2012 KTM 500 EXC as a Lightweight Dual Sport
Discussion in 'Thumpers' started by harcus, Dec 3, 2011.
  1. The Walrus
    The Walrus Gone and back again.
    Nov 9, 2003
    9,789
    Freshly minted Millcreek
    Had a plugged fuel filter, that OEM POS that's inline just before the throttle body. It was pretty obviously fuel starved. I used some adjustable fuel clamps and the Autozone FF1203DL filter. Spliced them in to the line which lengthens it nicely, easy connection to the quick disconnect. I didn't even open up the throttle body....Looks like this:
    Bike turned over and fired right up....tighten the clamps.....quick spin to verify and back in the saddle again.....:1drink
    Edit: Quick thanks to harcus for the tips and consults....
  2. HeadintheClouds
    HeadintheClouds Adventurer
    Apr 28, 2012
    69
    West Carolina
  3. HeadintheClouds
    Apr 28, 2012
    69
    West Carolina
    Does anyone know of any aftermarket passenger pegs I can install on my '12? I know the bike isn't made for 2 people but I'd like to cruise the gravel roads with my young daughter on occasion. Thanks y'all!
  4. wsmc831
    wsmc831 Long timer
    Jan 25, 2006
    1,006
    Central Oregon
    Globetrottin rack with passenger pegs is the only way I've seen.
  5. HeadintheClouds
    Apr 28, 2012
    69
    West Carolina
  6. r6realtor
    r6realtor Been here awhile
    Oct 7, 2012
    287
    FL
  7. MymoJoe
    MymoJoe Ride Ride Ride
    Sep 30, 2005
    3,525
    Fernvale QLD not close enough to the desert
    Lucas, I am not sure about the reference to bling hubs from haan and rad. My haan cush hub is a direct copy of the lc4 hub. It even appears to have the ktm lc4 cush rubbers/wedges. ... can you please elaborate.
    Joe
  8. davesupreme
    davesupreme grand poobah
    May 1, 2011
    5,263
    palm harbor, fla
    i have both a KTM hub and a Rad hub, use them both w/a KTM sprocket carrier.... the KTM hub is better, don't let the cast/billet shizzit fool you.... the bearings don't fit in the RAD hub, gotta glue them in, and the RAD hubs come w/shite chinois bearings that die immediately if not sooner....
  9. Grinder
    Grinder Wrong way 'round
    Sep 7, 2006
    3,395
    Ottawa
    Any advice for taking the countershaft sprocket off?
    I want to apply a liberal coating of moly 60 and in reading about the thread direction I saw a number of people broke their bolts. I understand it's standard thread, but apparently 2701 loctite. I'm reluctant to apply heat because of the seal... Is it necessary to heat it up to take the sprocket off? I have an air impact gun so I'm not worried about that aspect of it. I'd hate to break off the bolt.
  10. Bowhunter
    Bowhunter Single Trackin' & Stick & Stringin'
    Apr 10, 2012
    1,427
    Van Etten, NY
    It'll zip right off using your impact.
    Are you replacing the dome washer, and the o-ring?
  11. Grinder
    Sep 7, 2006
    3,395
    Ottawa
    The bike only has 7 hours so I was hoping to not need to replace...
  12. Bowhunter
    Apr 10, 2012
    1,427
    Van Etten, NY
    Gotcha.
  13. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,265
    Out in the NM Dez somewhere
    Put the bike in gear and on a stand, lean over the seat from the pipe side with one foot on the rear brake and use a 17mm 6pt socket with a decent sized ratchet on the CS bolt. It'll come right off w/o too much drama.
    An impact will work fine but I try to avoid their use on the bike unless I can't break it loose manually.
  14. Aviatordoc
    Aviatordoc Hooligan extraordinaire Supporter
    Dec 25, 2008
    1,501
    Chattanooga, TN
    This works real well. Thats exactly how I do it.
  15. deeve
    deeve Adventure Lite
    Jul 10, 2010
    1,685
    Hillsboro, OR
    It looks like EE makes the KTM Hardparts Case guard that comes with a plastic chain cover similar to the OEM part. The EE branded one comes with a metal bar. Anyone running either or?
  16. deeve
    Jul 10, 2010
    1,685
    Hillsboro, OR
    Ordering a skid plate (EE) and Seat Concepts tonight. Working in what handguards to get. I want to run power for a GPS and mount for it. Its really an Android phone running Locus maps, so it doesnt have to be fancy. I'll also be getting some bags like Mosko or GL. Not decided on the rest of the mods, if any yet. Maybe a luggage rack...maybe not.
    DAVE
  17. deeve
    Jul 10, 2010
    1,685
    Hillsboro, OR
    Got any pics of your setup?
  18. deeve
    Jul 10, 2010
    1,685
    Hillsboro, OR
    Those racks look pretty good, but $80 shipping...wow! I do like the set up. Looks like you can carry a load of stuff. Is that the 5.3 tank you have?
  19. r6realtor
    Oct 7, 2012
    287
    FL
    just wondering if anyone has accumulated a large amount of miles yet from dual sporting? if so any issues? how are they holding up?
  20. 13exc500fz1
    13exc500fz1 RIDE OR DIE
    Apr 12, 2014
    483
    Newark California
    Does anybody have a good recommendation on how to properly fix stripped plastic threads on the 3.1 Gallon tank I managed to strip the upper left fuel pump mounting plastic thread
