2009 RT ESA
Discussion in 'The Garage' started by Beemer Bob, Sep 6, 2019.
  1. Beemer Bob
    Beemer Bob Long timer
    Jun 30, 2009
    4,601
    Beautiful Downtown WV
    Pushing the ESA button changes the mode from Comfort to Normal to Sport but when holding the button down to change the rate nothing happens. Any ideas?
  2. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,218
    Central Ohio
    Are you stopped, in neutral?
  3. Beemer Bob
    Jun 30, 2009
    4,601
    Yes engine off ignition on.
  4. Jeffrop
    Jeffrop n00b
    Apr 22, 2018
    6
    Marietta, GA 30062, United States
    I have same year and model. I have engine on, in neutral, hold down ESA for 5 seconds, then press and release button till desired setting shows. Icon should blink while being adjusted and goes solid when finished
  5. kasuckmo
    kasuckmo Been here awhile
    Jun 21, 2018
    320
    fl
    When mine did the same it was a weak motor in the rear shock. Time to toss the esa or don’t worry about it. If your at 50k it’s new shock time anyway
  6. AviatorTroy
    AviatorTroy Long timer
    Oct 15, 2007
    2,413
    Castle Rock, CO
    Not sure about the RT but my same year GS has to have the engine running and in neutral for that to work. The comfort norm sport thing works with engine off.
    mitchapalooza likes this.
  7. mitchapalooza
    mitchapalooza Rider is Air-cooled Supporter
    Sep 1, 2010
    406
    Castle Rock, CO
    2009 gsa needs motor running to change stuff
