2009 F650GS twin running tube tire shinko 705?
Discussion in 'Parallel Universe' started by 1994klr250, Sep 19, 2012.
  1. 1994klr250
    1994klr250 Long timer
    Aug 16, 2007
    1,350
    Southeast michigan
    One of my riding buddies has an 09 F650GS twin with the cast tubeless wheels. Without knowing he ordered a rear shinko 705 140/70-17 that was tube type. I'm used to spoke wheels on my F800GS and KLR250 so tubes are nothing new to me. Would it be fine to put a tube in his rear tire and run the shinko 705? The only thing I'm not sure about is how to get the valve stem out of his rim without destroying it. I looked on the max bmw parts fiche and it looks like a standard auto type valve stem. Is it possible to remove the valve stem and be able to reuse it for the next tubeless tire? His bike does not have the tire pressure monitoring system so that's not a worry. Any info on this would be great thanks, Fred.
  2. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,429
    Penticton, BC, Canada
    I have run tube type tires on tubeless rims in the past with no issues. Sometimes a small amount of air will be lost weekly as there is not quite as good a seal to the rim (not always though). I'd say spoon it on and see how bad it leaks.
  3. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    9,097
    Southern Illinois USA
    It will be fine to run a tube with that wheel/tire. It's a cheap ass automotive stem! Just cut it off and buy another. Geeeeesss itÂ’s not a KLR.:rofl<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  4. 1994klr250
    Aug 16, 2007
    1,350
    Southeast michigan
    Thanks for the info, Once we get it spooned on I'll see what happens, Fred.
  5. Mr_Wilson
    Mr_Wilson Been here awhile
    Aug 27, 2006
    131
    Crystal River, FL
    I just finished a 4,000 mile trip to Colorado / Wyoming on that tire without a tube. No problems. I did use about half the tread, so I'm not expecting over 8,000 miles from it. I lost maybe 4 psi duing the two weeks.
  6. TowPro
    TowPro Single Track Geezer
    Aug 21, 2009
    4,959
    A mixed blessing
