2 stroke fun for 200 bucks
Discussion in '2 smokers' started by hardwaregrrl, Feb 16, 2011.
  1. Whitey1
    Whitey1 Long timer
    Mar 16, 2008
    11,603
    Ohio
    This all makes a lot of sense, my only question is where does the oil go after it is used to lube the crank? When you change the crankcase oil do you leave it a little low to account for the extra oil that will be introduced to the system? Doesn't the 2t oil thin down the other oil?
    Just curious.
  2. Al Tuna
    Al Tuna NSFW
    Nov 24, 2006
    24,921
    Moran Nation
    It is also burned in the combustion mixture and exits out the exhaust. The crank seals keep it separated from the trans oil.
  3. Whitey1
    Whitey1 Long timer
    Mar 16, 2008
    11,603
    Ohio
    :thumb
    Now it makes perfect sense! Thank you.
  4. stainlesscycle
    stainlesscycle Long timer
    Jun 6, 2008
    2,329
    morgantown, wv
    2 stroke fun for 200 bucks. ironic title. no fun and no $200 :rofl
    don't worry it'll all be worth it once it's done.
  5. hardwaregrrl
    hardwaregrrl Can't shoot straight Supporter
    Jan 26, 2006
    10,022
    Atlanta
    Ha! I know, but at the time I thought it would just need 50 dollars worth of TLC. But it is still fun, as learning often is.:D
  6. blaine.hale
    blaine.hale Long timer
    Feb 28, 2009
    4,379
    Atlanta, Ga
    When it's running, we can hit the trails! I'm dropping bearings back in my transmission and crank and reassembling this weekend. So glad I don't have an oil inject unit to deal with :)
  7. vtwin
    vtwin Air cooled runnin' mon
    Jan 11, 2005
    9,878
    NorCal
    How does my little Suzuki M31 two stroke get lube to the crank since it runs strictly premix? :ear
  8. PFFOG
    PFFOG Richard Alps-aholic Supporter
    Aug 19, 2005
    7,194
    Western NY, further from NYC than 6 entire states
    Probably not a CCI style injection.
  9. Grider Pirate
    Grider Pirate Long timer
    Sep 28, 2007
    1,686
    LV, NV
    The crankcase is part of the intake tract. Anything coming from the carburetor goes there first before being pumped up the transfer ports into the combustion chamber. The bearings get what they need from the oil in the fuel while it's down there. This is why two strokes of even moderate performance can't survive with bushings at the wrist pin or big end of the connecting rod. Bushings (and plain bearings) take considerable lubrication, while roller bearings (big end) and needle bearings (wrist pin end) need very little.
  10. PFFOG
    Aug 19, 2005
    7,194
    Not true with CCI, as the LH bearing is SHIELDED!! The air fuel mix is shrouded from the mix, and the lower end bearing is also shielded by smaller slits in the rod, than a pre-mix motor.
    Look at the diagrams or take one apart, it is very obvious that disconnecting the injection will lead to failure of the bearings.
  11. Grider Pirate
    Sep 28, 2007
    1,686
    LV, NV
    Copy all. Vtwin was asking about his 'little M31' two-stroke, saying it was strictly pre-mix. If his M31 is supposed to be a CCI system, then by all means, he should be using the pump.
  12. vtwin
    Jan 11, 2005
    9,878
    NorCal
    Thanks GP. Really seems like it's just not enough oil to lube bearings in pre mix, but they've been like that for years, so I guess it works.:dunno
  13. YamaGeek
    YamaGeek Skeletor sparklemuffin.
    Jun 24, 2007
    32,561
    western oregon
    It's actually more about shielding of the bearings.
    Suzuki copied SAAB's oil injection concept for the Sport, Shrike, and Monte Carlo 850 cc engines, all of which have an oil injection system that forces oil directly into the main crank bearings and the cylinder walls. To keep the oil in there from getting too diluted, they also had some extensive stamped metal shielding that covered the main bearings and crankwheels. The upside of all this complexity is that the cranks on these Suzukis are "stuffed", which in laymen's terms means that all the lower end open space is reduced to a minimum and this makes for more efficient transfer scavenging.
  14. pjhorgan
    pjhorgan Adventurer
    Jul 16, 2009
    14
    Gainesville, GA
    Jenna,
    I had a TS185, too... my first bike. It was a '71. Then I had a string of Suzuki two-strokes after that. Learned to soup them up quite a bit... they were over-engineered and came with a 12,000 mile warranty, so you could really work on them with a die-grinder. Used to replace the head gasket with tin foil, file 5mm off the piston intake skirt, port and polish the cylinder, put on a Bassani pipe and almost double the horsepower. Of course, that wasn't too hard, since, stock, it only had 11 hp!
    Also installed "long travel " shocks from Curnutt, in California, and put preload spacers and heavier oil in the front forks. Geared way down, it was a pretty good mountain climber.
    Later, my father got one, and we souped it up some as well. Wish I still had one.
    Enjoy!
  15. bgoodsoil
    bgoodsoil Dare to be Stupid
    Jul 9, 2008
    4,724
    Washington, DC, USA
    so why haven't I gotten to ride this thing yet? :ddog That oil pump oughta take a half hour to install. Back to work ya bum!
  16. blaine.hale
    Feb 28, 2009
    4,379
    Atlanta, Ga
    Jenna, we added a 2nd Bultaco to our house hold. When are we starting a gang and tearing up urban trails?
  17. hardwaregrrl
    Jan 26, 2006
    10,022
    Atlanta
    Dammit....I knew there was something I was supposed to be doing these past few months. She runs great! I'll post pics up tonight. Having electrical issues at the moment. Need tires and the damn registration from the stoner I swiped her from...but it's all good.!:thumb
  18. jkpell
    jkpell nOOby
    Nov 4, 2010
    3
    West Georgia
    you didn't by any chance get this from a chap that lives near Newnan did you?
  19. vtwin
    Jan 11, 2005
    9,878
    NorCal
    Jenna, glad you fixed all your issues. I am going through all this with my two little Suzuki smokers. Takes for ever to start my little K11p and my M31 only really started and ran once since Jan 1st.
  20. Stagehand
    Stagehand Imperfectionist
    Oct 6, 2004
    33,302
    Turicum
    Pics, my ass! :evil It didnt happen! ::fitz
