2001 Gas Gas TXT 321
Discussion in 'Trials' started by Grynch, Sep 14, 2019.
  1. Hoss Cartright
    Hoss Cartright 219.474.6657
    Oct 23, 2016
    951
    Galapagos Islands
    Just release the hose clamp at top and bottom of hose and rotate the thermo-switch for clearance.
    As I pointed-out in previous post, yellow A/C power-wire cannot be touching ground anywhere.
    #61
    Grynch, jonnyc21 and Brewtus like this.
  2. Grynch
    Grynch Long timer
    Jan 29, 2014
    2,293
    Bay area
    This looks like it was hitting on fan. Can I turn it 180 degrees? IMG_20191025_145159991.jpg
    #62
  3. Grynch
    Grynch Long timer
    Jan 29, 2014
    2,293
    Bay area
    It rubbed the yellow wire straight from the factory, and rubbed the fan.
    #63
  4. Hoss Cartright
    Oct 23, 2016
    951
    Galapagos Islands
    I see a few things in the images of your 19-year-old bike that are not "factory"
    Just do what it takes to clear the fan blade and get the yellow wire off the chassis. Stuff a little inch square piece of rubber cut from a bicycle tire for example. Or it may need to be repositioned only a teenie tiny little bit.
    #64
    Grynch, Norman Foley and Brewtus like this.
  5. Grynch
    Grynch Long timer
    Jan 29, 2014
    2,293
    Bay area
    Hoss send me a PM
    #65
  6. Grynch
    Grynch Long timer
    Jan 29, 2014
    2,293
    Bay area
    Ok
    #66
  7. Hoss Cartright
    Oct 23, 2016
    951
    Galapagos Islands
    How did this work out? Did you get it going good?
    Archive image of team GG rider Bruno Comozzi in the World Championship in the year 2000 on a TXT 321
    #67
    Norman Foley and jonnyc21 like this.
  8. Tuckerchef
    Tuckerchef Adventurer
    Mar 29, 2018
    14
    Kelowna BC
    I just picked up a 2002 gas gas txt edition 250. I just finished servicing it before I start riding it. Mine was in about the same shape as the one in this thread. I am in need of fork dust seals. I was able to get oil seals
    I just picked up a 2002 gas gas txt edition 250. I just finished servicing it before I start riding it. Mine was in about the same shape as the one in this thread. I am in need of fork dust seals. I am located in BC Canada. Any help would be appreciated.
    #68
  9. D2W
    D2W Been here awhile
    Jun 8, 2017
    277
    Summerland, B.C., CANADA
    Sent you a PM.
    #69
