2002 R1150GS ABS Pump Stuck On
Discussion in 'GS Boxers' started by rsamsel, May 2, 2017.
  1. rsamsel
    rsamsel Adventurer
    Sep 19, 2010
    95
    I have seen a thread regarding this but can't find it anywhere. -
    ABS Pump stays stuck on after it engages. Will stay on even when the bike is turned off. Temporary fix is to takethe tank off and smack the ABS pump until it kicks the relay....until happens again. Battery is fresh.
    I know I've seen a thread discussing which relay is required and the weird cover on the ABS pump that needs removed to access the relay but I cant find it anywhere.
    Experts?
    Rob
    Maple Valley WA
  2. rsamsel
    rsamsel Adventurer
    Sep 19, 2010
    95
  3. Terry
    Terry Long timer Supporter
    Jun 19, 2002
    1,370
    Colorado Springs, Colorado
    There is a description of how to remove the plastic cover over the relay here:
    http://advrider.com/index.php?resources/abs-2-modulator-repair.9/
    I don't know about a substitute relay. If you can't find one, I'd go looking for a used one. There are plenty of scrapped units around because of hydro issues. They should have good relays.
    Terry
  4. ErikMotoMan
    ErikMotoMan Airbag crash survivor!
    Apr 4, 2014
    4,486
    In Motorcycle Heaven since 1990 - So Cal!
    Absolutely no on a used relay, they all develop the same problem.
  5. Terry
    Jun 19, 2002
    1,370
    I wasn't aware this was a very common problem. I have heard of it happening, but it doesn't seem to affect a lot of people. Mine is still happy after many years.
    Terry
  6. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,325
    london, England
    . I think you're taking about the wrong ABS module, The early ABS modules don't have a common relay problem at all. In fact compared to the problems with the later servo/abs unit the earlier ABS only units are bullet proof.
  7. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    6,541
    Sunshine Coast B.C.
    Once the contacts start sticking they will keep doing it from what I have seen/experienced. The problem starts with a weak battery.
    Replacement is required.
    The same applies to the Load Relief relay
  8. ErikMotoMan
    Apr 4, 2014
    4,486
    My experience has been with this exact model year.
    #8
  9. Steptoe
    Steptoe steptoe
    Feb 21, 2004
    3,325
    london, England
    Yes, but it's not exactly a "common" problem. Think i've had two modules in the workshop with a relay problem in 25 years.
    #9
