2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    17,999
    The bad side of the PNW
    Yota!
  2. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,594
    Globe ''D'' Earth
    500 EXC when a strap broke and bike got drug behind the truck on the freeway. Not my bike.
    Kaaden, Buildzall, timeOday and 2 others like this.
  3. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    1,639
    USA
    JB Weld will fix that right up.
    Fast1, petew, Bitingdog and 2 others like this.
  4. Bearded Hooligan
    Bearded Hooligan Moto Addict
    Mar 30, 2004
    1,165
    Flat, Hot & Humid South GA
    Who makes this hauler? I am in the market for one since I got rid of the truck for a van. Currently looking at Versahulers as I like the extra receiver on the outside for adding a table or something like that.
  5. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,391
    SouthWest (AZ)
    Homemade. All steel minus the 6061 block for the BikeBinderz.
    Bitingdog and Bearded Hooligan like this.
  6. brucemuzik
    brucemuzik Adventurer
    May 17, 2016
    88
    Planet Earth
    Hi guys,
    I have a 2016 XC-W 500 in South Africa that I want to make street legal.
    Does anyone know if the stock 2016 500 EXC Light Harness (#77711079000) and Flasher Harness (#77711081000) are plug and play into the XC-W 500's harness?
    If so, would that give me the connections I need to plug in all the street goodies, or am I missing something?
    Bruce
  7. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,720
    Aberdeen, WA
    https://www.truenorthmotos.com/
    Check these guys out, what you want is exactly what they do. They can probably send you what you want or maybe tell you what you need.
    Bitingdog likes this.
  8. brucemuzik
    May 17, 2016
    88
    Planet Earth
    Epic. Thank you.
  9. xxxshiftxxx
    xxxshiftxxx Been here awhile
    Sep 12, 2010
    344
    Vegas babay
    Here is where you can get a 12V power source that only runs when the bike is on if you need it for the horn and blinkers and want to save some cash. I added the red wire on the male side of the plug.
    First pic is female side from bike, this is stock with brown, yellow and yellow with blue line. Male side stock is the second picture with an open spot, add a wire to that and bam... 12v power.
  10. brucemuzik
    May 17, 2016
    88
    Planet Earth
    That's pure gold right there. Thank you!
  11. xxxshiftxxx
    Sep 12, 2010
    344
    Vegas babay
    No problem! I am pretty sure the pin that I used was from a Molex .062” connector..
  12. Sparrowhawk
    Sparrowhawk Long timer Supporter
    Sep 26, 2005
    4,417
    Eastern Washington, USA
    An oil analysis could ease your mind. The WIX test kit is only $12 US. You could use a little syringe and a bit of tubing to pull the sample.
  13. Tortuga353
    Tortuga353 Been here awhile Supporter
    May 2, 2017
    380
    I finally had a super obvious electrical problem. I hate diagnosing electronics but this one was an easy solder away to fixing. Exciting for 100+ miles of single track this weekend with for the PMMC Tower run!
    Buildzall and Bitingdog like this.
  14. NVTS
    NVTS Arrivee Secteur Special Supporter
    May 18, 2006
    1,425
    Big Lick Virginia
    I recently picked up a cream puff 2014 500 EXC. All stock, smog, exhaust canister....you get it. Is there a way to tell if the PO unlocked the ECM so it can be euro/AUS mapped? Or am I stuck going down the tuner route?
    I just sold a 2015 501 w/Euro tune and it ran a helluva lot better than this pretty little 500.
    NVTS
  15. Buildzall
    Buildzall Rooster Supporter
    Apr 22, 2013
    4,146
    Ga
    I have a 14 and 15 and adjusting the initial TPS makes a huge difference overall without going whole hog
  16. NVTS
    May 18, 2006
    1,425
    Big Lick Virginia
    Thanks. My TPS was set at .60 and I bumped it to .64
    Next big run I'll get a fuller test in but so far the bump seems to have it popping less.
  17. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,018
    MN and NM
    When I got my 2015 model I decided to try it for a while without desmogging.
    But the popping on decel got a little annoying, so I removed all the smog stuff and this fixed the popping.
  18. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,594
    Globe ''D'' Earth
    Install a ball bearing in the SAS hose or remove altogether and no more popping.
  19. NVTS
    May 18, 2006
    1,425
    Big Lick Virginia
    All the smog paraphernalia is gone now and the tps at 6.4.
    Full test soon
  20. Sōul-ō
    Sōul-ō sick and tired I stand alone Supporter
    Sep 23, 2018
    257
    Denver
    I'm not trying to derail this thread, but there's a decent deal on a 2012 xc-w. It’s plated already,
    Any reason NOT to use an xc-w as a street legal light ADV bike for BDR’s?
    thanks everyone
