2007 R1200GS Starting problems post servicing.
Discussion in 'The Garage' started by Scottonthelam, Aug 21, 2019.
  1. Scottonthelam
    Scottonthelam n00b
    May 7, 2016
    6
    Canada
    Hi all I'm looking for some suggestions, my bike was running fine until I had the ABS system bled. The tank has to come off to service the ABS system on this bike and ever since the service the bike only starts intermittently. Can anybody help?
  2. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    You will find much more information if you delete this post and pose the same question in the GSpot forum which is where GS folk hang out.
  3. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,939
    Anchorage, formerly Spenard (hub of the universe)
    1st thing is to check that the throttle cables are properly seated in the injector bodies
  4. Scottonthelam
    Scottonthelam n00b
    May 7, 2016
    6
    Canada
    Thank you.
  5. Scottonthelam
    Scottonthelam n00b
    May 7, 2016
    6
    Canada
    Thanks I’ll check that.
  6. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    6,064
    Phoenix
    Take tank off
    Verify all routing and connections are secure
    Start with tank off
    Verify operation
    Reinstall tank
  7. groop
    groop So much to ponder
    Jun 5, 2007
    6,212
    oc, ca
    Also, the 2007 was subject to a fuel pump recall. Did the tech do the recall repair at the same time as the ABS since he had the tank off?
  8. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,943
    Hiding off Hwy 6, B.C.
    All that is saying is that you have never seen a 2005-07 BMW 1200GS fuel tank.
    Until they move this thread where it should be......maybe the OP could confirm that the fuel pump runs briefly to prime the fueling system when turning on the ignition.That is everytime the ignition is cycled On.No pump whirring everytime I'd think the FPC (fuel pump controller) is starting to act up and will fail shortly as many others have.
    #8
