Congrats. You pick up the one on the local CraigsList? That was a good price. Depending on your preferred use, size and such.... I'm 6'3".... a high seat, bar risers and center stand were a must for me. I also converted my rear rim to tubeless using the instructions from Dave at Best Rest. I also installed fork gaitors. The Puig windscreen upgrade was nice as I'm tall. Other than that, try and get some pannier racks. Soft or hard luggage if you plan to tour a bit. Wider pegs a must. I love my heed crash bars. I've been riding the BDRs alot more comfortably now. Used to take my R1200GS A before then. Oh... get a chain guide from Ratel Engineering. I lost a chain once in the bush while riding in BC. The taller suspension on this bike requires it IMHO
I had the Puck and tore it off hopping over a log. I may get creative and mill a thick aluminum plate.
The problem with any foot extension is weight. The extra weight causes the side stand to bounce and make contact with the ground from time to time. Not particularly dangerous given where it impacts, but it can be disconcerting. I even hollowed out the extension to reduce the weight. I ground quite a lot of plastic off my "pucks" before deciding to move the mount. If you decide to move the side stand mount, it needs to move downward on the bottom sub-frame by about 1.5mm. I bought a spare sub-frame off eBay for about $20 and chopped that one up.
For relocation of the side stand, I opted for the footpeg and it works fine. I used a side stand from a 1100GS for it: See the post: https://advrider.com/f/threads/the-650-dakar-thread.441434/page-1538#post-37005322
Cool idea. Still based on the original foot peg bracket and just welded an extension to add the pivot? Any clearance issues with the swingarm or tire?
That happened to me as well. $5 for a new puck and less than 10 minutes of work drilling new holes uninstall old and install new and I've been good since. Not a show stopper on the trail.
This is a TT footpeg bracket, but should work with an original bracket too. I used a 1100GS sidestand which is shorter, no clearance issues at all.
Just wanted to make sure it was still a three-point mount like the OEM. I'd be afraid a two-point mount might twist with all that torque applied.
It is still a three point mount with bolts to the frame. It's on my bike for 9 months now without issues.
I was thinking on cutting the puck down (diameter) or milling a aluminum block. I have access to a manual mill and have some stock to use. The puck is heavy and looks too Redneck.
This was my former solution (even before I drilled out all the excess material): Hacked out on my miter saw.
One Winter project is to replace the original Coolant in the 2013 Sertao. Considering the water pump seal Achilles Heel of the 650 series, and the low volume needed, I want to use the original BMW Coolant. I don’t have a shop manual to see the recommended part number for Coolant. I know some car coolants have Silicates which should not be used in Motorcycles. I found this https://www.amazon.com/BMW-82-14-2-...00NVC48VG/ref=cm_cr_arp_d_product_top?ie=UTF8 I can not determine if this is the proper BMW Motorcycle Coolant. Thoughts?
Of course Wayne had it on his site. Carry on.... http://www.f650gs.crossroadz.com.au/Repairs/WaterPump/Coolant-Info.pdf
Pretty much all the major brands are free of silicates these days. I'd use Prestone if I hadn't bought a gallon (yes, a gallon) of the BMW stuff when I changed the coolant the first time (they didn't sell it in quarts then). If you were local, I'd give you the pint you need. I change the coolant every two years. Pump has been fine (occasional drip from the hole every now and then), but I had a thermostat go last year. Make sure to thoroughly bleed the air out. When you let the air out of the bleed screw, have the bike on its side stand. Then back on the center stand and warm the engine up with the radiator cap off. Once the thermostat opens you can top it off, put the cap on and fill the reservior. EDIT: Just read up on the newer HOAT anti-freezes. Avoid them as they generally do include silicates.
