2005 R1200GS whats up with the brake light delay?
Discussion in 'GS Boxers' started by mouthfulloflake, Aug 4, 2019.
  1. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    37,174
    The Berkeley of Arkansas
    It as like its driven by the servo and not the front brake lever.
    The rear (foot) brake lever seems to actuate it pretty solidly.
    the front brake handlebar lever however, doesnt seem to turn it on or OFF>
    only turn it on and then wait a bit and maybe turn it off later?
    what am I missing with the abs/servo set up on this bike?
  2. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    Usually that is the microswitch in the front brake.
  3. mouthfulloflake
    Aug 21, 2008
    37,174
    ahhhh, ok!
    its not easily visible like the 1100GS
    I will check that though Jim thanks.
  4. mouthfulloflake
    Aug 21, 2008
    37,174
    Ok 3 times in the last couple of weeks the ABS warning never goes away, and one time I actually had VERY little brakes
    I had to coast to stop, turn of and restart, and then the servo returned.
    yesterday, the light just continued to flash as I rode off, so I stopped and reset it again.
    am I doing something wrong in the start up procedure?
    yesterday I was parked on a hill so I was holding the front brake the entire time during the start up sequence, did that cause the error?
  5. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    8,950
    DC metro
    Presume you've bled the brakes & pump... My own '05 doesn't seem to mind whether I hold the lever during start up, or not.
    Residual braking is not something that I've experienced, but my understanding is that the effect is disconcerting to practically frightening. Surely that depends upon speed.
    If fresh fluid, I'd make sure the battery was fully charged and then go out to vigorously exercise the ABS on dirt road or long patch of grass. If the pump functions as expected, I'd feel good about that.
    Bottom line, I don't think it has anything to do with your start up sequence. I'd worry about dirty or low fluid, but if that' not the case then the pump would get my attention.
    Otherwise, are the bike's electricals all in good order? And nothing on a gs911?
  6. mouthfulloflake
    Aug 21, 2008
    37,174
    I dont have a GS911 so i no idea there.
    Ill read how to flush and bleed, I have ZERO concept of whats involved on this bike, nor when it was done last.
    Thanks for the feedback.
  7. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    8,950
    DC metro
  8. mouthfulloflake
    Aug 21, 2008
    37,174
    thanks, I was just searching for those haha
    #8
  9. Desert Skies
    Desert Skies One brick shy...
    Mar 2, 2004
    2,614
    Tejas
    It still may be related to the front brake brake light problem. You have that issue sorted out yet?
    #9
  10. mouthfulloflake
    Aug 21, 2008
    37,174
    Not yet
    Been too hot to do much
    I leaned it against a wall in the garage and I'm riding the other bikes
    #10
  11. Desert Skies
    Mar 2, 2004
    2,614
    Tejas
    Yeah, it's too frickn hot down on the coast for me to ride. All my bikes are on maintainers, I'll be getting them ready for riding season around October.
    #11
  12. mouthfulloflake
    Aug 21, 2008
    37,174
    Rain the next three days here
    But only a high of 94 (104 index I think)
    Yeah I'm thinking a Honda Prius sounds nice right now
    #12
    JimVonBaden likes this.
  13. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    8,950
    DC metro
    Having grown up on the deep South, the car or engine is often less important than the a/c that it runs.
    #13
  14. mouthfulloflake
    Aug 21, 2008
    37,174
    Good point.
    and I do not think they make most cars AC systems like they used to.
    at least many that I have driven/ridden in.
    the days of the YORK compressor using 5HP off the crank pulley are gone.
    #14
  15. mouthfulloflake
    Aug 21, 2008
    37,174
    got home from work today ( riding the DR650)
    roll 2005 R1200GA out into the drive way to start trying to diagnose whats going on with the brakes.
    key on, NOTHING
    totally dead.
    battery voltage at 5.45volts
    BRAND new Deka battery 2 weeks ago, was good and charged by me, bike was started and ridden repeatedly, I think it has sat for a week without being started?
    this is getting godamned ridiculous.
    someone come with a trailer and get a good deal on a really pretty red 1200GS
    #15
  16. mouthfulloflake
    Aug 21, 2008
    37,174
    charged the battery up.
    started up
    idles for about 45 seconds and then dies.
    At this point I will just part it out.
    bmw went south WAY south after 2003..
    #16
  17. mouthfulloflake
    Aug 21, 2008
    37,174
    finally revved the hell out of it and got it to stay running for a bit, rode around the block
    ALL error lights go out, but the front brake is hanging, NOT always, but most of the time.
    the bike is basically unsafe to ride, at any speed over 30MPH
    and it is obvious when coasting that the front brake is hanging and then not..
    tail light is ON all of the time, front switch might be the culprit.
    I can not imagine ever trusting this over complicated piece of junk to ever go very very.
    you guys riding these bikes around have way more balls ( or credit card) than I do.
    #17
  18. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    8,950
    DC metro
    That's obviously, and understandably, frustrating. Ugh.
    If the battery is certain to be good, then there's an unexpected drain.
    Any added accessories? If not, I'd consider a search a la @roger 04 rt. That's not the easy path, but it's useful.
    And have you tried disconnecting the neg. (-) battery cable when the bike is unattended? Easy to do on a 1200.
    #18
  19. mouthfulloflake
    Aug 21, 2008
    37,174
    No i have not considered disconnecting the battery while unattended, because that is silly.
    because I dont do that for other bikes, cars, boats, or jetskis typically, for 10 days.... haha
    I removed everything from the battery other than the factory wires.
    this is just a lemon, a bad one.
    is it worth more as is, or in parts?
    that is what im trying to decide right now.
    very dissappointing.
    it makes good power, and SOMETIMES has good brakes.
    those are the only advantages over my old 1100
    the unreliability and sometimes surprise NO BRAKES, is a deal breaker, so back to the good old reliable 1100GS
    #19
  20. Desert Skies
    Mar 2, 2004
    2,614
    Tejas
    Sorry you're are giving up Matt, I sure liked the 110K I put on mine, quirks aside.
    #20
