2012 ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. kito
    kito Been here awhile
    Mar 8, 2009
    468
    cheshire , England
    Looking for a bit of wiring advice please. I want to install an ignition switch on my bike. I have a key switch that has both closed on and closed off so though I'd wire it to both the starter button and the kill switch. The left switch that has the kill button also has horn ,high/low beam and indicators so the is quite a few wires coming out of that so which colour wired do I need on the kill side ?
    Thanks kito
  2. RideFreak
    RideFreak Torque Jockey
    Apr 17, 2009
    12,360
    Out in the NM Dez somewhere
    That looks kinda familiar :D
    DesertRatliff and 2old2Bbold like this.
  3. jcat5503
    jcat5503 Been here awhile
    May 15, 2015
    176
    Houston
    Any of you guys ditch the rim locks? I am considering it, because I never air down below 15psi or so.. It should help a lot with balancing the tires.
  4. spaceman_spiff
    spaceman_spiff Long timer
    Jul 24, 2008
    2,428
    Santa Cruz, CA
    I will never ride without rim locks. If you're out somewhere and can't patch or replace a flat tire then the rim locks will make it possible to ride on the flat.
    Also you should try airing down more. It's amazing how much more traction comes from just a few lbs difference!
    Bitingdog likes this.
  5. katoomryder
    katoomryder Adventurer
    Aug 27, 2007
    99
    Cambridge, NY
    Don’t do it. The rim locks are your only means of maintaining control if you get a flat. The tire will likely unseat from the rim, leaving you with no direct contact with the ground.
    If you’re having trouble balancing your wheels, drill a new hole in the rim opposite the valve stem. Then install the rim lock opposite the valve stem.
  6. RideFreak
    Apr 17, 2009
    12,360
    It helps allot with balancing the tire. Depends on the riding, I wouldn't do it for hardcore dirt. My dirt wheels have rimlocks, the cush wheel doesn't and that one gets run at 16-18 psi. No issues at that pressure.
  7. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    10,095
    Vancouver B.C. rainforest
    Two rimlocks 180° apart or a Motion Pro lite-loc will make balancing your wheels easier. I couldn't ride half of the trails that I like at 15psi. Sometimes I run half of that in my back tire, depending upon the tire and terrain
  8. Grinder
    Grinder Wrong way 'round
    Sep 7, 2006
    2,942
    In DC traffic...
    Yup. I rode all day on a front flat. I had a tube but my buddies were in a hurry and I didn’t want to hold them up. In retrospect, the day might have been more fun with air in my tire! Rim locks are useful.
  9. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    4,197
    SouthWest (AZ)
    some 500 pic's from this weekend....
  10. CSpringsRider
    CSpringsRider Been here awhile
    Apr 17, 2015
    325
    Colorado Springs, CO
    Update on the Tubliss install. The rear install was straightforward and no problem. I thought, "what is the big deal?" Then I took on the front. What a PITA! No matter what I tried, I could not get enough slack to get the last 6-8" of the second bead on the rim. Finally got it on with the help of my buddy using way more muscle than I would have expected to be required. I thought we were going to bend tire levers, we were pushing so hard. My tire changing technique definitely needs work.
  11. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,381
    Aberdeen, WA
    You hired a photographer!?
  12. Duzitall
    Duzitall old dude
    Dec 20, 2015
    315
    San Diego
    Same here. Rear, easy. Front, WTF? Extra difficult with stiff tire like the Fatty DST. No fucking way that thing was fitting in the drop center with TUbliss. I used truck tire irons and a LOT of harsh language to get it done! Next time, wheels go to Clairemont Cycle Supply. Let Jamie deal with that task. I'll pay gladly. TUbliss is still worth it!
  13. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    4,197
    SouthWest (AZ)
    ttmike likes this.
  14. jcat5503
    May 15, 2015
    176
    Houston
    I actually have a set of the lite-locks in the garage. Maybe I will just install those. What do you recommend as far as weights once I do that?
  15. avconnect
    avconnect Been here awhile
    Apr 22, 2012
    448
    Salt Lake City
    1. Thinking of buying the Acerbis 4.1 tank. Anyone know if my KTM hard parts radiator guards will interfere?
  16. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    3,818
    Arlington, Texas
    My guards clear by ~ 1/8" at the top, outside corner.
    thumpididump likes this.
  17. RideFreak
    Apr 17, 2009
    12,360
  18. Yardstick
    Yardstick Hydrophobic
    Oct 18, 2007
    3,725
    Chandler, Arizona
    My bike sprung a leak! Actually, the fuel line quick disconnect is leaking. I haven't finished diagnosing the problem but I would be interested to know if anyone else has had this happen. I had the KTM wash plug kit installed with the supplied O-ring on the tank side and the cap on the Zip-Ty filter for a couple of days while adjusting valves, waiting on shims and doing some other maintenance. I put the tank back on last night and reconnected the fuel line. Everything felt normal. When I hit the starter button a stream of fuel shot out from between the two halves of the quick disconnect fitting. The O-ring supplied in the wash kit felt a little tight. Could that have expanded the plastic on the male part of the quick disconnect fitting causing the connection to become loose? Or did the O-ring on the Zip-Ty filter dry out? Any other ideas to check?
  19. bigtodd
    bigtodd Hi, wanna ride?
    Apr 18, 2010
    2,749
    Surf City, USA
    I'm using this tank with the Bullet Proof guards ... no issues
  20. Vincenthdfan
    Vincenthdfan Long timer
    Apr 30, 2009
    2,019
    Olympia, Washington
    I think it dried out.
    I've made many, many O-rings work again by soaking them in straight gasoline overnight and reinstalling them.
    They re-swell back up after shrinking from drying out.
    I learned this working on jet aircraft early in my Air Force career....fuel leaks from manifolds everywhere when first refueling, then they would cure themselves once the seals would swell back up.
    davesupreme likes this.
