2004 Suzuki Vstrom 650 cranks but won't start... (Video)
Discussion in 'Japanese polycylindered adventure bikes' started by TengaiJohn, Dec 30, 2019.
  1. TengaiJohn
    TengaiJohn Long timer Supporter
    Apr 24, 2006
    3,715
    Tappan, NY
    Hi everyone,
    I purchased a 2004 Wee from an inmate about 6 months ago. The bike has over 90k miles on it.
    Here's what I've done since buying it:
    1. New gas tank
    2. New fuel pump and fuel filter
    3. New Air and Oil Filter
    4. Oil change
    5. New battery
    and a few other changes but that are not relevant to this issue.
    I have not ridden it much since I was having some weird issues with the front end. I decided to change the stem bearings.
    Before replacing the stem bearings the bike started up and ran fine. I started her up right before doing the stem bearing replacement.
    The only two parts I removed/changed while doing steam bearings was a replacement ignition switch and remove throttle cable assembly on handlebar to re-route the cables.
    Put everything back on the bike and it cranks but no start. Try some starting fluid and she starts fine.
    Checked fuel - OK
    Checked fuses - OK
    Checked fuel pump - she primes
    I started to removed the air filter box and check the injectors.
    Here is the when I try to start it with the injectors off the throttle body.
    Are the injectors supposed to squirt some fuel when the fuel pump primes?
    Does the choke look ok?
    It's my first V so I'm not very familiar with the bike.
    Any help would be greatly appreciated.
    Thanks and Happy New Year!
  2. MeVoGTC
    MeVoGTC Been here awhile
    Nov 18, 2019
    307
    Maryland
    How old was the gas? Did you check your spark plugs? Did sediment in the tank get stirred up between now and the last time it ran?
  3. TengaiJohn
    Apr 24, 2006
    3,715
    Tappan, NY
    Thanks for the reply. Brand New tank and fuel pump. I’m getting fuel pressure but she won’t run. Engine will run if I spray starter fluid.
  4. dtysdalx2
    dtysdalx2 Just glad to be here.
    Aug 1, 2004
    26,791
    Moneyapolis, MN
    Can you see fuel getting sprayed down the throttle bodies? You can remove the secondaries if you want. Open the throttle while watching.
    9V battery and some carb cleaner can check injectors for opening. Easy to remove, on my L2 650 at least.
  5. eakins
    eakins Butler Maps
    May 29, 2002
    36,980
    Fort Collins, Colorado
    Did you pull a plug and ground to test to see if you have spark on both cyl?
    It needs fuel and spark. Compression too of course.
    If you have spark then starter fluid and see what happens.
    If you don't have spark that's the ussue
  6. TengaiJohn
    Apr 24, 2006
    3,715
    Tappan, NY
    I’ll give that a try.
  7. ShiftHead
    ShiftHead the f is silent.
    May 2, 2009
    446
    Fort Mill, SC
    If it starts with starter fluid then you have spark and compression, which means you have a fuel delivery issue. You say it's a new fuel pump, but I'd start there.
    eakins and MeVoGTC like this.
  8. PeterW
    PeterW Long timer
    Nov 11, 2005
    4,762
    Gold Coast
    Plug the clutch interlock switch back in. Check the sidestand cutout switch as well.
    #8
  9. RickyBilly
    RickyBilly Mentally Retired
    Apr 2, 2010
    211
    Wallyworld, Ontaxio, The Colonies
    Check the clutch interlock switch....this is a common problem and an easy and inexpensive fix...you can short it out with a piece of wire to test it, if that is the issue it will run, though not well...was a $12 fix in Canada...I had 2 x wee stroms with this issue...other wise a great bike
    #9
  10. eakins
    eakins Butler Maps
    May 29, 2002
    36,980
    I thought that clutch switch only came into play when the bike is not in neutral.
    If it's in nuetral I thought it still starts w/o touching the clutch?
    #10
  11. ned37
    ned37 Been here awhile
    Oct 29, 2007
    390
    verde valley, az
    not the case with my '12, but imo, that's the way it should be
    #11
    RowBust likes this.
  12. Dusty Roads
    Dusty Roads Adventurer
    Jun 25, 2007
    56
    Suches,Georgia
    My 06 DL1000 self diagnostic test (service manual)found my issue;mice chewed one of coil wires
    #12
  13. racer
    racer Long timer
    May 5, 2004
    2,607
    Indiana
    Why did you replace the ignition switch? Put the old one back in and see what happens. Good luck. Racer
    #13
