2012 990 Adventure Immobilizer Location?
Discussion in 'Dakar champion (950/990)' started by Bajageorgia, Sep 11, 2019.
  1. Bajageorgia
    Bajageorgia n00b
    Oct 12, 2014
    8
    Hey all, new 990 adv owner here. The owner only had one black key and no orange key nor code card. The bike is a pristine, very very low mile bike so I decided to bite the bullet and replace the lock set and immobilizer so it would be as new. I intend to ride this thing for at least 10 years.
    I haven’t found any info on the actual location of the immobilizer. I pulled apart the fairing and headlight assembly thinking it would be up under the speedo cluster but it’s not there.
    Can anyone point me in the right direction?
    Thanks all!
  2. Bajageorgia
    Bajageorgia n00b
    Oct 12, 2014
    8
    Should have mentioned, it’s a 2012 R.
  3. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,428
    SWEDEN, Norsjö
    Has this not been covered enough that it's possible to find by searching?
    Really hope you payed very little for the bike.
    Cause to do it the right way it's ALOT of money.
    Have not really set myself into this problem but think ECU needs to be replaced. And a full lock set, just the keys with chip will cost way to much.
    There are rumors about some company being able to reprogram and remove immobilizer.
    Good luck.
    /Johan
    Bajageorgia likes this.
  4. Bajageorgia
    Bajageorgia n00b
    Oct 12, 2014
    8
    Got a great deal on it. There has been a lot of coverage. The ecu does not need to be replaced but does need to be connected to KTM diagnostic system to instruct the ecu to accept the new immobilizer. I have all that worked out. Just need to find the immobilizer to pop in the new one. Any insight on the actual location of it?
  5. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,683
    Mill Spring, NC
    Personally if it were me,, I would either send the ECU out to have the immobilizer programed out or find an earlier ECU the doesn't have the immobilizer programming.
  6. Gmc28
    Gmc28 Gmower
    Dec 28, 2011
    204
    Dirt Road Oregon
    Wow, everything offered except what bajageorgia asked.... tough crowd.
    But sorry, I don’t recall where the damn is physically located. Someone will chime in with the actual answer.
    mat_rock667 and Bajageorgia like this.
  7. Bajageorgia
    Bajageorgia n00b
    Oct 12, 2014
    8
    Ok- found it. 2012 990 Adventure immobilizer is located under the top storage compartment tucked into the frame on the right side.
    It is accessible by removing only the compartment. The tank and fairing do not need to be removed.
    Gmc28, DirtyADV and Boatman like this.
  8. PaisaMed
    PaisaMed Been here awhile
    Nov 20, 2011
    149
    Toronto, CAN & Medellin, COL
    How did this immobilizer issue end? I'm having a problem with my immobilizer and would like to bypass it completely.
    #8
  9. LilYoda
    LilYoda Been here awhile
    May 20, 2013
    428
    Thinkpad can disable them, for a fee. Send him a MP
    #9
  10. Rharr
    Rharr Been here awhile
    Apr 5, 2014
    967
    Tucson Az
    After disabled, can you still remap by uploading new map file?
    #10
  11. Jaunt
    Jaunt Adventurer
    Mar 29, 2011
    59
    Central Iowa
    Immobilizer on a 2011 KTM 990 Adventure.
    #11
