2008 F650/800gs abs removal
Discussion in 'Parallel Universe' started by kito, Jul 7, 2020.
  1. kito
    kito Been here awhile
    Mar 8, 2009
    509
    cheshire , England
    has anyone any experience of removing the abs ? I’m ok with nuts n bolts so to speak but wondering about the wiring . Iv tried googling but only found a video on YouTube that I think was in polish so only limited help.
  2. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    374
    Fannystelle
    Why ?
    Arbolmano likes this.
  3. Motoriley
    Motoriley Still riding like crap after all these years.
    Feb 14, 2003
    3,136
    Deepest darkest burbs of Montreal
    You could just disable it permanently unless you really want to get rid of the plumbing.
  4. kito
    Mar 8, 2009
    509
    cheshire , England
    I want the whole system gone
  5. FinTec
    FinTec Been here awhile Supporter
    Sep 27, 2013
    574
    Colorado
    kito: I did remove the entire ABS system from my 2013 F800GS. It helped create a lot of room for some of the other upgrades I made to the bike and dropped a chunk of weight. However, one issue that really made it tough for me: the front brake light. The ABS sees your front brake pressure change and activates the brake light. So if you unplug the ABS unit your brake light stays on. However, on pre-2013 I belive this is not the case. If your front brake lever has a micro-switch then the ABS is not controlling the brake light like 2013+ models.
    Can read my work on removing ABS on my build thread here:
    https://advrider.com/f/threads/an-800s-rebirth-the-build-of-mechanico.1030354/page-8#post-26434820
  6. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,201
    Lanark County near Ottawa ON
    I am pretty sure that pressure activated switches are ready available and can be plumbed in wherever convenient. Would need to extend the wiring.
  7. kito
    Mar 8, 2009
    509
    cheshire , England
    I read your excellent thread in full a year ago but have recently been looking through it again. I seen you know your way around a bike an had some issues that had me worried. My bike is a 2008 so hopefully easy to do as I’d like to fit the nuda battery box
  8. FinTec
    Sep 27, 2013
    574
    Colorado
    Yep, I suspect yours being a 2008 it will have a switch on the front brake which means you are good to go. You might get a CEL on the dash, but you'll live.
    #8
