2012 forester with 148K miles has serious rod knock. Engine is toast
Discussion in 'The Garage' started by LuciferMutt, Oct 13, 2019.
  1. Achtung
    Achtung Wicked Pisssah Adventurer
    Nov 1, 2002
    2,662
    Waltham MA
    2880BB54-4DFC-49AD-A59B-7AAAC4218CDD.jpeg D6A0FA7E-D7D6-425B-A75F-3215E34592D1.jpeg 7B6B6788-BC8B-4D33-A0B0-9F23EDEE19C6.jpeg
    I've had 3 Subies, this one was an 08 with 150k that had regular oil changes. It dropped a valve guide. I did the job myself and it still cost 2 grand. Suck part is the car lasted 6 months after the repair and had another unrelated engine failure. Should've cut my losses and split after the first failure but I bought it new and got 150,000 trouble fee miles so I'm not too disappointed. Ended up selling it to the dealership and walking away.
    #41
    concours and spokester like this.
  2. concours
    concours WFO for 47 years
    Dec 2, 2008
    7,169
    Kensington, NH USA
    So my 2001 VW TDI I drove 630,000 miles, never had the head or oil pan off, is looking pretty good now...
    #42
  3. Achtung
    Nov 1, 2002
    2,662
    Waltham MA
    That's more in line with what I would expect from modern engineering. Honestly I'm just trying to look on the bright side.
    #43
  4. Adanac rider
    Adanac rider O.S.T.R. Supporter
    Dec 5, 2006
    1,218
    N.V.I.
    I wonder if moms cars would last longer if she stopped lending them out ? :hmmmmm
    #44
    concours likes this.
  5. showkey
    showkey Long timer
    Jun 25, 2007
    2,359
    Wausau
    Couple for thoughts:
    Modern engine oil light ............should say “JUNK ENGINE”.......low pressure at speed the engine is done.
    Oil pressure gauge.................is only good if you watch it and know good from bad pressures. 20# at 6k-8k is junk engine time.
    Rebuilding a modern engine............rarely makes economic sense, when shop labor rate is $100-$200 per hour.
    "......................................................add parts at retail, no oil pressure means crank, heads, cams, valve train, piston rings etc. machine work like boring. Short block or long $8500 might actually be cheap. German MB, Audi, BMW rebuilds might start at $12k
    Sprinter engines start at $13k and rebuild parts like cranks and oversize pistons are N/A
    #45
  6. BLZ2DWL
    BLZ2DWL Roustabout Supporter
    Sep 13, 2007
    272
    SW VA
    '98 Legacy with 2.2, sold it with 225k on it still running strong.
    '05 Outback with 2.5 (5spd), sold it with 215k on it still running strong.
    '13 Legacy with 2.5, sold it with 70k, obviously still running strong.
    Never replaced anything more than a few wheels bearings and valve cover gaskets. Most dependable cars I've ever owned. I bet for ~$2k an independent shop can put a rebuilt or salvage motor in it. Fix the oil light while you're at it.
    #46
  7. sjc56
    sjc56 Long timer
    Oct 26, 2006
    2,066
    Broad Brook CT USA
    2012 Forester running fine at 112000. But then I am on my second replacement motor (warranty thank god) which was put in at around 80k and my center dif was replaced at 93K, I had the extended warranty that the PO bought with the car also a right drive shaft was done also under warranty. Not sure if I should keep or get out while it is still going good. And this motor is now using a quart and a half every 2K. Other then that it's a great car that works for me. CRV's are looking good.
    #47
  8. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    2,007
    Flaw'da
    My boss has a '99 F-350 with a 7.3. Just helped him do s fluid change. 398,902 miles. It failed an injector once. A customer has one with 600k+ miles on it. I have a '99 Ford/Mazda Ranger 2.5 with 310k miles that still does not use a whole quart of oil between changes. Good maintenance goes a long way.
    #48
  9. showkey
    showkey Long timer
    Jun 25, 2007
    2,359
    Wausau
    #49
  10. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    14,831
    the hills
    An engine has two big enemies. One already mentioned here is poor maintenance. The other is it has a finite life under maximum load. The more you use it the faster it wears. High output small bores are particularly susceptible to #2. That's why my '17 WRX doesn't see a lot of high boost operation. And the current FA20 has great mid-range torque making it unnecessary. Drive like you stole it was coined by a dealer. And never forget shit happens. :D
    #50
  11. Achtung
    Nov 1, 2002
    2,662
    Waltham MA
    Almost all those 2.5 Subie motors blow head gaskets and drop valves around 150k. It's just a bad design. No amount of maintenance will help.
    #51
    sieg, showkey and concours like this.
  12. concours
    Dec 2, 2008
    7,169
    Kensington, NH USA
    As previously stated. They must drive awesome, for people to love them as they fail...
    #52
    sieg and showkey like this.
  13. Ibraz
    Ibraz Been here awhile
    Feb 11, 2017
    402
    Québec
    Guess there's always worse... My ex's Nissan Versa. Two engines and two transmissions (second ones 200 miles before waranty expired) in 60k miles.
    Pile of junk...
    #53
  14. layinlow61
    layinlow61 Been here awhile
    Dec 15, 2009
    238
    Salisbury
    Yup...love them at first....then the issues start! :hair
    #54
  15. concours
    Dec 2, 2008
    7,169
    Kensington, NH USA
    I know they were cute at $2000....
    1972
    $32,000-$42,000.... not so much
    Door still closes with the feel of folding a cheep lawn chair.
    #55
  16. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    15,963
    New(er) Mexico
    Well, she replaced with a 2019. :rolleyes At least the dealer honored the $5000 trade in agreement, actually giving them a bit more than that towards the new one.
    #56
  17. concours
    Dec 2, 2008
    7,169
    Kensington, NH USA
    Monopoly money.
    #57
    sieg and LuciferMutt like this.
  18. concours
    Dec 2, 2008
    7,169
    Kensington, NH USA
    #58
