2004 R1150RT Wideband O2 Sensor Project (and AF-XIED for BMW)
Discussion in 'Vendors' started by roger 04 rt, Dec 13, 2011.
  1. CannonsvilleRider
    CannonsvilleRider Been here awhile
    Aug 26, 2007
    729
    North of Cannonsville, NY
    I am new to this topic, but don't understand how the reading for the narrowband sensor is modified. Is there a link for that information?
  2. MassiveLee
    MassiveLee Banned
    Nov 11, 2013
    1,611
    Montreal
    You are correct. And it was confirmed yesterday when I did some readings with a GS911. The AF-XIED reads the signal from the oxygen sensor and literraly shifts it. The DME reads the signal as being a lean mixture and richens up fuel.
  3. Blu_Vue
    Blu_Vue Nothing is what it seems.
    Apr 14, 2008
    304
    Denver, CO
    Just received the universal harness along with the device for my '99 1100gs.
    Where does the RED wire connect? Instructions say "to 12v", but do not specify where.
    Also, if anyone has pics of the actual instal on an r1100, will you please point me in that direction? Electrical diagrams just ain't my thing.
    Thank you, in-advance!
  4. roger 04 rt
    roger 04 rt Long timer
    Nov 9, 2011
    3,452
    Massachusetts
    The stock O2 sensor outputs a signal greater than 700 mV when the mixture as measured in the exhaust is richer than 14.7:1, and under 200 mV when leaner than 14.7.
    The afxied is constantly sampling the O2 sensor voltage. Depending on its setting, it's output voltage makes the 700 to 200 transition at AFRs richer than 14.7. So the Motronic sees the same exact signal but that signal makes the transition at a different mixture.
    http://www.advrider.com/forums/showthread.php?p=20877761#post20877761
  5. CannonsvilleRider
    Aug 26, 2007
    729
    Could someone explain how the "shifting" works? I am interested in getting one for my 2012 1200 GSA, but it sounds too much like "magic".
  6. Steiney
    Steiney Adventurer
    Jun 27, 2010
    84
    HarCo, MD
    It does work like magic but it's really not. I'm no expert but the way I understand it is like this - it's kind of like a set of headphones that has its own volume control in the cord. Your music player or phone is putting out sound at a set volume, but you can alter that volume by adjusting the volume switch in the cord prior to getting to your ears. The O2 sensors are the music player and your ears are the bike's computer that determines how much fuel to give based on what it's "hearing". I know this is dumbing it down to the extreme and I don't mean to take anything away from the sophisticated electronics and all the R&D used to accomplish this. I have no affiliation with the company other than being an extremely satisfied customer...
  7. roger 04 rt
    Nov 9, 2011
    3,452
    Massachusetts
    The stock o2 sensor outputs a signal greater than 700 mv when the mixture as measured in the exhaust is richer than 14.7:1, and under 200 mv when leaner than 14.7.
    The afxied is constantly sampling the o2 sensor voltage. Depending on its setting, it's output voltage makes the 700 to 200 transition at afrs richer than 14.7. So the motronic sees the same exact signal but that signal makes the transition at a different mixture.
    My description above is literally how it does what it does, there's no magic involved. The AF-XIED measures the O2 sensor voltages above 450 mV, uses a proprietary mathematical algorithm, and outputs a signal to the Motronic.
    The "before" signal swings between 200 and 700 mV (approx.).The "after" signal also swings between 200 and 700 mV (approx.). So the difference is not the voltage swing, the difference is that the "after" signal swings at a lower (richer) level of exhaust oxygen content--e.g. 14.1:1 AFR (approx.) on setting 7.
    The link above goes into enough technical detail, that if you were so inclined, you could design one.
  8. jadoca
    jadoca Adventurer
    Jul 15, 2006
    93
    What is your evaluation?
  9. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,290
    The woods and mountains of Alabama
    Yeah, JVB, Produce!
