2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    4,200
    SouthWest (AZ)
    First race of season tomorrow. Up in the Sheridan Mountains outside Prescott AZ. 60 rows of 4 bikes each row... I'm in row 56. All good.
    Dan950ser, Stu, Tortuga353 and 4 others like this.
  2. AussieEvo
    AussieEvo Adventurer
    Feb 8, 2017
    21
    Nice work 2bold, thanks mate!!
  3. Duzitall
    Duzitall old dude
    Dec 20, 2015
    315
    San Diego
    Best of luck!
  4. CanadianX
    CanadianX Don’t leave a steaming pile for others.
    Dec 26, 2010
    3,892
    New Brunswick
    I'm thinking ahead to a bit of an overhaul this winter and wondering what I should do to the 500. Thinking refresh and preventative maintenance. I'm closing in on 300 hrs with nothing but valve checks and oil and filter changes for the most part. The motors runs true, burns no oil and it shifts as it always has. Clutch is still the original, no problems with it. Bike is stock with a slight tweak to the TPS volts, canister removed and exhaust stock with screens and all.
    My list:
    Fluids (brake, coolant etc.) Any value in flushing the clutch hydraulic fluid?
    Clutch dampers
    Service suspension
    Service Swing arm pivots
    Rear brake pivot rebuild
    True and balance the wheels
    New chain and sprockets.
    New in tank fuel filter
    Detailed cleaning
    What else?
    Maybe time to have the damper serviced? I was also thinking plastics and decals as mine are pretty beat but that the nature of riding it.
    Bitingdog likes this.
  5. Vincenthdfan
    Vincenthdfan Long timer
    Apr 30, 2009
    2,020
    Olympia, Washington
    Wow, that is awesome service you've gotten out of that bike, very encouraging!
  6. Grinder
    Grinder Wrong way 'round
    Sep 7, 2006
    2,943
    In DC traffic...
    I think that's a pretty complete list but add steering head bearing service, lever pivot clean and grease. Once you start into it, you may notice other things like wiring or other little items that need attention.
  7. DesertRatliff
    DesertRatliff Tinker Tinker Ride Ride
    Feb 12, 2007
    1,747
    Durango, CO U.S.A
    Wheel bearings in good shape?
    +1 on head bearings.
    Otherwise, your list looks a lot like mine for the winter (clutch dampers and suspension anyway) and reminds me I should probably check my TPS setting.
  8. CanadianX
    Dec 26, 2010
    3,892
    New Brunswick
    Ah, yes head bearing, forgot about that. It did get freshened up at around 100 hrs when I put the damper on and the lever pivots have had some tlc as a matter of seasonal routine but definitely good to add to the list. Ack the wiring. After the 690 I've been weary of KTM wiring but the 500 is certainly more simple but some dielectric grease in the connectors would be good.
    I was thinking piston rings but it isn't down on power and isn't burning oil so thought I'd leave it alone, least I get into chasing the weak link after changing one wear item in the system.
    @DesertRatliff yeah wheel bearings are good. The fronts are the originals if you can believe that. The rears have been wearing out fast. I suspect I have on one occasion over tightened the axle nut but I think I'm on my 5th or 6th set. The bike does see a lot of mud and water but it seems the intervals are getting shorter. Chain seems aligned so truing and balancing the rear wheel and perhaps replacing the inner spacer might be next. The plastic inner spacer that goes on the brake side before you put the bearing in is suspect now. I've heard people not running it but it was in there fromt the factory so I have kept it.
    DesertRatliff likes this.
  9. CSpringsRider
    CSpringsRider Been here awhile
    Apr 17, 2015
    325
    Colorado Springs, CO
    I have a question for those of you who run Tubliss. Has anyone installed them using a used tire and if so, what kind of problems, if any, did you have? The videos on their website say to use new tires because of the dent caused by the rim lock in a used tire. I have a set of Tubliss inserts and a new front tire for the 500 but my rear tire (MT43) still has lots of miles left. I also have the Beta with two "new" tires (150 miles at this point). Any feedback would be appreciated as to the likelihood of problems caused by using a Tubliss with used tires.
    davesupreme likes this.
  10. CanadianX
    Dec 26, 2010
    3,892
    New Brunswick
    No feed back but I'd be curious to hear about how the front feels with tubliss installed. Someone told me they didn't like it as it felt vague for handling. (??) I figured it would feel about the same as a tube with the same air pressure ...? Thinking about going tubliss front and rear to reduce unsprung weight and preserve my rims.
  11. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    1,874
    Olympia, WA
    Yes and the problem is that they will constantly leak because the bead doesn't want to seal on the rim. You could try and run the rim locks in the same place and see what happens.
  12. Branchbuster
    Branchbuster Been here awhile
    Mar 13, 2017
    584
    Manistee National Forest
    I have installed a used tire, D606, on my TubeLiss 2 rear... Then went on and wore that one out. No problems at all.
  13. Branchbuster
    Mar 13, 2017
    584
    On a Tubliss system the entire inner liner is a bead lock. You wont have problems if you Tire Slime the bead all the way around like the instructions tell you to do. You are also told to check your tire pressure each day you ride.This is a small concession to make for me for such great performance.
  14. Branchbuster
    Mar 13, 2017
    584
    CanadianX.... Be careful not to over-tighten your drive chain. You might be doing this to make it more quiet, but it is hard on wheel bearings. They require more slack than other bikes for sure.
  15. Dan950ser
    Sep 24, 2010
    1,874
    Olympia, WA
    I understand how the tubliss system works and when I install mine with a new tire they rarely ever leak at all. I was suggesting to put the black rimlock in the picture near the old indent on the used tire. I use a tractor tire sealant because I like it more than the slime stuff. A used tire will work but probably leak so just keep an eye on your air pressure. IMG_5146.JPG
  16. bigtodd
    bigtodd Hi, wanna ride?
    Apr 18, 2010
    2,749
    Surf City, USA
    Nice! Always able to find a way to work in that tractor you like to play with :-)
    Dan950ser likes this.
  17. Dan950ser
    Sep 24, 2010
    1,874
    Olympia, WA
    Had are first bonfire of the year on Saturday and stoking the fire with the new tractor is definitely fun! :thumb
  18. CanadianX
    Dec 26, 2010
    3,892
    New Brunswick
    Nope, I'm good there and run on the slightly looser side for chain tension to ensure the suspension has full unimpeded range. I'm thinking chain alignment or bent rim/bad balance. I don't ride a lot of road miles but short rips on the hwy are required to get to the trail head and the rear wheel being unbalanced, low tire pressure and a non-DOT soft tire tends to hop a fair amount which may be stressing the bearings.
  19. scottydawg
    scottydawg Been here awhile
    Sep 19, 2010
    124
    Sacramento, CA
    Circling back on sprockets now that I am going to make firm decision. Any input on using the Dirt Tricks products? How about Dirt Tricks vs. Supersprox?
  20. RideFreak
    RideFreak Torque Jockey
    Apr 17, 2009
    12,367
    Out in the NM Dez somewhere
    I've had great luck with supersprox, the front c/s are the factory width so no leaking because the sprocket wasn't machined right. I don't think I've ever thrown away a supersprox rear, they wear very slowly.
    WRW9751, scottydawg and oldfuddy like this.
