2005 CRF250R Rebuild
Discussion in 'Some Assembly Required' started by Raindog18, Sep 18, 2018.
  1. Raindog18
    Raindog18 Rock it till the wheels fall off
    Apr 20, 2015
    45
    Montana
    So... after rebuilding my KX65 pitbike I had the confidence I could rebuild a 4 stroke, and as I turns out I can’t at least not yet. I bought a 2005 CRF250R off Craigslist for $550 and put a new crank, bearings, spark plug and gaskets in the bike (copper shavings were in the oil). But it just won’t start after getting it back together. It has back fired a few times and sounded like it wants to start but won’t. What can I check besides the timing and valves? Am I just not kicking it hard enough lol maybe I should stick to little 2 strokes. Thank you very much for any and all help!
  2. pro69ss
    pro69ss Adventurer
    Aug 28, 2018
    84
    St Petersburg
    Did it run before rebuild ?
  3. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    6,101
    below the sea
    Any ie engine needs fuel, ignition and compression. Start there.
  4. Raindog18
    Apr 20, 2015
    45
    Montana
    Nope I bought it and the oil had large chunks of copper in it, so I just took it apart right away.
    Well it would have spark if the bike fired for that split second, fuel also and it does take a good kick to get the motor to turn over. I’ve rechecked the valves and timing everything seems to be good. Maybe a wire is undone that I missed?
  5. cedric
    cedric Been here awhile
    Nov 7, 2006
    262
    Calgary
    Are the valve clearances within the specs? Those bikes were notorious for valve issues.
  6. neil w
    neil w Been here awhile
    Jan 13, 2013
    218
    Check the timing isn't 180 degrees out
    jake28 and Bultaco206 like this.
  7. Raindog18
    Apr 20, 2015
    45
    Montana
    Yep the valves are in spec. For the timing it’s have the cam lobs facing back and line up the timing marks in the case correct?
    Also today I put new gas and sea foam in. It was a little closer but still didn’t. Maybe try rebuilding/cleaning the carb?
