2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    4,677
    SouthWest (AZ)
    Well, that set up isn't for me but I dig shit like this when folks go all out making it their own and there's clearly a lot of effort and time put forth. I dig this kind of stuff. Very cool
    l_c8 likes this.
  2. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    4,309
    Arlington, Texas
    Thanks. It works good for what I use it for, and I can change it back to a single track day rider in short order. :thumb
  3. motokeith
    motokeith Been here awhile
    Mar 29, 2012
    741
    Falcon, CO
    If you remove the stock dongle thingie and leave the key in the on position the bike behaves exactly the same way. I like this setup as I can just use the run/kill toggle while off-roading but still have the ability to remove the key if I need to leave the bike unattended whilst I run in somewhere.
    oldfuddy likes this.
  4. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,471
    Aberdeen, WA
    Interesting, so the black item that is removed when you insert the eliminator? Then the head and tail lights will go off after a few seconds when the kill switch is off? Might have to try that.
  5. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    11,294
    Vancouver B.C. rainforest
    You sir are correct!
  6. RideFreak
    RideFreak Torque Jockey
    Apr 17, 2009
    13,227
    Out in the NM Dez somewhere
    That's the route I took, if we leave the bike outside somewhere over night it's usually out in BFE Utah with nobody around, otherwise it has a cable lock going through it or in the room.
    I prefer the dirtbike (no key) setup but if I am going on a trip where I feel the key is important I can throw the switch back on in a couple of mins which doesn't say much for the bikes security, that's why its fully insured. .
    Bitingdog and oldfuddy like this.
  7. brokeassloser
    brokeassloser I'll do it!!!
    Jan 2, 2007
    1,276
    Vancouver WA
    I have the key eliminator and sometimes I just pull the dongle. Takes seconds and fits well in my pocket. Usually I don't bother as these bikes are so easy to steal- that's what insurance is for.
  8. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    4,677
    SouthWest (AZ)
    Ya know.... That's pretty smucking fart right there. Nice.
  9. Bengt Phorks
    Bengt Phorks Been here awhile
    Sep 20, 2012
    429
    If you pull the jumper plug off the ignition key switch you will still be able to use the key switch as usual and the bike will shut off all the power after about 8 seconds just like if you have the key eliminator plug installed. The bike will not start unless the key switch is in the run position.
  10. brokeassloser
    Jan 2, 2007
    1,276
    Vancouver WA
    The key switch eliminator is about five bucks and probably in stock at your KTM dealer. Why monkey around?
  11. Bengt Phorks
    Sep 20, 2012
    429
    You save 5 bucks.
  12. brokeassloser
    Jan 2, 2007
    1,276
    Vancouver WA
    You used to ride a KLR didn't you?:lol3
  13. the_babaji
    the_babaji Long timer
    Oct 10, 2011
    1,102
    Ontario, Canada
    Guys, im getting sick of carrying my tool roll, spare tube, pump, etc.... on my back, is there a nice solution some kind of tail bag, that is robust enough for some heavy items, and wont fly off going down the trail?
  14. MasterMarine
    MasterMarine Long timer
    Jan 22, 2007
    2,332
    Now serving just Snohomish County
    I use one of these Dirt Bike Gear Tube bags to carry tools in. It fits perfectly below my HDB Rally Lite Setup but also fit well with my stock headlight map. I don't carry a tube in it tho. The way it is designed, it will not come off.
    I also use a Cycoactive Fender Bag to carry my spare front tube and a couple of longer tools on the front fender. I converted to the newer style fender which is much stronger. I used a kit from Flatland Racing to put a 2014+ fender on my 2013 bike.
    Here they are on my bike:
  15. BRUTE448
    BRUTE448 15' KTM 450 XC-W (Oregon Plated)
    Dec 6, 2015
    136
    Oregon
    i just got the wolfman luggage "day tripper" saddle bags and i 100 % vouch for them, rackless system and holds tight and steady!!! tools /coat/ shirt/ tow rope/ terry towel all fit with room to spare! and only thing on me now is water!!!
  16. Bungholio
    Oct 9, 2008
    2,471
    Aberdeen, WA
    GL Mojave would work well too. I had/have a Wolfman rear tool bag that carried my KTM tool kit and a tube and a couple other odd items. And an enduro tank bag for another tube, camera, gloves, phone, flashlight and other odd and ends. Pretty compact and out of the way. Plus hydration pack with tire irons and good to go. Tank bag also good for padding the twins on downhills while seated.
    Photo with fuel bottle as well. I used the fender bag for that one trip then gave it to my son in law.
    I like the Kriega US-5 and 10 for mounting on the rear, but the US-10 may be a little large back there for my taste.
    RideFreak likes this.
  17. like2lean
    like2lean Been here awhile
    Apr 24, 2014
    228
    Okc, OK
    I like the Kriega 5l.
  18. motokeith
    Mar 29, 2012
    741
    Falcon, CO
    I use a Wolfman Enduro Tool Bag. It has a base plate with compression straps and velcro that is bolted to the fender and solidly secures the bag, but allows the bag itself to be removed from the bike. Pics, because who doesn't like pics...
    The mounting plate on the bike in the "just screwing around at the OHV park" configuration
    Attached to the bike (camera angle makes it look huge, lol)
    Contents of bag in organizer packs.
    Organizer packs exploded
  19. Johnrunner89
    Johnrunner89 AdventureNewb
    Jun 13, 2013
    127
    California
    If you want a super slim option, I run the dirt bike gear fastboy with a small tool wrap. Fits my ktm tool kit, full socket kit, an air gauge, pump, zip ties and t handle. I still carry a couple of small handy stuff in my hydration pack that I might need if I had hike off the bike. Here's my setup.
    biggziff and Lutz like this.
  20. Bengt Phorks
    Sep 20, 2012
    429
    Oh god no just Huskys.
