2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. GSteve
    GSteve Long timer
    Feb 26, 2003
    2,107
    NM desert
    The key blanks are available through Rocky Mountain ATV/MC, (#39 on diagram), https://www.rockymountainatvmc.com/oem-schematic/2. They show 10+ available.
    Westerly_Wind and Tortuga353 like this.
  2. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    4,183
    Bridge over Troubled Water
    Friend with a MY14 500 had the fan bearing seize with less than 2000 miles on it. What helped the diagnosis is when three of us rode together with our 500s and it was hot and humid conditions, his never turned on in tight single track.
    We pulled things apart trailside and found that the fan would not turn by hand without excessive force and the fuse was blown. @RideFreak suggested a replacement fan that was identical to OEM and that solved the problem. I believe the posts are from late last summer within this thread.
    randingo likes this.
  3. motokeith
    motokeith Been here awhile
    Mar 29, 2012
    990
    Falcon, CO
    I had zero issues just walking into Home Depot and getting a couple dupes of my 2014 key cut. Must not be a particularly special blank.
    Tortuga353 likes this.
  4. Tortuga353
    Tortuga353 Been here awhile Supporter
    May 2, 2017
    380
  5. bigtodd
    bigtodd Hi, wanna ride?
    Apr 18, 2010
    3,440
    Surf City, USA
    Most likely a bad thermostat switch ... if you have a power source (spare battery, lead from battery, etc.), unplug the fan wires from the thermostat and connect to your power source. If the fan kicks on you have a bad thermo switch. Might consider a low temp switch as a replacement. I also like this radiator cap from RMATV;
    ezflyr, ChasM and randingo like this.
  6. Bengt Phorks
    Bengt Phorks Been here awhile
    Sep 20, 2012
    458
    First place to look is the thermostat at the bottom of the right radiator. Pull back the wire cover, and with the ignition on, put a jumper wire between the 2 contacts to bypass the thermostat. the fan should go on.
    The thermostat not working has been a problem on some bikes like my 2012 500 EXC. I replaced it with a 90 degree centigrade thermostat to make the fan come on a little sooner.
    https://www.partsgeek.com/r5cf2jd-b...4+BMW+3.0S+Auxiliary+Fan+Switch+-+Beck+Arnley
  7. Sparrowhawk
    Sparrowhawk Long timer Supporter
    Sep 26, 2005
    4,417
    Eastern Washington, USA
    You might try a good locksmith shop. Probably won't find much at a local hardware store.
  8. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,018
    MN and NM
    I lost my spare key a couple of years ago and took my main one to a high end locksmith. They couldn't find an exact blank match to the key. But after some searching the guy found one he was pretty sure would work.
    I went ahead with it and it does work.
    I don't have the key in front of me. It is stored in my Camelback. If there is any interest I will get it out and try to figure out what the make and model is.
  9. Magus
    Magus Never grew up... Supporter
    Jan 25, 2006
    620
    Texas and Colorado
    2012 xcw in Denver
    Sounds like the one stolen from me
  10. Fast1
    Aug 18, 2007
    4,183
    Good idea!
  11. ChasM
    ChasM Been here awhile
    Nov 27, 2007
    813
    Loomis, CA (Sacramento area)
    You have already received several helpful things to check. The first thing to check is to short out the leads to the thermo-sensor. If the fan does not turn on this indicates either a faulty fan or perhaps a blown fuse. If the fan turns on the problem is most likely a faulty thermo-sensor.
  12. Bengt Phorks
    Sep 20, 2012
    458
    Some varieties of Master padlocks keys are the same as the KTM keys. My KTM key will open one of my Master padlocks and I found out when I accidentally put the wrong key in the lock. It just happened to be the lock I use to chain my bike in the garage. So now I use the bike key to open the padlock and run the bike.
  13. Tortuga353
    May 2, 2017
    380
    Interesting
  14. HellSickle
    HellSickle Scone Rider
    Sep 19, 2005
    22,824
    Fort Collins
    Loaded for bear (beer?). Death Valley trip for my 10th anniversary with my honey. She will be on her venerable DR350.
    I probably will shed some gear, but some items I don't normally carry are an extra quart of oil, center-stand device, rear tube in addition to the front, emergency bivy sack, and loads of water.
    I'm geared taller than I've ever been at 15/48.
  15. Bengt Phorks
    Sep 20, 2012
    458
    Some maps for your gps and phone for Death Valley.
    OwlsheadGPS Project app for the iPhone. Offroad maps for all of California.
    Owlshead gps maps for death valley.
    https://www.owlsheadgps.com/owlshea...ea/54-owlsheadgps-project-garmin-gps-img-file
    Death Valley map for your phone. Scroll to the bottom of the page.
    http://www.ctuc.info/ctuc/index.php
    Buildzall and HellSickle like this.
  16. HellSickle
    Sep 19, 2005
    22,824
    Fort Collins
    Thanks, I already downloaded a couple of different geo-referenced pdfs. For simple navigation, the park service map has been georeferenced and is available free.
  17. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    6,018
    MN and NM
    Yeah, being a National Park there is not much opportunity for exploring obscure roads. I think you are pretty much limited to following what's on the official maps as long as you get the good backcountry map. Which IMHO is plenty.
  18. little squirt
    little squirt Been here awhile
    Sep 22, 2010
    120
    808 All Day
    sold my WR250X and upgrading to this in a couple days.
    2016 500 6day, 3200miles. Can't wait!! Any quick pointers to keep an eye on at first besides oil change and check coolant? going to pull wheels, swingarm, triple trees to grease all the bearings and give a good once over. Thanks for any input fellas! Glad to switch threads :clap
    Buildzall, Fast1 and DIRTLER like this.
  19. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,594
    Globe ''D'' Earth
    Looks Great, should be good to go. Sometimes the ground strap from the battery to the sub frame needs to be cleaned and tightened.
  20. timeOday
    timeOday Long timer
    Jun 20, 2008
    3,637
    New Mexico