  10. WindSailor
    WindSailor Been here awhile
    Jan 29, 2008
    795
    Somewhere out West
    Bump.
    With the quality of people commenting on this - I'll probably go ahead and order this.
    I guess the only question left is whether to use 7 or 8....
    Sent from my Samsung Note 3
  11. roger 04 rt
    Nov 9, 2011
    3,452
    Massachusetts
    Start with 7, ride for a few tanks. Then do the same with 8 and 6.
  12. def
    Feb 28, 2004
    14,290
    Roger, when changing the fueling setting, should you dump the adaptives?
  13. CannonsvilleRider
    Aug 26, 2007
    729
    I have a 2005 hexhead that pulls like a freight train and a 2012 camhead that is prone to pinging. Anyone tried the AF-XIED on a Camhead that was a pinger?
  14. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,094
    NE Oregon
    I left on July 22 and returned on Aug 1 on a 2,067 mile dirt ride across Oregon, Idaho and Montana; solo and then with a group on the Best of Montana 2014 ride.
    My bike is a 2007 R1200 GS Adventure and I left the AF-XiED, which was installed just before this trip, on the #7 setting for the entire time.
    Ambient temps 40-102 F. Gear weight 70 lbs, rider 165 lbs. Total wt about 800 lbs. Engine oil: Redline full synthetic; used 300ml on trip.
    Type of riding. 90% + off road. From 100 miles on Lolo Motorway in 1 and 2 gear with aver speed 11.2 mph to 70 mph dirt roads. Many long up hill grades [5-10 miles] in first gear and ambient temps 85-90 F.
    Observations:
    #1 No popping on deceleration.
    #2 Started within two revs. Every time.
    #3 Engine temp slightly below previous temps without AF-XiED and slower to heat up on long climbs.
    #4 Best of all, smoother throttle transitions in 1 and 2 gears when crawling up grades or descending grades on compression. Never stumbled.
    I wished that I had tried #8 setting but it was working so I didn't need to "fix it". Very few "rattle" starts when hot and under a load; mostly from my poor use of clutch or starting on a grade.
    See http://www.advrider.com/forums/showthread.php?t=997064 BOM report.
    I enjoyed the ride immensely and in no small part due to the enhanced performance of my bike with the AF-XiED installed. Thanks Mike and Roger for your patience in leading me through the installation and understanding of how it worked. And for Nightrider producing the AF-XiED. Appreciated.
    Phil
    masegraves likes this.
  15. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,094
    NE Oregon
    [Not wanting to horn in on JVB's observations but to add to the mix; here is what I posted on the AF-XiED thread on how it worked on my bike]
    I left on July 22 and returned on Aug 1 on a 2,067 mile dirt ride across Oregon, Idaho and Montana solo and then with a group on the Best of Montana 2014 ride.
    Observations:
    Phil
  16. terryckdbf
    terryckdbf Bumbling BackRoad Riders™
    Jun 1, 2006
    4,503
    Perry, Ga
    Wow Phil, looks as though ya'll had a great time. I had a good time reading about it. Got a kick with the "chain" comment.
    Be well.
    Terry
  17. MUDHWY
    MUDHWY Big Break
    Jun 4, 2014
    12,620
    The Edge Of Town
    Phil's finally got a system that works! Better than those other guys' products huh? :wink:
  18. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,094
    NE Oregon
    Hush! Those could be banning words!
    To each their own and there are indeed many ways to "get there"...for me the AF-XiED proved to best meet my needs..
    Phil
    Wyvern813 likes this.
  19. MUDHWY
    MUDHWY Big Break
    Jun 4, 2014
    12,620
    The Edge Of Town
    ...and I only even say anything because I lived through the same process of elimination before getting my XiED system. :1drink
  20. roger 04 rt
    Nov 9, 2011
    3,452
    Massachusetts
    Nope, no need to. Go from setting to setting no reset. Just give 'em time to adapt.
