2011 R1200GSA Acceleration Issues
Discussion in 'GS Boxers' started by Moonmanzn, Apr 19, 2020.
  1. Moonmanzn
    Moonmanzn Adventurer
    May 17, 2019
    46
    United Kingdom
    Good Afternoon Sir's/Ma'am
    Hope you keeping safe during the current climate.
    Im military and still in work, my commuter bike is giving me issues.
    2011 R1200GSA with 18k Miles.
    Bike pulls very well through all gears until in 6th and on motorway at 80mph, accelerating from there seems very strained and held back, have ridden a r1150r and that pulls much better than mine.
    Fully serviced and valves and TBs checked and synched.
    Fuel controller and fuel pump replaced.
    Injectors replaced
    New battery
    New primary coils
    Bike will start and ride till 40mph on secondarys.
    Brand new plugs all round.
    Fuel is new
    Vent hoses clear
    No kinks in fuel lines
    TPS swapped with good one from working GS
    Adaptions reset on GS911
    02 Sensors seem to swing between 0.3 and 0.8 but have been up to 1100mv?
    Bike has a akropovic full decat system installed.
    I bought the bike, babie dit home as been stored 12 months, fitted exhaust an dthen did a major service.
    Had the flat spot issue since owning it and have slowly replaced all parts as listed above to no avail.
    Swapping back to stock exhaust tmrw and buying new secondary coils seems my last options.
    Any help greatly received.
    Have a gS911 log from a run if anyone is well swept up on the values contained.
  2. ultane
    ultane sqeezin the bag
    Feb 20, 2008
    4,460
    The dry side of the blood brain barrier
    Welcome to the forum! Lots of smart folks here. I’m sure someone will be able to help.
  3. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    Thank you very much, have already emailed a log over to a gentleman who seems very knowledgeable and hopefully he sees something amiss.
  4. ultane
    Feb 20, 2008
    4,460
    Any update?
  5. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    8,855
    Sunshine Coast B.C.
    You may have a fuel supply issue at high loads.
    At this point I would rig up an inline adapter setup using M&F quick disconnects and a pressure gauge.
    You are looking for 4 bar normal running.
    Go out on a road test and flog it while watching for a drop in fuel pressure.
    If so, there could be an issue with
    The pump controller
    The primary filter sock
    The hose from the pump output to the upper filter chamber (crack)
    The upper filter chamber clogged
    My rig
    mitchapalooza likes this.
  6. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    GS Addict, Sir, thank you for reply.
    I have a new pump, controller coils etc out.
    I took pump out again and rigged power to it without controller was showing 130psi, 100 psi with controller connected.
    bike running and idling the psi was 60, dropping to 54/55 and high speeds.
    so looks like 4 bar and dropping to 3.5 and the top end.
    The bike should stay at 4 bar at all times im assuming?
    only thing left is the "hidden filter" has clogged?
    I back flushed it but with 18k on the clock the cleaning fluid/petrol ran clear, no gunk at all.
    So internal housing must have collapsed as stood in storage for 16 months.
    Could i have your thoughts, as a new housing is 450 dollars.
    Lastly, running without the fuel controller, pump obviously at 100% and that made a noticeable difference, as well as my brothers F800GS fuel assembly loosely inserted into tank.
    Both these times the bike seemed to pull strongly to 7k
  7. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    lastly Sir, did a flow test off the right side disconnect to a bucket, I was getting 570ml in 30seconds.
  8. GS Addict
    Sep 24, 2006
    8,855
    Sunshine Coast B.C.
    The above all looks good IMO.
    I'm not concerned with 3.5 bar at top end - plenty of pressure for the injectors.
    #8
  9. GS Addict
    Sep 24, 2006
    8,855
    Sunshine Coast B.C.
    Also good.
    #9
  10. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    Then I am very much stumped.
    Drop in pressure was only thing that was highlighted in all the tests and gs911.
    Only way I can make the bike accelerate better is disconnecting the controller or someone elses pump housing.
    I'm at a loss
    #10
  11. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    #11
  12. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    Hi Sir, sucking pump is fine, and clear. My issue is the bike seems fuel starved at high rpm. 6k for example, bypassing controller and a diff housing make sit run much better.
    only logical thing is that the hidden fuel filter has collapsed or partially blocked.
    already cleane dit and the fuel/cleaner mixture was clean as a whistle. so much be collapsed etc and strangling the flow at high rpm as i see a 1/2 ba drop in fuel pressure at wot
    #12
  13. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    8,952
    DC metro
    You've already swapped in a borrowed or replacement fuel pump, and the bike then ran "strong" as you expected it to at higher rpm?
    Here in the States, we can get those pumps for only about US$150...
    https://www.euromotoelectrics.com/product-p/fp-379.htm
    That's a relative bargain compared to BMW's list for the whole assembly. Shipping affects final cost, however. Does Nippy Norman list anything similar? Motobins, etc.?
    #13
  14. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    the pump is brand new, the actual housing with locked away filter is the 450$ issue. the pump on my assembly is new and tested at 130 psi.
    with fuel controller bypassed the pump is at 100% at alll time so negates my symptoms, say 50%. another whole assembly make sthe bike run very well.
    only thing left in the problem equation is the filter in the assembly
    #14
  15. GS Addict
    Sep 24, 2006
    8,855
    Sunshine Coast B.C.
    Normally I cannot see 1/2 bar starving the system for fuel, but when checking my reprom specs it shows 3.5bar operating pressure for the Hexheads and 4 bar for the Camheads.
    Something to add to the list.
    #15
  16. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    yes this is also what it noted, hence bike runs very well at rpm till 5500ish then when i open it at say 80 or 90 its slowly pulls to 110 etc.
    my 1100gs pulled better at higher rpm, so definitely starvation.
    #16
  17. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    8,952
    DC metro
    If I'm reading the above correctly, then I'd try bypassing the FPC with either the dongle that Burns Moto sells or else a length of paired wire. Who am I kidding? I'm cheap and would go with the paired wire.
    And if the bike runs as desired / expected with the FPC bypassed then either the FPC itself is bad, or else the wires (2) between the FPC and the fuel pump are the problem. But maybe I'm misunderstanding the swap & testing discussed above.
    #17
  18. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    i ran the bike with the FPC bypassed, with wire, and it ran better. good shout on the wires running through housing. can check them out. but unit has 18k and looks clean as a whistle, but a look over and continuity test might be worth it
    #18
  19. Moonmanzn
    May 17, 2019
    46
    United Kingdom
    only thought is that why the wiring is only breaking down at higher rpm only, but maybe some corrosion.
    #19
  20. GS Addict
    Sep 24, 2006
    8,855
    Sunshine Coast B.C.
    Just thinking this thru more...
    Any chance the baffles/packing have come loose in the AK silencer?
    Do you still have the stock system to test?
    #20
