2008 weestrom starting issues
Discussion in 'Japanese polycylindered adventure bikes' started by Sonuvasailor, Sep 9, 2019.
  1. Sonuvasailor
    Sonuvasailor Adventurer
    Oct 5, 2011
    48
    Atlanta, GA
    Hello everyone
    Fresh oil, fresh battery, 3/4 tank of gas.
    Starter spins but it won’t turn over.
    Any thoughts would be helpful - thanks
  2. pixilated
    pixilated Been here awhile
    Jan 14, 2016
    338
    6,300 ft.
    Check for spark at plug:
    Pull a plug and lay it on the block with plug wires still attached. Make sure the metal/hex on plug is touching the block (the block grounds the plug). Hit the starter and watch for spark.
  3. i_4ce
    i_4ce Been here awhile
    Jul 7, 2005
    335
    SLC, Utah
    I got an 07 and just had the fuel pump die a week ago. You can listen to hear if the fuel gets primed. or You can lift the tank and disconnect the fuel line, attach another line and drain to see if fuel is primed when you turn the motorcycle on.
  4. dtysdalx2
    dtysdalx2 Just glad to be here.
    Aug 1, 2004
    26,806
    Moneyapolis, MN
    Rock it back and fourth in gear. Maybe starter clutch is hung up.
