2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. Mountainhound
    Mountainhound Long timer
    Sep 25, 2015
    2,173
    New Hampshire
    Well yesterday just wasn't my day, I was supposed to meet a guy for a ride and on the way there the caribiner at end of strap came off tie down on truck, how I've no idea. Then when I got to meeting spot I got bike and all gear out of truck and go to start getting ready when I realize I am a complete dumb ass, I forgot my boots. So didn't have no ride in the woods only on some woods roads ;( 20200925_114130.jpg
    Bitingdog likes this.
  2. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,637
    New Mexico
    Would have been so much worse with a trailer hitch rack
    Fast1 and Bitingdog like this.
  3. Mountainhound
    Sep 25, 2015
    2,173
    New Hampshire
    Isn't That truth, always a bright side.
  4. todd83-900t
    todd83-900t Been here awhile
    May 14, 2006
    240
    SLC, UT
    Most of your oil questions can be answered by sending a sample to Blackstone for an oil analysis.
    Fast1, DIRTLER and Bitingdog like this.
  5. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    15,443
    Out in the NM Dez somewhere
    if the trailer hitch rack uses straps :-)
  6. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,637
    New Mexico
    This has probably been answered somewhere but with the kind you put bolts through the footpegs, isn't it more of a problem when you run low on ground clearance driving through a ravine? Then instead of sliding the rack on the ground you're dragging the bike wheels sideways.
  7. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,720
    Aberdeen, WA
    Don't drive through a ravine. The kind with hydraulic lift raise the bikes pretty high, ultimate mx hitch hauler for instance. Now the kind with the wheel tray that protrude 2 feet behind the vehicle might be an issue.
  8. Kyron
    Kyron Oncler Inds
    Jun 11, 2007
    1,088
    Phoenix Arizona ATR > Pacifica Ca PMA
    You are changing the oil filter and cleaning the screens..... right
    :hide
  9. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,594
    Globe ''D'' Earth
    Yes, the oil doesn't really look dirty its just that it used to be clear in the site glass for a few hundred miles and now its dark at only 25 miles.
    Kyron likes this.
  10. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,463
    Reno
    I thinks it is a good observation. I wouldn’t panic either. I would think about what might be behind the color change—coolant as suggested, clutch plates, some kind of sludge buildup breaking down, ???? Kinda old school, but I might flush with diesel or solvent and see what comes out. FwIW
  11. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,391
    SouthWest (AZ)
    Mine doesn’t drag in the AZ mountains/desert. I can run bike binderz or straps. It would drag in a deep ravine though, especially when I run it in the front when I have my trailer on the back. In the back it’s way up in the air as the truck is a 4x4 and clears the ground good.
  12. RideFreak
    Apr 17, 2009
    15,443
    Obviously the truck's approach angles are seriously affected but the carrier hasn't dragged getting out to the parking areas which isn't always easy. No straps
    Fast1, Yeti2ride, Bitingdog and 2 others like this.
  13. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,391
    SouthWest (AZ)
    Nice, I went with BikeBinders for strapless, didn’t think of making something like you have there.
  14. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,637
    New Mexico
    Oh, you do have a rail. I thought without straps we were talking about the mx hauler where the wheels dangle.
    I have never seen one set up like yours.
  15. Mountainhound
    Sep 25, 2015
    2,173
    New Hampshire
    I have a ultimate mx hauler and have only hooked bike to it a couple times but I did drag tires backing truck up this small hill in my driveway and I must say that soured me about using it. The truck it was on is a 19 f350 with the fx4 package which puts truck on 34" tire so the hitch isn't low, in fact when when ultimate mx hauler is on there I have to lift bike in order to get it on it at its lowest point on flat ground. I really like the idea of it, just not sure it's for me because I always find myself on unlevel ground. 20200927_100501.jpg
  16. jm19328
    jm19328 2020 KTM 500 Exc
    Apr 7, 2015
    278
    NY
    I have the mx hauler too, super heavy duty
  17. sonic reducer
    sonic reducer Been here awhile
    Aug 19, 2007
    608
    SeaTac WA
    i need a new hitch hauler, mine is pretty rusty and a little tweaked too. what would you guys recommend for one that can withstand some harder driving on pretty bad roads? fwiw going on a 2002 toyota tundra 4x4. has a canopy on permanent or i would probably just haul in the bed. i thought about building a new one, i do have the steel for one on hand.
  18. Kyron
    Kyron Oncler Inds
    Jun 11, 2007
    1,088
  19. renogeorge
    Apr 7, 2007
    6,463
    Reno
    I’ve been using the Ultimate MX Hauler for 20 + years and swear by them. Never had a problem on rough roads or interstates. Easy to store, load and unload with no tie downs needed. Makes a good work stand when you need both wheels off the ground. FWIW
  20. Bungholio
    Oct 9, 2008
    2,720
    Aberdeen, WA
    Don't know about the hauler but the readyramp is interesting. From joehauler
