. It fouled plugs in the same manner as your bike does. I rebuilt the top end (ie. pistons and rings) but it still fouled plugs. Finally sold it to a good friend who figured out the cause of the problem. I'd put std sized pistons and rings in not knowing that the previous owner had bored the cylinders 1st over. LOL
    #11
  12. Pendragon5
    Pendragon5 Carress of Steel
    Jul 2, 2008
    62
    Cheyenne WY
    Is there an o-ring as well as a seal on the crank side?
    #12
  13. Stick_man
    Feb 26, 2012
    91
    NY
    No there is no o ring. I already tore it down again. This time I am replacing all the bearings, seals, and I have a spare used countershaft. I am also using gasket goop on the center gasket and freezing the one case half before assembly. Heck I might even bring it to a mechanic and pay his 250 bucks to put it together if I have a hint of doubt about it working
    #13
  14. concours
    concours WFO for 50 years
    Dec 2, 2008
    8,224
    NH USA
    ...except it’s Italian.
    #14
  15. PSchrauber
    PSchrauber Long timer
    Jan 3, 2011
    1,358
    Summer: Kemiö, Finland; Winter: North Germany
    What color had the plugs whee they wet or just dark, or with build up black carbon?
    #15
  16. gmk999
    gmk999 ____ as a Rotax
    May 2, 2011
    5,738
    New England
    Check the cylinder bore vs the piston and ring diameter.. If its a Harley, it was owned by a Harley guy.
    Were there any homemade parts in there when you first cracked the case?:rofl
    #16
  17. Stick_man
    Feb 26, 2012
    91
    NY
    I know it Italian but it resembles a typical japanese 2 stroke set up. only difference is the clutch.
    plugs are wet and black
    I think rings and stuff are ok. Has like 140 lbs of pressure.
    I think it was that center gasket ... I slit the cases and it looked like it got bunched up in there right where cylinder and gearbox surfaces mate.
    I also noticed the shaft bearing has a slight kilter on the inner race when spum around, which must be where that clutch wobble is coming from. Oh well need to be more careful this time.
    #17
  18. PSchrauber
    Jan 3, 2011
    1,358
    Than it is running to fat too and also burning too much oil and/or gas.
    That is too a environment the plugs don't like at all and due fail with a sudden.
    I had the sane oroblem with an old crank seal on the gearbox (primäry gear side) and a carb that did not suite the motor.
    New seals and a proper carb dsolved it and of course simple plugs nothing special as tgese Iridium olugs don't like 2 strokes.
    #18
