2008 F650gs
Discussion in 'Parallel Universe' started by obsidian, Sep 14, 2008.
  1. obsidian
    obsidian Scared of the dark..
    Nov 21, 2007
    837
    Currently in Canada.
    Just curious if anyone has opinions or thoughts about the 650GS for fire roads and gravel roads? Will the rims be ok for that sort of riding?
  2. JRWooden
    JRWooden never attribute to malice...
    Jul 5, 2008
    6,983
    North Carolina
    As far as I know we have no first-hand reports (good or bad) on the 658 cast rims.
    While they are cast rims, they look more beefy than many I have seen. Also, apparently the 800 spoked rims aren't really as beefy as you might suspect...
    See the pictures at the bottom of this page:
    http://www.ukgser.com/forums/showthread.php?t=154536
    So ... you might buy an 800 and STILL decide the rims are not "fit for purpose" ? :huh
    Jim
  3. blackie
    blackie Been here awhile
    Dec 18, 2007
    434
    Cowgary, AB
    Been riding mine on fire roads. No problems with the rims. Tire are a different story. The stock ones are fine for normal travel but if you plan on more aggressive riding especially on loose dirt/gravel knobbies like the TKC would be better.
  4. RobTheRigger
    RobTheRigger Killing threads here since 2008
    Jul 19, 2008
    674
    SW Idaho
    Chatting about this on another thread. Blackie, what do you think about throwing some X Country rims and knobbies on the 650 for a little more serious dirt riding? Not motocross, but not groomed dirt roads either.
    -Rob
  5. blackie
    Dec 18, 2007
    434
    Cowgary, AB
    Sorry didn't see this earlier..
    The xcountry rims might work if it fits....
  6. RobTheRigger
    Jul 19, 2008
    674
    SW Idaho
    From the BMW website.
    F650GS
    <TABLE class=alternatinRowsTable id=wheels_tires_spec_table cellSpacing=0 cellPadding=0 border=0><TBODY><TR class=rowA><TD class=propName scope=row>Front Wheel</TD><TD class=wide>2.50 x 19 cast aluminum</TD></TR><TR class=rowB><TD class=propName scope=row>Rear Wheel</TD><TD class=wide>3.50 x 17 cast aluminum</TD></TR><TR class=rowA><TD class=propName scope=row>Front Tire</TD><TD class=wide>110/80 x 19 tubeless</TD></TR><TR class=rowB><TD class=propName scope=row>Rear Tire</TD><TD class=wide>140/80 x 17 tubeless</TD></TR></TBODY></TABLE>
    XCountry
    <TABLE class=alternatinRowsTable id=wheels_tires_spec_table cellSpacing=0 cellPadding=0 border=0><TBODY><TR class=rowA><TD class=propName scope=row>Front Wheel</TD><TD class=wide>2.50 x 19 wire-spoke</TD></TR><TR class=rowB><TD class=propName scope=row>Rear Wheel</TD><TD class=wide>3.00 x 17 wire-spoke</TD></TR><TR class=rowA><TD class=propName scope=row>Front Tire</TD><TD class=wide>100/90 x 19 tube-type</TD></TR><TR class=rowB><TD class=propName scope=row>Rear Tire</TD><TD class=wide>130/80 x 17 tube-type</TD></TR></TBODY></TABLE>
    Hope this helps.
    -Rob
  7. blackie
    Dec 18, 2007
    434
    Cowgary, AB
    Yeah the numbers look about right, just wondering about the other stuff like brake rotor, sprocket mounts etc if those will fit too.
  8. RobTheRigger
    Jul 19, 2008
    674
    SW Idaho
    That and axle spacing, too.
    #8
  9. mrpete64
    mrpete64 Been here awhile
    Feb 11, 2007
    634
    I am seriously considering the 650 due to the fact that I "fit" better on it. I broke right leg and it is easier to throw my leg over the 650 due to the fact that is a bit lower. My only concern is that I want to go to South American on it and wonder about the cast wheels. I really don't think that I am going to "bash" it over big rocks/trees/and truck parts if I can help it.
    I appreciate any "insights" you might offer about the cast wheels. I realize that if one hits anything big enough it will take out either type of wheel.
    Again...thanks for you comments.
    Mr. Pete--->
    #9
  10. blackie
    Dec 18, 2007
    434
    Cowgary, AB
    Cast rims -> Tubeless tyres -> easier to repair punctures on the side of the road :1drink
    #10
  11. huckleberry
    huckleberry BACK ROAD BOMBER
    Sep 19, 2008
    1,108
    N.E. Pa.
    what he said!--that was 1 of the reasons i went with the 650 over the 800 have been bombing around on dirt roads since i got mine and think its great! don't even mind the tires-mind you i'm not trying to maintain dakar speeds- but running 40-60 mph its cool have 1100 miles on and about 1/2 is dirt
    #11
  12. RobTheRigger
    Jul 19, 2008
    674
    SW Idaho
    #12
  13. Navaho
    Navaho Long timer
    Oct 31, 2005
    1,093
    Baton Rouge, LA
    I think that as long as you maintain good pressure in the tires (over 30 psi) the rims will be ok for almost anything you would attempt on the 650. I went uphill on two long runs of concrete steps last week and the rims survived. Maybe not much of a test as hitting a pothole at over 60 but just don't think that there's much to worry about if you keep the psi up.
    #13
  14. RobTheRigger
    Jul 19, 2008
    674
    SW Idaho
    Don't you usually air down for off-road?
    When are you planning on modding your 650 for a trials bike? :D I don't have any stair climbing skillz!:bow
    -Rob
    #14
