2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,463
    Reno
    Only if your state doesn’t allow dirt to street conversions
  2. Sōul-ō
    Sōul-ō sick and tired I stand alone Supporter
    Sep 23, 2018
    257
    Denver
    Nope, CO doesn't care. It’s already registered here.
    Are there many/any differences I need to consider? Is the “w” gearbox sufficient for dual sporting to the trailhead?
  3. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,637
    New Mexico
    500 EXC and XC-W gearboxes are the same.
    It's not like the two strokes with XC vs XC-W.
  4. Tortuga353
    Tortuga353 Been here awhile Supporter
    May 2, 2017
    380
    I’m at 150 hours with 5000 miles and checked valves at 120 and they were good. I looked at the manual and it basically says rebuild it. What should I do to the bike to keep her happy and my mind at ease?
    I am regular with oil and air filters.
    Ran a few races but I’d say I’m not overly hard on the motor.
    JP4 likes this.
  5. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    529
    Hood River, OR
    Start at about 3:30 and Jimmy Lewis will give his take on it. He says he's got four 500's.
    rktman and Tortuga353 like this.
  6. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,637
    New Mexico
    Get a leak-down tester so you can keep an eye on compression. Then, absent any problems plan on new rings or rings+piston+valve seats every 400 hrs.
    YMMV
  7. Tortuga353
    May 2, 2017
    380
    Ok so pretty much leave her alone unless something changes. Got it! Thanks.
    I plan on checking (replacing if I’m in there) the clutch dampeners and give it a good detailed cleaning, fastener check, and lube.
    Bitingdog and JP4 like this.
  8. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,018
    MN and NM
    I must have missed something or didn't go back far enough. What is the bike doing that the manual says "rebuild it" but others say leave it alone??
    I have well over 8000 on mine. It runs like a banshee and burns no oil.
    roookie1 likes this.
  9. Tortuga353
    May 2, 2017
    380
    Just looking at the 135 hours maintenance schedule.
    Bitingdog and wbbnm like this.
  10. Colemanfu
    Colemanfu King of all manfu
    Jan 27, 2006
    5,500
    DAYTONA USA
    MX season started down here in Florida at my broski’s farm. It’s an old guys track and although not my jam, I appreciate the time behind bars. 2012 exc 500. Still pulling strong!
    2020 Opening Day at The Moto Farm
  11. Tortuga353
    May 2, 2017
    380
    @Colemanfu always enjoy those! That first case over the large table made me cringe.
    I need to get brave and ride some more moto or maybe not, Haha, my local track War Eagle MX is having its first night ride tonight. Maybe I need to ride over there.
    Bitingdog likes this.
  12. xxxshiftxxx
    xxxshiftxxx Been here awhile
    Sep 12, 2010
    344
    Vegas babay
    Had some seeping oil from the right side case gasket. Have new gasket, what are the torque settings for water pump shaft, water pump cover and right side case bolts?
    Thanks everyone!!
  13. xxxshiftxxx
    Sep 12, 2010
    344
    Vegas babay
    And I found them in my manual...
    Water pump nut, impeller, 8nm
    Water pump cover, 10nm
    Engine case, 10nm
  14. Bengt Phorks
    Bengt Phorks Been here awhile
    Sep 20, 2012
    458
    Starter button is dirty.
    you can take it apart and clean it or wash it out with water.
    The starter will last about a thousand hours before you need to change the brushes.
    The kickstarter is your backup.
    agapetos likes this.
  15. Bengt Phorks
    Sep 20, 2012
    458
    I have over a thousand hours on my 2012 so it seems pretty reliable. It's starting to burn oil so I am going to put on a new cylinder and piston. The valves seem to be fine but I will change the valve seals and springs while it's apart.
    Sōul-ō likes this.
  16. randingo
    randingo Voted "Class Lounger"
    Aug 24, 2015
    771
    The dog house
    I've been on my new to me 2016 500exc for a few months now and have never heard the fan come on and I've ridden in very hot weather and some technical terrain where it seams it should have come on. This is the first dirt bike I've ever had that has a fan so I'm not up to speed on how to start looking for where the problem might be. An specific pointers would be appreciated.
  17. Tortuga353
    May 2, 2017
    380
    I lost a key off my carabiner. The plastic little lock broke off. Anyone know the hardware store equivalent? I called KTM and they are months away from a blank.
    I have the original and card so just going to cut a few.
  18. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,018
    MN and NM
    The one on my 2015 comes on a lot. Last year I had an electrical problem which prevented it from coming on. I was riding tight trails and the bike overheated. There was steam all around me.
    So maybe if the bike isn't overheating, you are just not riding stuff that would make the fan come on. Mine won't come on riding medium dirt roads unless there is a long, steep, slow section.
  19. randingo
    Aug 24, 2015
    771
    The dog house
    Just rode Lockhart Basin on a 90 plus day with 2 friends on 500's and both their fans were coming on. I've also rode some tough single track in Taylor Park, CO and it never came on. All that said, I have never had it overheat to the point of steaming like I do all the time on my 200 XC-W. Maybe I'm just riding it like a girlyman:lol2
  20. Mountainhound
    Mountainhound Long timer
    Sep 25, 2015
    2,173
    New Hampshire
    My 16 the fan comes on often when things slow down and gets technical, but not if I can keep some speed going in technical terrain.
