2006 gs1200 brake failure flashing lights
Discussion in 'GS Boxers' started by sergito, Jul 29, 2020.
  1. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    hi i got 06 gs1200 with the abs ( red triangle) and the brake failure light flashing really fast,i replaced the front abs sensor(it had a hole on it) and now the lights still flashing,not sure if i need the obd scanner to reset the codes?
    i tried the abs on off and nothing,also cable from the green-blue from the round obd plug to the negative to the battery and the abs button for 8 seconds.
    whats next???
  2. Desert Skies
    Desert Skies One brick shy...
    Mar 2, 2004
    2,613
    Tejas
    Scan with GS911 to get fault code.
  3. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,707
    DC metro
    Is the battery certain to be fully charged? And when was the brake fluid last thoroughly flushed?
  4. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    If you don't have owner's manual, you should download one for free from the interwebs. The sequence and frequency of ABS brake lights flashes (if bike is equipped with ABS servo brakes) is explained during the self diagnosing so you first establish that there is an issue, if indeed it is the case...
    Then, in misfortunate case you'll have to deal with one, you can proceed with GS911 scanning reading the codes etc...
  5. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    12.45v unsure of brake flushed bout it used cheap like that with the lights
  6. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    kk gonna download it now and count the sequence thanksss
  7. b4thenite
    b4thenite Long timer
    Oct 14, 2008
    1,214
    Korea Town, Los Angeles,
    Could be many things. Check all physical elements first. Brake lever, rear brake sensor, bulbs, etc.
    I had to replace small parts on brake lever once. When I dropped the bike the rear brake pedal was miss aligned and it resulted ABS sensor malfunction. Other times it was a bulb that needed to swap. Good luck and let us know.
  8. Chuck Roll
    Chuck Roll Lazy
    Feb 15, 2004
    4,180
    Duvall, WA.
    When it happened on my 07 , a abs pump was the culprit , a rebuilt one fixed it .
    #8
  9. 0neTrackMind
    0neTrackMind Motorcycle Mechanic
    Apr 2, 2010
    33
    Puget Sound
    2006 was a different animal. Power brakes. If bought cheap, there is likely deferred maintenance...
    OP needs to follow guidance above first.
    #9
  10. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    Hi,i just checked all fisical elements, back bulb works as it should,brake switches work too,i can hear the servo pump pretty loud tho,diferent sound for each brakes,how can i check the level on the main pump? Abs servo pump? Might need some oil there? Im borrowing an scanner tomorrow but not really sure what it is,i thought the broken ans sensor was the issue.
    #10
  11. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    Yeah bought it cheap coz of the lights flashing lol
    #11
  12. * SHAG *
    * SHAG * Unstable
    Nov 28, 2001
    5,652
    Bradford, Pa
    Have you ridden the bike? Do the brakes work?
    #12
  13. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    Yeah drove the bike with the lights,it breaks ,
    #13
  14. postoak2112
    postoak2112 Javalina
    Jun 5, 2016
    55
    Austin, Tx
    just make sure your break lever is fully releasing. i crashed my '06 and when i got her back up
    long story short the hand protector had shifted such that it wouldn't allow the break lever to fully release.
    good luck
    marty
    #14
  15. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    32,423
    The Berkeley of Arkansas
    My 2005 did this off and on
    Brakes would work great
    Then not work
    Then sometimes drag and engage themselves
    I ripped that servo ABS junk off and
    Now the brakes work wonderfully
    #15
  16. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    Hi guys update, i borrowed the scanner and this happened lol deleted them and now i only have the fluid level coming up,i also got other codes for engine and the alarm system i deleted them tgey are not back for now,tomorrow i will flush the system and will get back to you guys,thanks for the help
    #16
  17. PerazziMx14
    PerazziMx14 Been here awhile
    Oct 9, 2011
    943
    I just bought an 05 last Monday knowing the idiot lights were illuminated. Got it home flushed the servo unit and the fronts were good rear Elias dead. Wednesday this is what was on the garage floor
    #17
    mouthfulloflake and sergito like this.
  18. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    Fixed???
    #18
  19. Lead Wrist
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    Fixed as in removed and discarded...
    #19
  20. sergito
    sergito Adventurer
    Jul 29, 2020
    14
    bc
    I saw u. An fix them on YouTube,
    #20
