1. AVOID SCAMMERS!
      (1) Do not transact without protections in place! Different payment options may limit your payment protection
      (2) Use a payment service like PayPal WITH (!) purchase protection.
      (3) Terms like 'Friends and Family' are a warning that NO payment protection exists.
      (4) Avoid transactions with new members with no history and "family or friend of friend" offers.
      (5) If you do not understand the payment method you're being asked to use; stop and do not proceed until you do
      (6) If you receive a suspicious private message, click the "report" link and let us know!
    LISTINGS MUST INCLUDE: Price, Location, Product Description(s) and NO Links to CL or EBAY or your post will not be allowed. Read the rules!
Sold 2002 KLR 650 Loaded - $2,500 NoVa
Discussion in 'Bikes' started by cassimonee, Nov 21, 2020.
Thread Status:
Not open for further replies.
  1. cassimonee
    cassimonee Adventurer
    Nov 19, 2017
    61
    Alexandria, VA
    I bought this KLR at the end of August 2020 from another ADV Rider user for my boyfriend to ride while he visited from Germany. He put around 3,000 miles on it and it performed flawlessly offroad on the Northeast Backcountry Discovery Route (NEBDR), including Class IV roads. This KLR is a true off-road oriented dual sport and is about the performance, not pretty plastics. The bikes runs fantastic and I continue to ride it locally. The mileage is approximate because there isn’t an odometer, this is a best guess based on my conversations with the previous owner and the mileage we added. The trailtech has been rewired so future mileage will be incorporated. Original builder thread available upon request.
    Currently located in Alexandria, VA. Contact me to see in person or test ride.
    Clean title with Odometer Reading Exemption
    Mileage - approx 25,000 miles
    Known Maintenance:
    Rear brake caliper rebuild - 50 miles ago
    Rear brake rotor - 50 miles ago
    Rear brake pads - 50 miles ago
    Chain adjusted - 50 miles ago
    Rear brake fluid replaced - 50 miles ago
    Front brake fluid replaced - 3,000 miles ago
    Oil change - 500 miles ago
    Front Tire - Changed 3,000 miles ago
    Rear Tire - Changed 4,500 miles ago
    Modifications/Upgrades:
    2004 RMZ 250 KYB Front Forks and Triple
    Cogent Moab shock
    Sargent seat
    IMS 6.6 gallon Fuel tank
    CVK40 pumper carb with pilot and needle jets from KLR stock carb 142.5 main and KLX needle in second slot, stock pilot jet
    Pro Taper Contour Windham/RM Mid handlebars
    Doubletake Mirrors
    JNS Engineering DRZ400S Headlight
    DRZ400SM Headlight brackets
    DRZ400 headlight shroud
    Trailtech Vapor Speedometer with Indicator lights
    Mylers Supercool radiator
    Ernie Bell modified clutch arm
    Ernie Bell skid plate
    Torsion spring DooHicky from EagleMike
    2006 KX 250F Front wheel hub laced to Excel Takasago rim with heavy duty Moose spokes
    Supersprox front sprocket with EagleMike counter sprocket nut
    2006 KX 250F Caliper (two pistons instead of stock single piston)
    Galfer wave rotor (front)
    Supersprox 43 T sprocket (rear)
    KLR 600 hollow rear axle
    Stainless Steel Brake Lines (front and rear)
    Happy Trails master cylinder mount
    Front fender Polisport UFX Freeflow
    2009 KLR rear fender
    Rear led turn signals
    Zeta XC handguards with integrated turn signals
    Extra Parts
    FMF Q4 muffler
    New Shinko 244 Rear tire
    New Heavy Duty tube (rear tire)
    Extra set of rims
    Klmer Service Manual + Kawasaki Supplement Book
    Motorcycle Cover
    ***luggage NOT included***
    skybo1 and baldman1 like this.
Thread Status:
