2009 F 650 GS cush blocks
Discussion in 'Parallel Universe' started by auntieweenie, Jul 10, 2011.
  1. auntieweenie
    auntieweenie n00b
    Jul 4, 2011
    3
    My boyfriend was changing my tire and has noticed that on the rubber cush blocks , on the small part there are different numbers. 2,3,5, &11. All the blocks look the same. Is there a particular sequence that they should be re-installed in the hub? He doesn't seem to think that there is because they all seem the same size, but I just want to make sure.
    AuntieWeenie
  2. huckleberry
    huckleberry BACK ROAD BOMBER
    Sep 19, 2008
    1,108
    N.E. Pa.
    to the best of my knowledge they are all the same/ Mine have come out many times and i never checked to make sure each 1 went back where it came from ,with no problems yet.
  3. auntieweenie
    auntieweenie n00b
    Jul 4, 2011
    3
    Thanks a bunch. Now on to the front...
    Weenie
  4. JRWooden
    JRWooden never attribute to malice...
    Jul 5, 2008
    6,974
    North Carolina
    My guess would be that those number are the "mold cavity" numbers ...
    when parts are molded they usually mold a bunch of pieces at once to save time.
    They put a small number somewhere on the mold cavity for each piece so that if there is a problem with the quality or the dimensions of the part they can try to trace it back to the individual cavity that is responsible.
  5. markymcd
    markymcd Been here awhile
    Sep 18, 2008
    927
    Vancouver, BC, Canada
    they're definitely the same.. i've had the wheel off many times... 650 and 800 wheel uses the same rubber too.
    doing anything with the front is a piece of cake compared to the rear. Especially tires!
    Mark
